re gear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by k9port, Apr 18, 2012.
  1. Apr 18, 2012 at 5:01 PM
    k9port
    k9port [OP] Active Member
    Palm Beach
    SR5
    Leveling Kit, Pro Comp ES 6000 front shocks and Pro comp ES 9000 rear shocks
    I'm thinking of purchasing a Detroit Locker trutack for my 2004 SR5 3.4 dbl cab. Not sure which gears are in it now. Should I re gear when I do this mod? If so what should I change to? Im looking for more power at the rear when I need it. Also, Can anyone recommend a better or similar unit to the Detroit? Thanks!
  2. Apr 18, 2012 at 5:16 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    What size tires? if you have stock and are looking for more power get 4.56 and if you have 33's and up get 4.88's.
  3. Apr 18, 2012 at 10:48 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    x2.
    detroit is probably the best LSD, you have 4.10 gears atm (edit) if it is still stock
  4. Apr 18, 2012 at 11:59 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    You wont need to re-gear just because your adding a locker. but if you do regear then also remember that you will have to regear the front as well since your 4x4... and as for hte ratio dont even mess with 4:56 go straight to 4:88 imo, thats what ill be doing sometime soon hopefully lockers front and rear
  5. Apr 19, 2012 at 12:31 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    What size tires?! If they are oversized compared to stock, definitely regear! - It will be the best decision you can ever make (absolutely for ur truck and and maybe even for your life haha)
  6. Apr 19, 2012 at 12:49 AM
    valon5150
    Steven
    redding
    01 taco turd
    i would consider gears a life changing decision. at least i hope when i regear this summer that it changes my life haha
  7. Apr 19, 2012 at 12:56 AM
    especk
    Erik
    Redding, CA
    it will make u more of a man for sure!
  8. Apr 19, 2012 at 1:01 AM
    valon5150
    Steven
    redding
    01 taco turd
    doubles the size of your balls right?
    offtopic but how are you still awake? like 6 hours ago you looked like you were half way to falling asleep standing haha
