Re-gearing??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, May 30, 2013.
  1. May 30, 2013 at 8:38 AM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I am running 265 70 17's Toyo Open Country ATII's and have lost about 2mpg. I am not complaining, but just more so curious what gears I should go with if I decide to go that route. I will be lifting it to 3" w new UCA's and 285's at some point in time.
    All opinions and info would be greatly appreciated as to my setup now with new gears and the benefits as well as my future 3" setup.
    Also, what gears are stock on my 2010 Sport DCSB?
    Thanks
  2. May 30, 2013 at 10:15 AM
    aubi1414
    Justin
    Pensacola, FL
    Nobody has any info? Also im good with a wrench is this do able myself if I can find instructions on how to take everything apart? Also, what would it cost to do this project?
  3. May 30, 2013 at 10:20 AM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    Your truck should come with 3:73 gear ratio, I believe they only sell 4:56 aftermarket. As for doing it yourself it depends but it isn't something many people do on their own because if it isn't properly installed you can have lots of issues which can cost more $$$
  4. May 30, 2013 at 10:22 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Call up East Coast Gear Supply. Great prices and good customer service. They'll get you straightened out. Although I'm not sure a rehear is going to make that much of a difference for you in MPG. Especially if you do a lot of highway miles.
  5. May 30, 2013 at 10:23 AM
    aubi1414
    Justin
    Pensacola, FL
    Wow wouldn't have thought the gears jumped that high from a 3:73 to a 4:56. Yeah I was debated on doing it myself or professionally but if I can find some good detailed instructions I feel like I could do it as long as its just normal tools I can buy and nothing major I have to do.
  6. May 30, 2013 at 10:24 AM
    aubi1414
    Justin
    Pensacola, FL
    Gotcha yeah mainly city driving and highway. Just thought I could spend more money and help out the MPG :D
  7. May 30, 2013 at 10:26 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    If you buy complete 3rds from a vendor like East Coast Gear Supply, a competent wrench can swap them out in a day. Otherwise, you're looking at getting some specialized equipment and facing the learning curve of setting up the preload and backlash of a set of gears. A worthwhile endeavor if you are really into wrenching but not so much for the bolt-on type modder.
    In your MPG calculations, are you accounting for the change in circumference of the tire? Bigger tire means you travel farther for the same number of rotations.
    One other option would be to pull 3rds from a manual version of your truck. Not sure on 2nd Gens, might be geared for 4.10 (which the 1st Gens are) which would be closer to what you want.
  8. May 30, 2013 at 10:50 AM
    aubi1414
    Justin
    Pensacola, FL
    My MPG difference from stock to new tires is only 1.03, so maybe 9-12 miles more per fill up. Still an AVG 2 MPG drop from what I was getting even when I try to drive conservative. I guess the weight of the wheels and tires has something to do with it too. So probably not worth changing out gears unless I jump to a 285 tire.
  9. May 30, 2013 at 10:56 AM
    Manwithoutaplan
    ID
    I would highly suggest if you never done it get it done by professional.
  10. May 30, 2013 at 11:01 AM
    aubi1414
    Justin
    Pensacola, FL
    Thanks and I just checked the weight of my new wheels/tire combo v my old wheels/tire combo and its exactly the same?? Why is my MPG off so much. I was getting 330 a tank now lucky to get 280
    New wheels 23lbs old 28lbs. Old tires 36lbs New tires 40.8 lbs
    Old = 256lbs total
    New= 255.2lbs total
  11. May 30, 2013 at 11:05 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    All 6 lug 2nd Gen Tacoma's are 3.73 auto or manual.
  12. May 30, 2013 at 11:15 AM
    tomtom
    The Desert SW
    2012 FJ
    that is the el sucko. :(
  13. May 30, 2013 at 11:16 AM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Not worth the effort or expense to go from 3.73 to 4.10 ratios. If / when you go to the 285 tires you will really need to regear and then go to 4.56. You did good buying those lightweight wheels! I am running 265/75R16 duratracs and stock 3.73 gears. Truck is a 5-speed auto trans. I get 16.8mpg highway/city combined, doubt there is much I can do to improve this except drive more like an old lady (already have it dialed back...)
  14. May 30, 2013 at 11:25 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    waste of money
    search more
  15. May 30, 2013 at 11:26 AM
    tomtom
    The Desert SW
    2012 FJ
    This.
  16. May 30, 2013 at 11:33 AM
    aubi1414
    Justin
    Pensacola, FL
    Still curious as to why my MPG dropped so much with no weight change and very little in Tire size?? Cool and thx all Ill save my money till the larger tires go on.
  17. May 30, 2013 at 12:09 PM
    pyrobobd
    pyrobobd Active Member
    Bob
    Southeast Colorado
    '07 basic truck
    Variable speed wiper switch
    FWIW, my 2007, 5 speed manual has 4.10 rear (and front) gears.
    Bob
  18. May 30, 2013 at 12:20 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    You need to account for the larger diameter of your new tires in the equation, as previously stated.
    Your odometer now has an X% of inaccuracy which is directly related to the percentage in diameter you increased.
    Simply put, a mile registered is not a mile traveled according to you stock odo. Same goes for your mph, from the factory, they read ~3% slow, mph registered should now be correct.
    All off the above is moot if you're using GPS measurements
    Interesting enough, a 265/75/16 or 265/70/17 is ~3% larger than stock...this puts your mph dead on correct and your odo about 3% short of actual miles traveled using stock instrumentation
  19. May 30, 2013 at 12:29 PM
    jmg256
    Al Tonter
    TRD Offroad
    To add...if you spend the bulk of your time on the highway, you might actually see an increase in mileage as you've effectively made your gear set 'taller'...that is if you can adjust your math to be correct.
    Edit to add: both my above posts assume stock gearing
  20. May 30, 2013 at 12:30 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Your ratio is actually going the wrong way. Going from 3.73 to 4.10 will reduce your mileage. If you are looking to increase you would want to go to 3.55, but this will cost you on low end torque, especially on the trail at low speeds.
