Re gearing for 30” ko2s
Discussion in '5 Lug' started by 5luggin, Sep 26, 2020.
  1. Sep 26, 2020 at 10:53 AM
    5luggin
    5luggin [OP] Member
    2019 Tacoma SR 2.7 4x4
    Any input? I have the base 5 lug and have been reading that if I put 30” ko2s it will put a lot of ware and tear on the truck. Would re gearing the transmission help with the ware and tear? Any opinions? I just love the look of the ko2s. Any help is appreciated.
  2. Sep 29, 2020 at 4:15 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Im on 235s (29s) and my 5lug isnt bad, in fact im thinking of doing 31s for a lil bit before i regear; if i dont have a 6 lug rear to use by the time my current tires wear.
    Most ppl on here dont regear till they hit the 31s mark. Have u checked ur door sticker to see what gears u already have?
  3. Sep 29, 2020 at 1:42 PM
    5luggin
    5luggin [OP] Member
    Okay good to know. Thanks for the input. And no I haven’t checked but it’s a stock truck so I’m assuming that the trans would have the stock gearing. However it’s the base work truck and not the sr5 so that might make a difference?
  4. Sep 29, 2020 at 1:46 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Most people don't regear till they go up to 35's. You'll be more than fine with 30's.
  5. Sep 29, 2020 at 1:47 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    5 lug. Not 6 lug. Diff ball parks.
  6. Sep 29, 2020 at 1:48 PM
    Das it mang
    Az
    1996 T100 SR5 MT
  7. Sep 29, 2020 at 9:06 PM
    5luggin
    5luggin [OP] Member
    Thank you all. You guys are awesome!! I know it was a super noob question. I apologize haha.
  8. Sep 29, 2020 at 9:10 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    FYI - you don’t re year your transmission, you re gear your rear differential
  9. Sep 29, 2020 at 9:12 PM
    5luggin
    5luggin [OP] Member
    @Das it mang heres a pic of my vin. My vin starts with a 5 and not a 1 or 2. I’m a little confused.
    Das it mang likes this.
  10. Sep 29, 2020 at 9:13 PM
    5luggin
    5luggin [OP] Member
    @Das it mang ill read a little more into it when I get home.
  11. Sep 29, 2020 at 9:18 PM
    5luggin
    5luggin [OP] Member
    @Evenflow ohhhh okay. HAHAHA I was super bummed cause re gearing a tranny sounded expensive. Re gearing a rear diff sounds less costly. That’s some relief.
  12. Sep 29, 2020 at 9:22 PM
    5luggin
    5luggin [OP] Member
    @Das it mang wait, I just looked closer. It’s not the vin that I need to read it’s the a/tm and the following characters/numbers right? I have an automatic.
  13. Sep 29, 2020 at 9:30 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    You probbly have a 3 gear ratio, you can run kO2’s butnthe truck will be slightly sluggish and youll get worse gas mileage, and if you do regear for this setup youll mpg will take an even bigger hit
  14. Sep 29, 2020 at 9:35 PM
    5luggin
    5luggin [OP] Member
    @Tacoma1997White4x4
    Fersure. Speed isn’t all that important to me. I’m 26 and bought the truck cause I don’t want speeding tickets hahaha. The gas mileage part kinda sucks but if oh well. It’ll look a lot better than the 215’s that I have currently haha.
  15. Sep 29, 2020 at 9:36 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    A01A is urs. U have 3.42, 2 pinion open. U can do the 30s but eventually id regear with that.
    I have 3.58 with a MT which makes it easier for me
  16. Sep 29, 2020 at 9:44 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    30s arent near stock tire size for a 5 lug bruh. Chillout, hes asking honest questions and ur flying off the handle
  17. Sep 29, 2020 at 9:45 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    *you're. And you're right. After the debate tonight, I'm a little wired up. I'm gonna delete my post. My bad, and I apologize.
  18. Sep 29, 2020 at 9:46 PM
    5luggin
    5luggin [OP] Member
    @kairo im sorry that you feel this way. These and genuine questions and I really just don’t know. I’ve learned a lot so far. I always thought that re gearing had to do with the transmission. Is there anyway I can make myself more credible?
  19. Sep 29, 2020 at 9:51 PM
    5luggin
    5luggin [OP] Member
    @kairo okay, good to know thanks.
  20. Sep 29, 2020 at 10:26 PM
    5luggin
    5luggin [OP] Member
    @Das it mang okay I’ll look search the forum more in-depth to find out about re gearing the rear axel. Thanks for the help.
