Re-sealing factory roof rack holes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rizzowe, Feb 7, 2021.
  1. Feb 7, 2021 at 1:26 PM
    Rizzowe
    Rizzowe [OP] Member
    2020 Silver-Sky TRD OR 4x4
    I had a OEM roof rack on my 2020 DCSB. I took it off so that I could go back to using the drip moldings that were originally on the truck with the intention of eventually getting a more traditional Thule or Yakima rack.
    My questions is, does anyone have experience with going to the dealer to have the holes sealed or to have the factory bolt hole tape re-applied? I was able to get the drip moldings but the parts dept. said they didn’t have a part # for the tape that covers the holes. I’ve seen a lot of mixed reviews on sealing the holes with silicone and would prefer a more permanent, worry-free option. I have VHB over the holes currently and it started peeling pretty easily after a wash.
  2. Feb 7, 2021 at 2:05 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    On an older vehicle I filled the holes with RTV after I took the roof rack off, cleaned the channel with alcohol, applied single sided vhb tape over the hole, and replaced the drip molding.
    For 2 years I never had a leak then I sold the vehicle.
    Rizzowe[OP] and TacoManOne like this.
  3. Feb 7, 2021 at 2:24 PM
    Rizzowe
    Rizzowe [OP] Member
    I didn’t know there was single sided VHB. Might need to look into that. The double sided tends to absorb a lot of water
  4. Feb 7, 2021 at 2:37 PM
    ssd2k2
    Keith
    Minnesota
    I'm not sure if it was official 3m VHB tape, I got it off a job site, it was some waterproof sealing tape that seemed very similar to VHB tape.
    Edit: It was something like this
    https://www.amazon.com/3M-Extreme-S...612737758&sprefix=3m++sealing,aps,185&sr=8-10
    The important thing is to clean the area with rubbing alcohol so the tape can get a good bond.
    On my current Tacoma I have double sided VHB holding the molding in place on both ends with zero issues over the last 6 months. And I have used double sided VHB to hold down roof moldings on multiple vehicles with almost no issues.
    Rizzowe[QUOTED][OP] likes this.
  5. Feb 7, 2021 at 2:43 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    SS bolts with a little teflon tape?
    Rizzowe[OP] likes this.
  6. Feb 7, 2021 at 2:43 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    If it were me, I'd install a metric setscrew with teflon tape. Then put a small piece of masking tape over the head of the setscrew. Then smear seam sealer over it to seal. This would allow easy access to the threads if needed in the future.
    Malvolio and Rizzowe[OP] like this.
  7. Jun 18, 2022 at 12:45 AM
    TacoTuesday1
    SD CA
    Looking into this now. Thought of this. But it would need anti-sieze. Would not be good for the set screw to seize. Allen would probably be better than flathead.
    I forget what plugged it from factory. I think gooey adhesive residue that gums up. I don't know if underneath that it had any plastic plug inserts or not, to pry out.
    I've had good luck before using two layers of cut/trimmed aluminum foil tape (HVAC ducting) and will probably try that route again
