Re-gearing
Discussion in '5 Lug' started by 5LUGTACO, Mar 2, 2011.
  1. Mar 2, 2011 at 11:12 PM
    5LUGTACO
    5LUGTACO [OP] Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Ok so i know a lot of guys have re-geared their five lug tacoma's what i want to know is what brand you ended up going with why and how much. Also what gear ratio and what size tires are you running?
    Thank you
  2. Mar 2, 2011 at 11:33 PM
    MadTaco461
    MadTaco461 Jack May Hoffer
    Murrieta, CA
    99 turbo 5 lug long travel
    Kinda stock
    I just found an used axle and threw it in there. I think they are Yukon's. I'm 4.56 with 32" tires. I'm going 10 mph slower than what my truck actually says at high speeds. I want to change my gears again soon for more torque and found gears for $200 and quoted $300 for install.
  3. Mar 5, 2011 at 5:57 AM
    bills yota 2wpeel
    bills yota 2wpeel Active Member
    Bill
    Haddam CT
    08' tacoma 5 lug silver
    Ready lift 5 lug 2.75 suspension, custom built 1.75 body lift, Nitto Grappler A/T 265/70R16, AR Tactic Wheels 16x8 4.97bs, AFE pro dry cai, ARB RD129 rear locker 4.10 gears, lc engineering header
    I found a complete 3rd member with factory 4.10 gears and bolted it in there. that is stock gearing for the 5sp 4wd or prerunner with a 4 cyl. I have 265/70 r16 tires same as a 4wd. I like it.
  4. Mar 5, 2011 at 12:12 PM
    5LUGTACO
    David
    California
    06 TACOMA 5 LUG
    Did you get the third member from a 2005 + tacoma? Also what other models are out there that have 4.10 gears? that can be used for he five lug tacomas?
  5. Mar 5, 2011 at 9:01 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    How much did the complete 3rd member run you?
  6. Mar 5, 2011 at 11:32 PM
    MadTaco461
    Murrieta, CA
    Kinda stock
    http://home.4x4wire.com/erik/diffs/
    I use this as a reference, but for a 05+ 5 lug it's pretty hard to a third with gears. 5 lugs are an 8" diff for the +05, and non locked 6lug are 8.4" diff and aren't interchangeable with 8". You share the same gears as the e-locker tacomas. I'm not sure if an e locker third will bolt into your diff.
    This is if you want to stay with the 5 lug rim in the rear.
  7. Mar 6, 2011 at 7:48 AM
    bills yota 2wpeel
    Bill
    Haddam CT
    My third came from a '96 tacoma 4x4 non trd 4.10, there is alot of conflicting info about these rear ends but as I understand...
    -All 4wd/prerunner non trd e-locker 96up tacomas have the 8.4 rear diff.
    -At least 05up 2wd 5lug tacomas have the 8.4. Maybe '03, '04 too?
    -T100 pickups all years.
    -Tundras '01-'06
    I think at least the '96up 4cyl manual trans 4wd, prerunners had 4.10 gears, the ring gear will have the ratio etched into it, or you could just spin the tires up on jackstands.
    The one problem I had with the '96 third going into an '08 was the pinion flange had a different bolt pattern so I had to swap them
  8. Mar 6, 2011 at 7:56 AM
    bills yota 2wpeel
    Bill
    Haddam CT
    I disagree, I thought 05up 5lugs and 6lugs (non elocker), were the same. I hear it called 8.4 although the ring gear actually only measures 8" in diameter. The e-lockers were 8" but its a different setup I thought?
  9. Mar 6, 2011 at 7:59 AM
    bills yota 2wpeel
    Bill
    Haddam CT
    I paid $175 shipped, the guy said it had 150,000 miles.
  10. Mar 6, 2011 at 10:03 AM
    MadTaco461
    Murrieta, CA
    Kinda stock
    Sorry about that :eek:. Yes the 05+ 5 lugs are 8.4" not 8". I responded to that a little too late at night.
  11. Mar 6, 2011 at 1:12 PM
    5LUGTACO
    David
    California
    06 TACOMA 5 LUG
    Does anyone know if i can swap in a third member from a tacoma with a trd e-locker?
  12. Mar 6, 2011 at 11:19 PM
    MadTaco461
    Murrieta, CA
    Kinda stock
    Nope non locking and e-lockers can't switch. If looking for a locker most people go for limited slip. You can find good used 8.4" thirds for around $200-250. Place a wanted add on a few of the desert forums when ready to buy one.
  13. Mar 7, 2011 at 12:32 PM
    5LUGTACO
    David
    California
    06 TACOMA 5 LUG
    Ok lets say i found a tacoma rear axle complete with a locker from an 05 + tacoma. Could i just slide in my axles to keep the 5 lug pattern? Or do they have a different spline count and im guessing since the lockers are 8" they would be a little shorter than the 5 lug 8.4" ??? Or is the 8.4 referring to the size of the diff?
  14. Mar 7, 2011 at 4:37 PM
    05RedTaco
    Tony
    Scottsdale
    Thats a steal :eek:
  15. Mar 7, 2011 at 7:43 PM
    MadTaco461
    Murrieta, CA
    Kinda stock
    I though you were looking to re-gear? But wms to wms(wheel mounting surface) is the same. I believe both splines match up so you can run your axles. If you are looking for a deal stay away from the elockers. You'd have to buy gears because 4.10s aren't stock in elockers and need to buy a stand alone kit to make the locker work $150.
  16. Mar 7, 2011 at 9:54 PM
    5LUGTACO
    David
    California
    06 TACOMA 5 LUG
    Ok so it would be cheaper to just buy gears and a locker than? I was thinking if I could find a complete axle and just install that would be so easy but guess there's nothing out there then to do that with 4.10 gears huh?
  17. Mar 8, 2011 at 4:29 PM
    MadTaco461
    Murrieta, CA
    Kinda stock
    I'd place a wanted add on dezertrangers, racedezert, or ttora. Make sure you are specific about what you want. A whole bunch of people emailed me when I was looking for a new axle. I got a pretty good deal on my axle. Mine is fully trussed with 4.56, and lsd with only 500 miles on it since last rebuild and gears for $500 and I'm still 5 lug. Not sure where you are located but all this stuff is in CA. Other forums like pirate4x4 is more state wide.
