Re-gearing my Tacoma......4.10 or 4.56?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Oct 25, 2017.
  1. Oct 30, 2017 at 9:01 AM
    #61
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Didn't know 4.30's were available now... that would be awesome for a 2nd gen 6speed on 35's...
    The 4.56's work very well for wheeling, the issue is the Hwy RPM's. They just take you a bit too high and for long distances and it is indeed bothersome. (at least for me)
    I'd consider 4.30's to be the perfect ratio for my application. 4.10's being the only other ratio available I believed they would work well for me due to the crawlbox mod - without that 4.10's would suck for wheeling.
    PFD FIRE[OP] likes this.
  2. Oct 30, 2017 at 9:52 AM
    #62
    PFD FIRE
    PFD FIRE [OP] Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    Just talked to a tech at ECGS and he did confirm that they do make a 4.30 for 2nd gen Tacoma’s but advised me not to waste my money with the 4.30 and go with a 4.56 regardless if I go with a 32” or 33” E rated tire.
    I have to say I was a little surprised I thought for sure he was going to say 4.30 was the sweet spot but instead recommended 4.56.
    Any opinions out there?
  3. Oct 30, 2017 at 1:11 PM
    #63
    Pigpen
    Dan
    Northwest Montana
    For an auto trans maybe. I'll probably still go with 4.10 for mine. I drive a lot of long distances and have a 45 min commute to work. I just want back what I lost going to 33s. This is my DD
  4. Oct 30, 2017 at 1:12 PM
    #64
    Pigpen
    Dan
    Northwest Montana
    Homer just said RPMs are too high on the highway with 35s and 4.56 gears. How do you think it's going to be with 32s?
  5. Oct 30, 2017 at 1:16 PM
    #65
    Pigpen
    Dan
    Northwest Montana
    And I won't be doing any regearing until I'm ready to put in lockers. My truck is heavy and I tow frequently in the mountains. It still works fine. It's a bit more of a dog than I'd like, but certainly tolerable.
  6. Oct 30, 2017 at 1:23 PM
    #66
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Keep in mind, manuals will turn higher RPM due to the higher final drive ratio.
  7. Oct 30, 2017 at 1:25 PM
    #67
    StealthMedia
    StealthMedia Well-Known Member
    Nick
    Thousand Oaks, CA
    2014 Silver Sky TRD Sport DCLB
    Usually I'm in the 75-85 range @2200-2500ish hahaha!
    Yeah it actually probably is too low. It's kinda of weird that t's so low considering that my tires are only an inch or so bigger than stock, and only weigh 45lbs (C-load KO2's). I would rather be geared slightly too high than too low though once I have my new suspension/tire setup by next summer, because I do ALOT of highway driving above 75mph and that's not going to change. So, I will probably end up with 4.10
  8. Oct 30, 2017 at 1:31 PM
    #68
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Correct
  9. Oct 30, 2017 at 1:40 PM
    #69
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    I recently installed ECGS 4.56 on my 2012 auto with 33s. I love them.
    5th gear: 2575rpm at 75mph (not towing, converter locked)
    5th gear: 2432rpm at 65mph (not towing, converter locked)
    4th gear: 3446rpm at 70mph (towing 2000lb trailer, converter locked)
    I don't think 4.10s would be enough, 4.88s a bit steep maybe. I should have done it sooner, it's so much more enjoyable to drive. The biggest difference is the transmission doesn't downshift at the slightest stupid incline and the converter just stays locked. It pulls like a train. The whole truck just feels...grateful.
    SLeeper512 and 617mike9c1 like this.
  10. Oct 30, 2017 at 2:29 PM
    #70
    Castle
    Castle Well-Known Member
    SF Bay Area
    2012 DCLB SR5
    Bumpers,lockers, gears, lift...
    I have the same setup and agree how much smoother the truck is. The truck can handle hills again without the transmission getting crazy.
    SLeeper512 likes this.
  11. Oct 30, 2017 at 2:29 PM
    #71
    PFD FIRE
    David
    San Diego
  12. Oct 30, 2017 at 10:23 PM
    #72
    StealthMedia
    Nick
    Thousand Oaks, CA
    I feel the same
    Hmm
  13. Nov 1, 2017 at 8:07 PM
    #73
    CooleyOne
    CooleyOne TRD OffRoad
    EastBay, NorCal
    2017 TRD OffRoad Taco
    2017 TRD OffRoad
    Just wanted to throw this out there that the 3.5L V6 AT, 3rd Gen is a 3.909 Diff.
  14. Nov 2, 2017 at 8:00 PM
    #74
    StealthMedia
    Nick
    Thousand Oaks, CA
    Anyone know what underdrive doubler Tacomas have? I haven't found it using google
  15. Nov 6, 2017 at 2:30 PM
    #75
    renval
    renval Well-Known Member
    Renz
    SoCal
    Im glad i waited on my purchase, i was getting 4.56 from ECGS for my TRD OR 4x4 6speed manual trans, i just found out they now have 4.30 gears front and rear, i think this gear ration is perfect for 33s or 35s with manual trans. what do you guys think?
  16. Nov 6, 2017 at 4:35 PM
    #76
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    4.30 for 33s (255/85/16) on the V6 AT are my plan.
  17. Nov 7, 2017 at 8:35 AM
    #77
    SLeeper512
    SLeeper512 Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    This is my plan too. A few weeks ago made the appointment with ECG to regear to 4.56 (they made no mention of 4.3). They pointed out that the 4.56 would only be 300 extra rpm over the 4.10... running 265/75/16 tires.
    I will be towing a very light trailer, approx 3500# fully loaded, mostly out west in mountains.
    However, may switch to a heavier trailer, approx 5000#, after a bit.
    How heavy are your trailers?
    Thanks
  18. Nov 7, 2017 at 1:53 PM
    #78
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    My trailer is about 5,000 to 5,500 lbs loaded. Stock gearing and 265/75/16. I'm 90% sure I'll be regearing before going up to 255s.
    SLeeper512[QUOTED] likes this.
  19. Nov 7, 2017 at 1:59 PM
    #79
    SLeeper512
    Sam
    I believe you also have a supercharger :) giving you a lot of low end torque.
  20. Nov 10, 2017 at 8:59 AM
    #80
    PFD FIRE
    David
    San Diego
    If I go with a 265/75/16 heavier tire (Coopper STT Pro) I’ll probably regear to 4.30. I don’t haul a trailer but I do carry lots of gear and passengers when I go off roading :)
