Re-sealing Headlights Question
Discussion in 'Lighting' started by ColtsTRD, Nov 13, 2011.
  1. Nov 13, 2011 at 10:07 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    Hey fellas, I have the ebay BHLM headlights on my truck and the drivers side is fogging up really bad from the rain and temp change we're having out here. I went to Home Depot and got some DAP Window and Door Silicone...its water and sun proof and non cracking. Where should I seal this damn thing? All around the edges? Also, is there any way to make the seal better where the bulbs screw in? (parking and turn signal)
    Thanks for any help fellas...I'm drying the thing out now in the oven LMAO! :D
  2. Nov 13, 2011 at 10:23 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    BUMP!!
  3. Nov 13, 2011 at 10:25 AM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    yeah i i resealed mine right when i got them, i did all around the edges
  4. Nov 13, 2011 at 10:25 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    okay cool, any issues since?
  5. Nov 13, 2011 at 10:26 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    if you can, open it up and clean it.. then seal with window butly.. thing of tangy taffy..then you can put a bead of GE silicone where the lens meet the housing.
  6. Nov 13, 2011 at 10:29 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    fuck man, thats a lil' more than I'm looking to do...I've done the BHLM before with some other guys on here and its kind of a PITA...I'll just try sealing the fuck out of it all around the edges
  7. Nov 13, 2011 at 10:35 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    You can't just seal it up now, the moisture will be trapped in there forever.
  8. Nov 13, 2011 at 10:39 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Take the headlight off and bake it on about 200 degrees for 10 minutes at a time until the water evaporates. The water should evaporate out of the housing as long as you don't have a ton of water in there. I have done this in the past with good luck when I had condensation. Then run the bead of silicon around the seam where the lens meets the housing. Put on some latex gloves and work it into the seam with your finger. I recommend gloves because that silicon gets messy and doesn't clean off with water. Make sure you have a lot of paper towels handy.
  9. Nov 13, 2011 at 10:39 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Put a silica gel packet in the light and it will soak up the moisture. Then you can seal them off.
  10. Nov 13, 2011 at 10:47 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    I'm not sealing it with the moisture in there...i'm drying it out now...its in the oven. I'll make sure its completely dry before re-sealing fellas :)
  11. Nov 13, 2011 at 10:48 AM
    ColtsTRD
    ColtsTRD [OP] .....
    Scott
    AZ
    2005 TRD DCSB
    your the man!!!!!
  12. Nov 14, 2011 at 9:46 AM
    Fiolo
    Fiolo Senior member
    no, they are pretty good for now
  13. Nov 14, 2011 at 9:56 AM
    Bently
    Bently Active Member
    Scott
    2011 black tacoma
    fog lights installed tri fold tonneau cover Folding towing mirrors
    Whats everyone running for headlights? im looking for something brighter other than the oem parts.
  14. Nov 14, 2011 at 10:40 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The OEM housings are actually pretty good compared to other manufacturers. Those cheap Ebay projector housings will not be as bright. Like Wolfpack said, for the best light output, retrofit the stock housings with projectors. Check out theretrofitsource.com, that's where most of the members here got their kits from.
    If you're looking for something simplier, try Philips X-treme bulbs or PIAA X-Treme white bulbs. I've had both and they'll both outshine the OEM bulbs.
  15. Nov 14, 2011 at 10:47 AM
    macgyver
    Brad
    Canton, GA
    I run silvania silverstars in mine and they improved the brightness a little bit over stock. They only last about 9 months to a year but I am willing to deal with that.
    Our stock headlights are actually quite bright. My girlfriend's Jeep compass for example has horrible headlights. I hate driving her car at night.
