Re manufactured steering rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hennessy3300, Apr 11, 2020.
  1. Apr 11, 2020 at 10:34 AM
    hennessy3300
    hennessy3300 [OP] Well-Known Member
    Looking to replace my leaking steering rack. I've been delaying replacing the original rack using Lucas stop leak and its been working good for about a year but the leaky seals have finally returned and there is a tiny bit of play on one of the inner tie rods. Has anyone used a Detroit Axle manufactured rack? The price is great and it comes with a lifetime warranty.
    https://www.ebay.com/itm/Complete-P...4?fits=Year:2005|Model:Tacoma&epid=1026733317
  2. May 12, 2020 at 10:49 AM
    Zersko
    Zersko Well-Known Member
    Northeast
    2016 Tacoma SR5
    I have the same problem with my rack. Im finally getting around to doing something about the leak, was planning on using Lucas. Did you mix with PS fluid or pump the PS fluid out then add 100% Lucas?
  3. May 12, 2020 at 11:26 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    When I did mine, years ago. I put MotherToyota parts back on. My personal opinion is, if it takes over 2 hrs to do, then OEM is the way. If you can swap easy, aftermarket...
    Just me.
    doorsidedown likes this.
  4. May 12, 2020 at 12:44 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    bought one june of 17
    works fine with no issue
    looked brand new when i got it
    DG92071 likes this.
  5. May 12, 2020 at 3:19 PM
    hennessy3300
    I added the lucas stop leak every time the reservoir got a little low until the bottle was used up. The rack whines for a second when starting in cold weather because its thick stuff but it works.
