RE-painting fender flares?? Front Bumper?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Slayenemy, Jan 31, 2010.
  1. Aug 26, 2010 at 8:41 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    yeesh...that stuff is temporary and will wash away after a bit of contact with water.
    My advice is to paint to match. I always thought the textured plastic non painted flares gave off the impression that it wasn't a highly optioned truck. Even if this is the case, color matching your flares will give it a nice finished look.
    Wipe the flares with isopropyl, then prime, then paint. Make sure you get paint that is designed for vinyl/plastic since it will have a flex additive in it and will not crack.
  2. Aug 26, 2010 at 8:59 PM
    hobo_hut
    hobo_hut Member
    A lot of people on other forums rep using Penetrol on black plastic trim pieces. Penetrol is a flow control paint additive and is available at most hardware places like home depot. A lot of people swear by it and Ive seen pictures and have to admit they look convincing. Easy to apply and wont peal off is what they say. Just google it. **Disclaimer** I haven't tried it...I'm just offering a possible alternative to painting.
  3. Aug 27, 2010 at 6:11 AM
    iDigTulsa
    iDigTulsa Well-Known Member
    Luke
    Tulsa, OK
    03 DoubleCab TRD SR5 4x4
    Free Alarm Mod, Grey Wire Mod, Reverse Leaf Spring Helper Mod, Kenwood Deck, Memphis 10'', Yakima Roof Rack, Debadged Sides,Silver Toyota Skid Plate, Injen CIA, 3.5'' Amsoil Dry Filter, 17 x 7.5 Tundra Split Spoke Alloy's
    Check out Post #14 for Before and After pics... I was and am still amazed.
  4. Oct 14, 2010 at 9:14 PM
    HusqyRider
    HusqyRider Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    +10 on mag eraser
  5. Oct 15, 2010 at 1:15 PM
    scocar
    scocar hypotenoper
    I found the HD Magic Eraser at Home Depot, but haven't had time to use it yet. My fenders are total shit--they almost look color-matched to my lunar mist metallic!
    I figure after the magic eraser, treat them with 303 each time I wash it (which is maybe onece every 2 months...). Anyone else used this approach yet? How long does it last? Seems to be the simplest by far compared to painting or other "restoration" products that require frequent retreatment.
  6. Oct 15, 2010 at 7:00 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Can you buy a color matched Spray paint to do the flares?
  7. Apr 13, 2013 at 4:48 AM
    yellowdotz
    yellowdotz Well-Known Member
    SiNNeR
    Pasadena, CA
    13 tacoma i42.7L 4x4 manual access
    Have you tried plastidip flat black spray? I think that is the best for black, but it has a slight texture.
    What about the stuff they spray stoves with? The heat spray. Those are very durable and resist the sun well.
  8. Apr 13, 2013 at 7:49 AM
    scocar
    scocar hypotenoper
    Wow, this is old. BTW, the Magic Eraser is very temporary, even with 303. I tried the Mother's BtoB too. very temporary. Screw this. I don't have the patience for this kind of upkeep. I'm going to paint them with Duplicolor adhesion promoter primer and satin black bumper/trim paint this summer.
  9. Apr 13, 2013 at 8:11 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    PLASTIDIP! There, I said it.
  10. Apr 14, 2013 at 9:02 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I used this stuff and only did 1 coat. Flares look killer now and have a little bit of texture for durability. Badass stuff! Mine have been painted since last year and look great still.
  11. Apr 14, 2013 at 11:16 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I used the exact same stuff on mine 2 weeks ago.
  12. Apr 14, 2013 at 11:28 PM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    how do the rubber seals around the flares hold up with that? im between this and just finding some black plastic trim paint. also need to replace the seal by the gas door. the part where the flare goes in to give space for the gas door is where the seal is coming out. yall have this problem?
  13. Apr 14, 2013 at 11:29 PM
    PcBuilder14
    Brent
    Nor Cal
    I taped off the seal, so there's no bedliner on mine.
  14. Apr 14, 2013 at 11:49 PM
    DSully72
    Daniel
    Appling, GA
    gotcha. im gonna take mine off since I have to fix that seal anyhow... just easier to spray on cardboard over the grass rather than buy a crap ton of tape and newspaper lol.
  15. Apr 15, 2013 at 12:43 AM
    #35
    PcBuilder14
    Brent
    Nor Cal
    Haha definitely. I've got overspray all over my hood... :eek:
  16. Apr 15, 2013 at 6:53 PM
    #36
    DSully72
    Daniel
    Appling, GA
    oooh no bueno :(
  17. Apr 16, 2013 at 7:24 AM
    #37
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    If you paint them, spend the time on proper prep. The "Trucks" show this weekend did a session on painting truck plastic. Good info. They prepped with a 3 part system from maybe Dupont? I don't remeber the company.
  18. Apr 16, 2013 at 7:32 AM
    #38
    WThomas1250
    WThomas1250 Well-Known Member
    I've used this stuff on my flares, front bumper, and rocker panels. Looks great!
  19. Apr 16, 2013 at 11:13 AM
    #39
    PcBuilder14
    Brent
    Nor Cal
    Not much prep required for bedlining plastic. Just clean it off really good and that's it. Bedliner is completely different from paint.
  20. Jan 29, 2017 at 11:15 AM
    #40
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Does the magic eraser last ?
    How much elbow grease ?
    Where do you buy it ?
