Re-Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by type o negative, Jan 30, 2009.
  1. Jan 30, 2009 at 3:44 PM
    type o negative
    type o negative [OP] Well-Known Member
    UT
    09 Double Cab TRD Sport - White
    Ok youve all seen my threads on lifts, well Im planning on regearing at the same time. From what ive seen on this site, for an 09 double cab automatic it sounds like I need 4.56? now I know NOTHING about gears.. Does this mean I need them in front and in back? and is there different types of gears? Im completely ignorant about this... Feel free to make fun of me, I would :D
  2. Jan 30, 2009 at 3:50 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Why are you re-gearing? Are you putting 37" tires on your truck?
  3. Jan 30, 2009 at 3:51 PM
    type o negative
    UT
    Ok so maybe it was a dumb question. I just thought going to 33s would lose quite a bit of gas mileage and you could do a regear to compensate...
  4. Jan 30, 2009 at 3:52 PM
    TacoCo
    Colorado
    Not necessary for 33's
  5. Jan 30, 2009 at 3:56 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    You will notice alittle loss in power and gas mileage. You don't really have to do a regear but if you do decide to go with Yukon gears front and back.
  6. Jan 30, 2009 at 4:00 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    You'd have to do a hell of a lot of driving to have your gas mileage make up for the cash you'll be dumping on gears. You might lose 2 mpg with 33" tires.
    The best (cheapest) way to improve mileage with larger tires is to keep them properly inflated.
  7. Jan 30, 2009 at 10:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You'll notice power loss.......in RPM's
    For example: when you get on the highway and your trying to get up a hill/mountain.... you'll have your foot on the floor and you still won't gain any speed getting up the hill. In fact, you'll drop down in speed because your RPM's at say 60mph will be much less with stock gears than if you put new (higher) gears in.
    If you're willing to *get used to it* (the power loss) - save your money.
    Other than that...... you could change your gears but I would highly recommend researching the cost involved. In most cases - a carrier change & gearing setup is required ($$). While you're changing the carrier - you might as well buy a traction device (locker, LSD, posi, or whatever).
  8. Jan 31, 2009 at 6:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I would re gear for 33's, but that s me. 4:10's would be about right for a 33" tire. Or MAYBE 4:30's, but they would be on the shorter side of the curve. Performance would definatly increase. Re gearing is one of the best things you can do when going to laerger tires.
  9. Jan 31, 2009 at 6:41 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Moneybags.... (j/k :D)
  10. Jan 31, 2009 at 6:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not that much to re gear. Maybe $1100.00, but in the scope of mods, thats not bad. Especially when considering the performance gains.
  11. Jan 31, 2009 at 6:44 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
  12. Jan 31, 2009 at 6:50 AM
    Cobra69
    I agree with Chris......I went with 4:88's on my rig. It calls for 4:56's but i wanted alittle more torque and power. Yes I gave up some rpm's and gas mileage ,but i don't do a ton of highway miles to worry about it.
  13. Jan 31, 2009 at 6:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. Anytime I regear a vehicle, I will "Over gear" it. ;)
  14. Jan 31, 2009 at 8:29 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    if ur putting 33's on a v6...theres prob no reason to regear. u'll lose a little power but not much.
    I on the other hand have a 4cyl with 33X12.5 and i feel a real loss of power. i went from 19MPG to 15MPG and it feels like a dog sometimes.
    When i have the money i will be regearing to 4.56's thats a good gear ratio for 33's
  15. Jan 31, 2009 at 12:50 PM
    4getful
    4getful Senior Junior Member In Training
    Dan
    Gilbert, AZ
    09 DCLB 4X4
    6" Pro-Comp Stage 2, 35x12.50x20 ProComp Xtreme All Terrain, 20" KMC Revolvers, 4.88 Gears, Banks Exhaust De-Badged
    Man, I wish it was only 1100 for gears. I got the 4.88's for my truck and it cost me 2300. I had to end up getting an Arb locker up front to carry the gears. They told me that the stock carrier was to small. The front was the problem, the rear was fine.
  16. Jan 31, 2009 at 12:52 PM
    Janster
    Jandy
    Lancaster, PA
    And that's a problem? You have an ARB.... consider it money WELL spent.
  17. Feb 3, 2009 at 11:18 AM
    4getful
    Dan
    Gilbert, AZ
    09 DCLB 4X4
    Nope, no problem at all. I just wasn't planning on doing a locker this soon.
  18. Feb 3, 2009 at 4:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are cheaper because they have a thiner ring gear and a smaller pinion. To get the higher gearing out of the same size ring gear, they have to make the ring gear thinner. Usually, they are not as strong as a lower gear either.
  19. Jun 26, 2012 at 11:09 PM
    tacowhore
    tacowhore Active Member
    ricky
    hamilton On.
    02 tacoma feeler
    lowering kit K&N cold air intake
    im also pretty clueless about gears and the re-gearing process but ive heard that it does increase performance? my truck is lowered how ever and is only rear wheel drive. do you have any input on a re gear for my truck?
  20. Jun 27, 2012 at 7:15 AM
    badger
    badger Well-Known Member
    07 SR5
    If you are lowered 2wd I assume you also run low profile tires. I can't imagine why you would want lower gears too.
    When you say it "improves performance", that is all relative to what you want from your truck. Lower gears will make the truck feel peppier because the transmission will walk through them quicker. It will most likely lower your quarter mile times and get you across an intersection faster. You will sacrifice a lot for that little buzz though on a street truck. The transmission will be rowing up and down constantly, and your highway performance will be severely impacted. If you are running low tires, you are already running under factory final gearing. I wouldn't push that any lower.
