Re-gearing my Tacoma......4.10 or 4.56?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Oct 25, 2017.
  1. Oct 26, 2017 at 6:17 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    lol I was just about to ask that! I have automatic with 4.56 with 35s. It's my daily driver and I drive on the freeway for about 20mins to work(with no traffic).
  2. Oct 26, 2017 at 6:22 PM
    acas
    acas Well-Known Member
    adam
    14 double cab short bed 6 speed manual!! save the manuals
    see i have 33s on it now and the rpm is like 2600 ish at 80.. stock tires i was at like 2850 rpm at 80 mph, remember i have a manual trans. i dont wanna spend the money on 4.10s and have the truck still feel sluggish, id like a little pep and get up and go, i also came from a sti and a evo so they were freaking fast cars.
  3. Oct 26, 2017 at 6:25 PM
    Pigpen
    Dan
    Northwest Montana
    I'm on 33s and a manual trans also.
  4. Oct 26, 2017 at 6:27 PM
    acas
    adam
    your truck had 3.73 gears stock? and what gears are you running now? i forgot what you said
  5. Oct 26, 2017 at 6:28 PM
    Pigpen
    Dan
    Northwest Montana
    stock
    no regear yet
  6. Oct 26, 2017 at 6:30 PM
    Pigpen
    Dan
    Northwest Montana
    4.10 has been my plan. 4.30 is sounding like a good option.
  7. Oct 26, 2017 at 6:34 PM
    acas
    adam
    do they make 4.30 for the tacomas yet? if they do then ill go with them, i dont think the 4.10s will be what i want and i think the 4.56 may be just a tad to high.
  8. Oct 26, 2017 at 8:58 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, some great responses above to be sure. You may also want to try this calculator as it will tell you a lot about how many RPMs/speed you will be running using various tire sizes, gear ratios, etc.
    http://www.grimmjeeper.com/gears.html
    Arcticelf likes this.
  9. Oct 26, 2017 at 9:58 PM
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I called East Coast Gear Supply (ECGS) today and the rep tells me that they don’t make 4.30 for the front diff on the Tacoma’s.
    I’m probably going to stick with 32’s go with an E rated all terrain tire and re-gear 4.10
    Pigpen likes this.
  10. Oct 26, 2017 at 10:19 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    There are OEM gears from Toyota in 4.30. The third generation Tacomas from 2016+ have that ratio if they are configured both V6 and manual transmission. The front diff is interchangeable with the second generation; the rear diff itself is not but the whole axle (with the diff in it) do bolt right up to the second gen trucks so that's an option. But also for the rear you can use the 4.30 diff from the first generation tundras. Those diffs will fit into the second gen Tacoma axle housing as well unless you have a TRD off-road in which case this won't work for you unless you swap to the whole axle assembly from a third gen TRD off-road but good luck finding that yet
  11. Oct 26, 2017 at 11:26 PM
    PFD FIRE
    David
    San Diego
    Anybody have an opinion using 4.10 on a 32” E rated tire?
  12. Oct 27, 2017 at 1:57 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    What? I swore I read it on here and then confirmed it myself on their website. Maybe I'm losing my mind.
  13. Oct 27, 2017 at 6:41 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    @fatfurious2 can talk about it.
    Something something MPGLOL, was the summary I think.
    acas[QUOTED] and fatfurious2 like this.
  14. Oct 27, 2017 at 6:43 AM
    Arcticelf
    Gladiator
    Now I just need to find a totaled 3rd gen and buy the front diff.....
  15. Oct 27, 2017 at 7:18 AM
    #35
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    That's pretty much what you'll have to do. As I stated earlier in this thread, I wanted 4.30 earlier this year but didn't do it because they do not make a 4.30 for the front diff. Now, if the 3rd gen has that ratio that's pretty cool (and a great option). 4.30 would honestly be the ultimate sweet spot for 33-35" tires.
    Arcticelf[QUOTED] likes this.
  16. Oct 27, 2017 at 7:21 AM
    #36
    Arcticelf
    Gladiator
    If they make that ratio for the 3rd gen the used gears should start showing up on the secondary market too, as people re-gear those trucks.
  17. Oct 27, 2017 at 7:27 AM
    #37
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Haha. I have 33s E rated ST Maxx, 4.56s, but now Im also supercharged. I am heading out for a trip, so I’ll try to get the rpms. But I rarely go 80. Only if some dragons are chasing me becti killed their babies
    PFD FIRE[OP] likes this.
  18. Oct 27, 2017 at 8:30 AM
    #38
    TireFire
    Olympic Peninsula
    Actually there's a drop in option for second gen TRD off-road in 4.30 that doesn't require a whole axle swap. Certain years of 4Runner have that ratio and the elocker so there ya go
  19. Oct 27, 2017 at 8:42 AM
    #39
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Pretty sure Yukon makes a 4.30 for the front for second gens?
  20. Oct 27, 2017 at 11:27 AM
    #40
    StealthMedia
    StealthMedia Well-Known Member
    Nick
    Thousand Oaks, CA
    2014 Silver Sky TRD Sport DCLB
    Subbed. Eventually getting 265/70/r17 KO2's for KO2's/Toyo RT's in 285/70/r17 so I may need to re-gear (definitely if I get the RT's as tire weight is 64lbs and they're true 33's). I need to go check what my factory gear ratio is first though
