re-gearing 4.0L 4.11-4.56
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dont surf805, Dec 9, 2012.
  1. Feb 24, 2013 at 9:03 PM
    BradyT88
    BradyT88 Well-Known Member
    No if you are a 6 lug you have 4.10's. If you are a 5 lug, you have 3.30's or 3.xx's (I can't every remember that 2nd ratio but it is a lower number than 73.)
  2. Feb 24, 2013 at 9:08 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    thanks what would you reccomend i get if i went with some 31/10.50/15 tires? i have 235/75/15 now and it feels sluggish compared to the stock 215/70/15s
  3. Feb 24, 2013 at 9:10 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    i seem to remember being 3.73s in the stock 6 lug...
  4. Feb 24, 2013 at 9:11 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    V6 yes, I4 has 4.10. Talking 6-lug here.
  5. Feb 24, 2013 at 9:16 PM
    MIAtaco
    Brian
    Miami FL
    i sadly have the 5 lug
  6. Feb 24, 2013 at 9:17 PM
    BradyT88
    Depends. Are you a 5 lug or 6 lug. If you are a 5 lug I would try to find somebody getting rid of some 4.10's. Try calling Just differentials or East Coast Gear Supply they may have a used set they can sell you for cheap. If you are a 6 lug I may just go straight to 4.88's.
  7. Feb 24, 2013 at 9:22 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    6 lugs come stock with 3.73s
    5 lugs have 4.10s stock.
  8. Feb 24, 2013 at 9:23 PM
    ColtsTRD
    Scott
    AZ
    and the Toyota 4.10s will not work with TRD O/R packages because they have 8" diffs.
    The 4.10s come outta 8.4" diffs (base, SR5 and TRD Sport)
  9. Feb 24, 2013 at 9:24 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Not entirely true, also depends on motor.
  10. Feb 24, 2013 at 9:25 PM
    BradyT88
    Just looked around some and I'd guess you have the 3.31 factory gears since that puts you at 2200 rpm at 75mph with the stock 215/70/15's. 4.10's with the 31/10.50/15's will get you up to about 2350 rpm which is a little over factory so considering the extra weight of the 31's it will likely feel about the same as stock.
  11. Feb 24, 2013 at 9:28 PM
    ColtsTRD
    Scott
    AZ
    True, I forgot they make 6 lug 4 bangers
    my bad
  12. Feb 24, 2013 at 9:36 PM
    BradyT88
    All V6's are 6 lugs and have 3.73's factory except the X-runners that are 5 lugs and have 3.15's.
    4 cylinders can vary. 4wd's and Prerunners are 6 lug and have 4.10's. 5 lugs are 2wd and come with 3.31's commonly and one other ratio that I can't remember... might be 3.15's.
    There are a few exceptions in here though I'm sure.
  13. Feb 24, 2013 at 9:40 PM
    ColtsTRD
    Scott
    AZ
    Ah, gotcha. I thought all the 4 bangers had 4.10s. I knew about the X-runners...hopefully I can sell my 3.73s to one of those guys lol
  14. Feb 25, 2013 at 1:01 AM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Haha.. Might I be that guy??
    Actually Digiratus (Mike) had his truck there, too.
    Worked it down to $2k.. And no tax since I'm an Alaskan. Sold my 4.10 third for $500, subtract that, too.
    Had to replace my collar seal on the ARB and new bearings in the front diff. Oh, and they swapped my 886s out for me too.
    I'd highly recommend either company; ECGS buys all of their gear sets from Nitro (Just Differentials/JTs).
    Stay far, far away from anything offered by 4Wheel Parts, it is absolute garbage. When it's all said and done, plan on spending about $1200/Axle. To do it the right way..
  15. Feb 25, 2013 at 1:19 AM
    #35
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    Dont do it yourself if you fuck up you wasting gears i have a friend that keeps doing it himself and goes through gears every 6-9 months.
  16. Feb 25, 2013 at 1:40 AM
    #36
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    +2... If you don't know what to buy to re-gear your truck, you probably
    shouldn't attempt setting up your own gears.
  17. Feb 25, 2013 at 3:05 AM
    #37
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    i'd never do it myself... that was kind of a cry for help in steering me in the right direction for parts.. :eek:
  18. Feb 25, 2013 at 7:01 AM
    #38
    BradyT88
    Mike was the guy I was referring to. Haha
  19. Feb 25, 2013 at 8:39 AM
    #39
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    As said, but so nobody gets confused reading this thread,
    5 lug auto is 3.3x
    5 lug manual is 3.10
    no 4:10 in second gen 5 lug 4 cyl
  20. Feb 25, 2013 at 8:43 AM
    #40
    BradyT88
    So 3.10 is the other gearing? I knew there was another one but couldn't remember what the hell it was. haha
