re gearing with 6"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdnbanker, Apr 7, 2009.
  1. Apr 7, 2009 at 8:06 PM
    cdnbanker
    cdnbanker [OP] Well-Known Member
    how important is regearing with a 6" lift
    what is the power gain / mpg gain
    worth the $400ish per axel - $1200 say for a 4x4
  2. Apr 7, 2009 at 8:31 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    what size tires are u running
    and what kinda gears u got in it already?
  3. Apr 7, 2009 at 8:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I regear anytime I increase tire size over 10%. Usually brings my mpg back in line with stock.
  4. Apr 7, 2009 at 8:40 PM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    power gain... almost none... mpg gain... almost none...
    you lift your truck and slam it on huge tires with stock gears... you risk grenading a trans and your entire driveline... is it worth it? you answer that.. would you rather pay 1200 in gearing or 4k for a new trans and driveline because you wanted to be a moron and half ass a truck? you tell us.
    when you regear, you are just relieveing that stress and bringing it back up to a almost stock situation... which is what the truck was designed for.
  5. Apr 7, 2009 at 10:15 PM
    cdnbanker
    just trying to price out a 6" lift, do it properly the first time ...
    guess ill have to add gears to the rest of the list
    its gonna be liek $10k to raise this bitch up
  6. Apr 7, 2009 at 10:37 PM
    ShtrMcGavin
    ShtrMcGavin Well-Known Member
    Bryan
    Tempe, AZ
    Silver 05 DBL Cab LB 4x4
    3" Lift, spidertrax 1.25" spacers all around
    I know this has been asked in a few other places but KROOKS your truck looks to have a similar lift to one Im looking at with a 6" lift and 35"s do you know how tall your truck is? Im trying to figure out if it would fit in the garage and in the parking structure at work
  7. Apr 8, 2009 at 4:22 AM
    cmfranks
    cmfranks Well-Known Member
    Craig
    Austin,TX
    08 DC Pre-Runner 6in Pro Comp Lift
    BHLM, Pro Comp Skid Plate, AFE Drop in Air Filter, Tint, Pioneer AVH 4000 DVD,Polk Audio 6.5 components, Polk 6.5 co-ax's, Polk Audio 400.1 amp, Polk Audio 500.1 amp, (2) Polk Audio 10 in Momo subs, Mr Marv sub box, Sockmonkey decals, Redline Elite hood struts, Bak Flip tonneau cover, N-Fab Nerf bars, Painted Center Console & Window/Door Lock Panels Black, Amber LED Dome/Map Lights
    I went ahead (awhile back) and re-geared even after researching the shit out of this topic. Many said ya or na. I have the 6 in lift and 33x12.50x18's, I did notice a diffrence (more power) in the take off as well at speeds more so on the hwy. As far as the MPG's, at first I didn't really see a change but now that my truck just hit 10k miles I avg about 16 mpg. BTW, I re-geared to 4.10's
    Hope this helps :wave:
  8. Apr 8, 2009 at 4:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In our trucks, 4:10's are the perfect gearing for 33's. :)
  9. Apr 8, 2009 at 6:36 AM
    cdnbanker
    good discussion guys, thanks for the insight
  10. Apr 8, 2009 at 5:08 PM
    cmfranks
    Craig
    Austin,TX
    I thought 4:30's were actually the best for 33's, although you cant find them anywhere ?????
    I'm happy w/ the 4:10's though
  11. Apr 8, 2009 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, your right, but good luck finding them.
  12. Apr 9, 2009 at 9:32 AM
    ShtrMcGavin
    Bryan
    Tempe, AZ
    What kind of gas mileage are you getting with 4:10's?
  13. Apr 9, 2009 at 10:19 AM
    cmfranks
    Craig
    Austin,TX
    Around 16 mpg. Mostly all city driving.
  14. Apr 9, 2009 at 7:55 PM
    allupinsydeyou
    so cal / vegas
    arrgggg!!! people that dont read into it piss me off... you all need to listen... ive been doin this for a long damn time and there is a reason that they make higher gear sets! you add that much more rotating mass to a vehicle and you start straining your driveline. normally if you have a truck stock on 28's through 31's, then you can step up to a 33 and you will notice if your driving stick you have to feather the clutch a bit longer on beginning take off... thats because upon stepping up... you have decreased the amount of torque to rotating mass. same amount of torque as your stock 28 or 31 to something 2 inches bigger around... may not seem like much to you... but people like the people on here sayin to throw it on 35's and leaveit stock, your the reason i make so much damn money as a mechanic.
    when you destroy your driveline... you come to people like me because you didnt listen to the mechanincs that are warning you of what will happen if you dont do it right. you ever hear the motto do it right the first time so you dont have to go back and do it again later? this is esp. where that applies. or... go for it.. and be sure to pm me when you break your shit and ill be more than happy to give you a tacomaworld discount at my shop while im replacing your trans and driveline.
    nick
