Re-gearing
Discussion in 'Performance and Tuning' started by Black Betty, Nov 1, 2008.
  1. Nov 1, 2008 at 1:25 PM
    Black Betty
    Black Betty [OP] Member
    Vancouver, Wa
    Her name is Black Betty
    Too many, I will add it later...
    So has anyone heard anything about regearing? Since 2006 I’ve been calling The 4 Wheel Drive Store every other month asking if it’s available yet. First they said it wasn’t available…then they said it, was but just for a short amount that was already sold out… they then said that they are fixing the bugs and that the 2nd batch isn‘t available yet. What’s the deal! They did say it will cost around $1,700 with install. Does any of this sound familiar?
  2. Nov 1, 2008 at 1:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Wow expensive. I haven't actually noticed anyone on here that has actually regeared.
  3. Nov 1, 2008 at 1:38 PM
    Black Betty
    Vancouver, Wa
    I know, and I keep getting the run around on the topic. It can't be good for my truck to have 6” lift with 35’s and not re-geared, I already have 40k on her!
  4. Nov 1, 2008 at 2:04 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    How does it feel? Do you do your correction for tires size when you figure fuel mileage? I have 3" lift with 33s and its hardly noticable. If your truck came with 3.73 gears then it will be responding like you have 3.26 gears right now. What are you looking to install some 4.10s maybe? Do you plan on installing them by youreslf? What kinda trouble are they giving you, shouldn't be hard to find some 4.10 or even 4.56 gears for your truck, then a shop or yourself to install.
  5. Nov 1, 2008 at 3:21 PM
    Black Betty
    Vancouver, Wa
    I was told that the gearing for the back are the same as all Toyota trucks. The front are different and were still under development. I wouldn’t want to do it myself, too many things that could go wrong. Yeah I had the 3" lift with 33’s when I first got my truck, I had to go bigger. You might be okay for a while. I know I need new gearing, it feel sluggish when I drive off the line…like I taking off in 2nd gear. I’m not a 100% sure what gearing I’m would put in, I’m thinking maybe 4.88’s.
  6. Nov 1, 2008 at 3:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I'll also do some looking into the front diff as I never heard of them being special. We'll see i'll get back with you.
  7. Nov 1, 2008 at 3:36 PM
    Black Betty
    Vancouver, Wa
    Thanks!
  8. Nov 1, 2008 at 4:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A good rule of thumb for the price of re-gearing is $500 to $600.00 per axel installed. My last re-gear cost me $1150.00 OTD. Any more than $1200.00 and I think you are getting screwed. my $0.02 :)
  9. Nov 1, 2008 at 4:56 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Chris did you regear this truck? If so did you experience any special troubles with your front end, as the OP has mentioned he is being told by the shops or dealers?
  10. Nov 1, 2008 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent re geared my Tacoma......yet. Also, remember I have no front diff. BUT, The second gen Tacomas have the same 7.5" front diff as the old ones. Im not aware of any changes that would prohibit a gear change. :confused:
  11. Nov 1, 2008 at 5:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I forgot you were a 2x4. I was remember the mall parking. Thats the same thing Tacozilla said. Thanks.
  12. Nov 1, 2008 at 5:04 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Not sure on prices either, but here is a great link. Check out TTORA, & Custom Taco for some good info:
    http://www.justdifferentials.com/
    Oh, if you got your quote from 4 Wheel Parts, screw them, they smoke too much crack...
  13. Nov 1, 2008 at 5:05 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^^ I agree 1000% ^^^
  14. Nov 1, 2008 at 5:27 PM
    Black Betty
    Vancouver, Wa
    Right on dude, I will look into it further. For my sake I hope so.
  15. Nov 2, 2008 at 1:56 AM
    Black Betty
    Vancouver, Wa
    Until then, is there anyone on here who has 05+ Tacoma with oversize tires that has re-geared??? I haven’t heard of any…
  16. Nov 4, 2008 at 4:40 AM
    cmfranks
    cmfranks Well-Known Member
    Craig
    Austin,TX
    08 DC Pre-Runner 6in Pro Comp Lift
    BHLM, Pro Comp Skid Plate, AFE Drop in Air Filter, Tint, Pioneer AVH 4000 DVD,Polk Audio 6.5 components, Polk 6.5 co-ax's, Polk Audio 400.1 amp, Polk Audio 500.1 amp, (2) Polk Audio 10 in Momo subs, Mr Marv sub box, Sockmonkey decals, Redline Elite hood struts, Bak Flip tonneau cover, N-Fab Nerf bars, Painted Center Console & Window/Door Lock Panels Black, Amber LED Dome/Map Lights
    I have re-geared my 08 prerunner. After the 6in lift w/ 33's i noticed the take off was pretty sluggish and of course the MPG sucked. 4wp's did mine out the door for $700 (or close too) and i really noticed a huge diffrence in the take off as well better performance at highway speeds. As for the MPG's, was getting 15 before, now about 17-18. Not a big diffrence in the MPG's, but it did help some. No other engine mods done yet. Went w/ 4:10's
  17. Nov 4, 2008 at 4:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good info! 4:10's I figured would be a good match with 33's. :)
  18. Nov 4, 2008 at 5:53 AM
    Black Betty
    Vancouver, Wa
    That is good info dude, Thanks! I bet it did help. You have a prerunner huh, does that mean you didn’t change your front gearing then?
    I have been looking around for a place that will re-gear back and front, I might have found a place that has them, not a 100% sure until I get them.
  19. Nov 4, 2008 at 6:27 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Thats correct the prerunner is 2x4, no front diff. to regear. That was done for a pretty good price.
  20. Jun 30, 2012 at 1:43 AM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    I've seen a lot of guys here were saying 4.10 is good to regear...obviously not
    unless you're running on stock tires. 4.10 can't handle 33" no matter what brands your tires are. 4.88 is a perfect match for 33" and 5.29 is great for 35 and up to 44. Why? been there and done that!
    anyone planning to regear? get a bigger gear 'cause most of us here are riding on bigger tires. thumps up for owning a toco!:burnrubber:one more thing, average for regearing is $700-$1300 depending on what kind of truck you got.
