Re-gearing a 2020 Tacoma w/Auto
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 20PRO, Jun 9, 2020.
  1. Jun 9, 2020 at 9:47 AM
    20PRO
    20PRO [OP] Member
    Colorado
    2020 White Tacoma TRD PRO
    RCI Rock Sliders, Diamondback HD bedcover, 275/70 x 17 KO2 tires, Icon Alloys Vector 6 wheels. Prinsu can rack. Front Runner load bars on the bed cover.
    While waiting for my Tacoma to arrive I thought I’d ask if Toyota has done any work wrt the 2020 auto transmission constantly hunting for the right gear? Is re-gearing still required ? When I move to larger tires, 33’s, I expect to re-gear. Looking for information while it’s in stock form.
  2. Jun 9, 2020 at 9:54 AM
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    The (debatable) problem with hunting gears was more of a software issue than an actual gear ratio issue. It was since fixed in some software updates a few years ago, and anything coming out now should be fine. Also I think its a bit debatable whether you need to regear on 33's. I see most regear on 33's (and definitely 35's) who are also fully armored, carrying a bunch of weight, racks, gear, etc.
  3. Jun 9, 2020 at 9:54 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Welcome to TW! On other threads you could find that the ECU tune that dictates the shift points has been updated over time but those updates are not only for the 2020 MY only. The hardware (aka gearing) is also the same the 2016's and Toyotas updates are "very similar" in regards to shifting for all 3rd gens. I recommend considering OVTune which will only improve stock and re-gear needs. I am stock with OVTune (VFTuner) and kept stock tire size and it's SIGNIFICANTLY improved drivability and hunting. Adding a larger tire would certainly make the experience less enjoyable without that regear you have in mind. Enjoy your new rig!
  4. Jun 9, 2020 at 9:56 AM
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    I’m about to regear because I am adding a lot of weight to the truck. However, I haven’t had any issues with my 19 with 4K miles on stock tires and 14k on 265/75/16s. (Other than the occasional diff whine that was supposedly fixed lol). I’m also mostly on flat terrain.
    You probably won’t notice anything stock (I can’t speak to people’s experiences at higher elevations) unless you read TW posts about it every morning.
    welcome to Tw. Prepare thy wallet
  5. Jun 9, 2020 at 10:06 AM
    thesspirate
    thesspirate Member
    Patrick
    Lake Elsinore, CA
    2020 TRD OR
    My 2020 V6 doesn't hunt for the right gear like the older models. The only "issue" I have is when going up any sort of incline, the trans shifts back and forth between 4th and 5th gear. I solve this on my own by always driving in "S" and limiting it to 4th gear around town and going up hills. Once I get back to level ground, I'll bump it up to 5th or 6th and it drives just fine.
    As for re-gearing, I'm on 33s and the only difference I've noticed is a drop in acceleration from a dig. Other than that, the transmission acts the exact same as it did before I lifted it with bigger tires. If anything, I'll retune before I re-gear.
    My differential also whines like others have stated, but it doesn't bother me.
    bulalo likes this.
  6. Jun 9, 2020 at 10:08 AM
    thesspirate
    thesspirate Member
    Patrick
    Lake Elsinore, CA
    2020 TRD OR
    This is the truest thing I've read in a while lol
    71tattooguy likes this.
  7. Jun 9, 2020 at 10:11 AM
    CoTacos
    Steven
    Denver, CO
    My truck is fairly stock still, and I've already spent more in mods than my entire track set up for my previous mazda...sometimes I hate this truck. Other times I come off a trail thinking how else I will spend my money to beat on it harder. Makes absolutely zero sense lol
    AKGSD likes this.
  8. Jun 9, 2020 at 10:13 AM
    deuceb
    deuceb Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2004 MB SL55 | 86 VW GTI
    Hunting isn't a problem as others have stated, but it's still geared poorly from the factory.
  9. Jun 9, 2020 at 10:15 AM
    thesspirate
    thesspirate Member
    Patrick
    Lake Elsinore, CA
    2020 TRD OR
    I used to spend a stupid amount of money on Harleys, now I have a Tacoma and its just as bad lol I also have the same relationship with my truck, sometimes I'll hate it and want to sell it already. The very next day I'll fall in love with it all over again. It's just the way it goes!
    uploadadventure likes this.
  10. Jun 9, 2020 at 10:17 AM
    CoTacos
    Steven
    Denver, CO
    Yeah...I tell myself as long as I can afford it and I'm having fun, why not. Life is short, do cool things
    thesspirate[QUOTED] likes this.
  11. Jun 9, 2020 at 10:23 AM
    ClubSoda
    ClubSoda Well-Known Member
    Harry
    2018 Cement Tacoma TRD Off-Road
    I chose not to regear my truck with 33's since I'm not running steel bumpers or anything that really adds a lot of weight to the truck aside from the larger tires. Honestly, I'm not noticing a difference with how the truck shifts while driving since I've added my lift and tires. I feel like the automatic trans always had issues shifting to the correct gear, and even when my truck was stock, I found myself manually shifting up while driving on the highway.. I don't plan on going full armor and I think 33's are the perfect size for the truck. I'd first look into OVtune before I did anything with the gears.
  12. Jun 9, 2020 at 10:25 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Just curious, but what are you all paying for regearing?
  13. Jun 9, 2020 at 10:26 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Isn't that what gear hunting is?
  14. Jun 9, 2020 at 10:36 AM
    tacomaccountant
    Florida
    I was quoted $6,000 (parts and labor for all) for regearing to 4.88s, front and rear ARB lockers, and an arb dual compressor(and all necessary attachments for the lockers).
    the labor for the regear install was 750 per axle
  15. Jun 9, 2020 at 10:37 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    shhhhhhhhhh!!!!!!!
    the truck is perfect in every way!! How dare you!? ;)
    As people have mentioned, tune sounds like your best bet. Mine hunts too on long hills
  16. Jun 9, 2020 at 10:43 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Software is part of the issue but IMO the software updates are just masking the issue. The real issue is the engine doesn't have the low end power to pull the stock tall gearing. Toyota did this to get a high MPG rating for the window sticker but it hurts more than it helps in the real world.
  17. Jun 9, 2020 at 10:45 AM
    angerbot
    angerbot Well-Known Member
    Depends where you drive too, if you spend a lot of time at high altitude or in hilly terrain it becomes more worth it to regear. I'm running 4.88s with < 100lbs of extra weight and the extra RPMs have really cut down on highway shifting. The truck has a lot more get up and go with a reagear as well if you like a slightly sportier ride (it's still obviously a truck but it can pull a lot harder on freeway onramps and the like).
    20PRO[OP] likes this.
  18. Jun 9, 2020 at 10:51 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    Pretty much. Lol
    skidooboy and Skydvrr[QUOTED] like this.
  19. Jun 9, 2020 at 10:53 AM
    abodyjoe
    joe
    I agree. My all stock 2017 always acted like it was under geared. It's not like the mpg was all that good either.
  20. Jun 9, 2020 at 11:00 AM
    CoTacos
    Steven
    Denver, CO
    I agree it's not the best driving truck in terms of gearing, but IMO it's not too different from any other car I've driven or been in with a similar v6 powertrain. I just did 5500 ft to 11,000 ft pass climb this weekend to camp. Between a full bed, RTT, rack, water, coolers, and all the crap in my back seat, I'd say I'm hauling an extra 5-600 lbs had to hit ECT and ran the truck around 3500-5500 RPM's the entire climb...but hey its do-able lol.
    Edit: also my RTT is above the cab and a god damn wind sail so that doesn't help either...
    AKGSD likes this.
