Re-gearing??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, May 30, 2013.
  1. May 30, 2013 at 12:41 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Depends on driving needs. If it is highway speeds, sure. If it is a lot of stop'n'go, not so much. Having the engine fight against not having enough torque doesn't do good for MPG either.
  2. May 30, 2013 at 3:06 PM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I did my calculation in the difference of revolutions per the calculator on the website and it is as stated a 1.03 difference so 3% but that only added like 10 miles per tank when I was getting 330 v 290??
  3. May 30, 2013 at 3:18 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Are you mostly a stop and go driver?
    As mentioned, you now need more "umph" to get going...while cruising at speed is now easier on the rpms. That extra little bit to overcome being stopped is magnified with a heavy foot.
  4. May 30, 2013 at 3:21 PM
    jmg256
    Al Tonter
    TRD Offroad
    Fwiw, I run a 265/75/16 and did notice a drop in in town mileage over stock, maybe ~1mpg, not enough to care...and completely anecdotal
  5. May 30, 2013 at 3:38 PM
    tomtom
    The Desert SW
    2012 FJ
    3% sounds right. It is the ratio of a 32" tire to a 31" tire.
    Depending on your driving habits, you may be losing efficiency at the bottom end if you are starting and stopping often.
  6. May 30, 2013 at 3:54 PM
    jmg256
    Al Tonter
    TRD Offroad
    Isn't that what I just said? :notsure:
  7. May 30, 2013 at 4:54 PM
    tomtom
    The Desert SW
    2012 FJ
    are we not allowed to be in agreement? :notsure:
  8. May 30, 2013 at 5:01 PM
    jmg256
    Al Tonter
    TRD Offroad
    Touche
  9. May 30, 2013 at 5:30 PM
    tomtom
    The Desert SW
    2012 FJ
    Great minds think alike, right? :)
  10. May 30, 2013 at 5:40 PM
    jmg256
    Al Tonter
    TRD Offroad
    Agreed
  11. May 30, 2013 at 7:34 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I wouldn't worry about spending money on changing gear ratio,
    I run 285/70/17 in the summer and stock tires in the winter and hardly notice any difference in the way it accels or drives between the two and my mpg's average 16-17 on both sets
  12. May 30, 2013 at 7:43 PM
    jmg256
    Al Tonter
    TRD Offroad
    X2...
    You speak of going to 285/70/17 in the future...that is the time to regear, if you feel necessary.
  13. May 31, 2013 at 4:17 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    You have 5 lug wheels and a 4 cylinder engine = 4.10 axle gears, as does the auto transmissions on 4 cylinders.
  14. May 31, 2013 at 7:11 AM
    aubi1414
    Justin
    Pensacola, FL
    I am a stop and go 90% of the time and I understand that.
  15. May 31, 2013 at 7:13 AM
    #35
    aubi1414
    Justin
    Pensacola, FL
    Agreed on both of yalls comments and makes sense I never really thought about the stop and go part because that's what I did before I put my new tires on as well.
  16. May 31, 2013 at 7:27 AM
    #36
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Drop in mpg could also be due to different tread design and psi. A different tire size usually rssults in different from stock tire pressure.
    Also from research and experisnce, only reason to re-gear is to gain power as mpg increase is insignificant.
  17. May 31, 2013 at 7:45 AM
    #37
    aubi1414
    Justin
    Pensacola, FL
    Yeah the tires def have a different tread design and a hum on the highway and guess ill steer clear of re-gearing unless I bump my tires size up again when I lift it more.
  18. May 31, 2013 at 8:03 AM
    #38
    pyrobobd
    pyrobobd Active Member
    Bob
    Southeast Colorado
    '07 basic truck
    Variable speed wiper switch
    No, I *do not* have 5-lug wheels. The truck is a base, access cab, 4-cyl, 4wd. And it does have 6 bolts. I really can count!
    B
  19. May 31, 2013 at 8:36 AM
    #39
    aubi1414
    Justin
    Pensacola, FL
  20. Jun 1, 2013 at 3:48 AM
    #40
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    Sorry, wasn't aware.
    Is it fair to say all 2nd Gen 4 cylinder auto or manual 2 or 4wd have 4.10 axles ?
