Re-gear with used 4.10 gears?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Jul 1, 2011.
  1. Jul 1, 2011 at 8:33 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    My truck has 285/70/17's
    Would it be possible for me to re-gear my truck with this used 4.10?
    Would I need anything else like an install kit or would I be able to just swap the gears?
  2. Jul 2, 2011 at 3:40 PM
    BarefootBandit
    Anybody? :[
  3. Jul 2, 2011 at 6:11 PM
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    Seems like most Tacoma people regear when going with taller tires, like 35s and end up with 4.88 since the cost (esp. labor) is rather high.
    I previously ran 4.56 with 32" BFG MTs (another vehicle) and it was too tall -- except when offroad, of course. The little things got to me, like when the lunchbox locker and tall gears made starting and turning at low speeds an adventure on wet or slick surfaces :)
    Anyway, IIRC, when I got my gears, I got the "master install kit". Depending on vendor and application, that's like the ring and pinion, pinion bearing, carrier bearing, crush sleeve, ring gear bolts, cover gasket, pinion nut, and even a little thing of loc tite.
    I would also buy new if buying gears. The time (or labor) to set gears right is worth a little more for a new set.
    My tacoma is new, barely through an oil change, so I know dick about swapping gears on them. Plus I only stood around and watch the guys who set mine. (A couple backyard drag racing types who wrench for extra cash.) So I wouldn't be much help
  4. Jul 2, 2011 at 6:36 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    You will have to get a 4 banger third to use 4:10 gears.
  5. Jul 2, 2011 at 6:54 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    deleted (researched)
  6. Jul 2, 2011 at 7:09 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    IM IN THE SAME SITUATION,AND YOUR FUEL MILEAGE WILL GET BETTER NOT WORSE.U CANNOT USED USED GEARS UNLESS YOU HAVE THE AXLE HOUSINGS AND THERE STILL IN THE PUMPKIN.YOU CAN NOT GET A PATTERN ANY OTHER WAY AND THEY WILL CHATTER.;)
  7. Jul 2, 2011 at 7:10 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Gas should go up slightly around town. And more torque.
  8. Jul 2, 2011 at 7:14 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Um I disagree respectfully, I got used gears with 136k miles on them and they have been nothing but perfect for what I needed. Installed maybe 6-8 months ago and nothing but great results with a satisfied end user!
    :woot: for regearing and doing the right thing for your truck thats got bigger tires!
  9. Jul 2, 2011 at 11:34 PM
    sooner
    TX
    2011-4X4-LONGBED
    i guess you got lucky ,but wont work in 2011 front clamshell.is ur truck 4x4?
  10. Jul 3, 2011 at 6:35 AM
    08pretaco
    az
    I am 2wd yes
  11. Jul 3, 2011 at 6:48 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well new gears are always preferred if you have the $$$ for them but I wouldn't be afraid to throw in a set of used gears, ya just have to know what to look for as far as burns & scoring, chipped,cracked,missing teeth etc; the chattering mentioned sounds more like a preload issue with the pinion & ring gear matching
  12. Jul 4, 2011 at 11:08 PM
    sooner
    TX
    2011-4X4-LONGBED
    im not saying you cant ever use used gears .im saying in a 2011 new style front clamshell you have to have brand new gears or the old axles with the gears still in them,to get the correct pattern.:confused:
