Re-gearing my Tacoma......4.10 or 4.56?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Oct 25, 2017.
  1. Oct 25, 2017 at 1:47 PM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    NEED YOUR OPINION: Looking into investing in 33" all terrains tires for my Tacoma, If I do I'm going to re-gear. Which gear ring & pinion should I go with 4.10 or 4.56?
  2. Oct 25, 2017 at 1:49 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    I would go 4.56, might as well do it once.
    I'm running 4.56 in my 2006 with 32s and it is great
    dirtnsmores likes this.
  3. Oct 25, 2017 at 2:12 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    4.10 is what the calculation will give you but 4.56 is what most folks run and you'll be happy
  4. Oct 25, 2017 at 2:50 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    4.10 if you aren't going to do 35s (you'll have the wantsies later) and want to go 80MPH on the highway with decent RPMS
    4.56 if you don't care about highway speed or plan on DirtyFives in the nearish future.
    Either way get a locker front and rear while you have the diffs open.
    Kolter45, Trailbutter and JDawg562 like this.
  5. Oct 25, 2017 at 2:53 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    all of this!
    GreenSmartBike likes this.
  6. Oct 25, 2017 at 3:04 PM
    ilovericers
    ilovericers Member
    06 SR5 DCSB 4x4
    OME Nitrochargers front with 885's and Dakars rear, magnaflow 3" catback, AFE stage 2 Si, ARE Z series canopy w/ yakima load bars, OEM roof rails, UNIDEN CMX760, OEM running boards, Avid Offroad light bar
    I regeared to 4.10s after switching to 33s. gear ratio is back to stock, a tiny but overgeared but I think it's great. 4.56 could be better for more control off road but highway driving would have suffered too much for me. at 75 mph I'm at ~2200 rpm
    RigginsTaco and Arcticelf like this.
  7. Oct 25, 2017 at 3:09 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Think you might also want to consider how much weight your pushing around with those gears... If you are often fully loaded with camping gear, or towing a trailer, or just have a bunch of armor weighing you down 4.56 might be the better choice... I have 4.10s on 33'' and no complaints, just a little sluggish when im fully loaded, but to me the low highway rpms are nice as we have some 80mph speed limits here.
    TheDrMaSuess likes this.
  8. Oct 25, 2017 at 3:13 PM
    Arcticelf
    Gladiator
    I'm still on stock gears with 33s and no real complaints.
    I need to buck up and commit to Dirty Fives and then gear accordingly...
  9. Oct 25, 2017 at 3:26 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    What did you have before the 33"
    I've got 265/70/17 on now and going to 33" "pizza cutters" just wondering how much it'll affect speed/power
  10. Oct 25, 2017 at 3:32 PM
    PFD FIRE
    David
    San Diego
    I’m currently running 32’s with stock gears. No issues but if I go with 33’s I think 4.10 would be best all around for both street and off road use.
    My rig is heavy with a camper shell, high lift jack, power tank and recovery gear. But no steel bumpers, winch or steel under armor so with that said 4.10 might do the trick
    YamaDirtrider likes this.
  11. Oct 25, 2017 at 3:36 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    I've got front and mid steel skids, hidden winch with steel line, and rtt on when camping
  12. Oct 25, 2017 at 5:27 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I was in your shoes earlier this year. I'm running the BFG KO2 34/10.5/17 tires that measure out to exactly 33.25" in diameter. It was a PIG with stock gears. I noticed a huge difference immediately.
    Like someone above mentioned, when you have the gears apart, you should plan on doing lockers at the same time. The labor is the same either way so you might as well. I went with ARB air lockers front and rear and I couldn't be happier. The truck just doesn't get stuck. It's incredible.
    Also, I believe the perfect gear ratio is 4.30 but they don't make it for the front (they do for the rear). I decided to go with 4.56 gears due to weight when I pack up the truck with gear and also because in the future I MIGHT go with slightly larger tires. After putting about 5,000 miles on the truck with the new gears I can honestly say I'm glad I went with 4.56 gears.
  13. Oct 25, 2017 at 8:20 PM
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    Google tire size calculator
    If u going with 285/70/17(32.7" not trully 33" if they exist. then its only 3.5% error but if stock was 265/65/17 then it will be 7% error. I dont see what big deal is. If error is 7% then if u going 50mph on speedometer its only 53.5mph in real speed
  14. Oct 25, 2017 at 8:24 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    I'm running 32's and some armor, canopy etc. and I plan on regearing at some point (4.56.or 4.88) since the truck feels sluggish now compared to when it was bone stock.
  15. Oct 25, 2017 at 8:30 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    I got the truck with 265/70/17.
    The new tire's are 255/80/17
    Originally the stock size was probably 265/65/17
  16. Oct 26, 2017 at 5:09 PM
    acas
    acas Well-Known Member
    adam
    14 double cab short bed 6 speed manual!! save the manuals
    my truck is a 6 speed double cab short bed, it came with the 265/65/17 stock and i just put on 285/70/17 and not only was the speedo off 4mph but the truck feels like a dog. its maybe only a 7% difference but the added weight of the tires and the larger diameter really makes adifference. Im thinking about going with the 4.56 gears.
  17. Oct 26, 2017 at 5:23 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    They make 4.30's for the front now, that's what I'm eventually going with.
  18. Oct 26, 2017 at 5:49 PM
    Pigpen
    Dan
    Northwest Montana
    Nobody asked which transmission you have...fail. If you want slightly better (more torque) than stock go 4.10 for a manual trans and 4.30 for auto.
    4.10 will make it feel stock with the 6 speed.
    This is really the winning option. So glad I didn't pull the trigger on a regear when I went to 33s - the 4.30 wasn't available yet.
    blu92in99 likes this.
  19. Oct 26, 2017 at 5:54 PM
    acas
    adam
    do you know what my rpm at 80mph would be with the 4.56 gears??
  20. Oct 26, 2017 at 6:11 PM
    Pigpen
    Dan
    Northwest Montana
    With 33s?
    Pretty high
    I'm still on stock gears and I'm climbing close to 3k rpms at 80 with 33s. You can almost see the gas gauge dropping.
    Redsyota likes this.
