re:Take-off shudder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO_BOB, Jun 10, 2010.
  1. Jun 10, 2010 at 12:19 AM
    TACO_BOB
    TACO_BOB [OP] Active Member
    Bob
    Northern Kentucky
    08 rc 5 speed 4x4
    Well first off thanks to obxfishn he uploaded this video...I've been having this same problem with my truck (2008 trd off road 4x4 sr5 v6) I got it 2 months ago under warranty...The toyota dealership couldn't slove this problem well i got one for them the video.. apon wacthing the vid i went out looking at the truck wrapped my hand around the carrier bearing sure enough i could move the whole assembly. so i downloaded the video to my camera and i'am taking it to the dealership this friday 1:00 hopefully this will straighten it out. Just thought if anyone else is having this problem maybe this will help.....fingers crossed I will keep you guys posted.
    rear tsb and shocks all around: done
    trans tsb: done
    carrier bearing assembly: hopefully
  2. Jun 10, 2010 at 1:03 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Tried everything on my 07 to resolve at the dealer. trans TSb carrier Bearing, the response was from dealer that its "inherant to the vehicle" Many posts on this issue.
    I just learn to live with it, as you will too in time. Hopefully your carrier bearing helps yours, as it didnt with mine.
  3. Jun 11, 2010 at 10:16 PM
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    I have the same shudder on the take-off and I couldn't figure out what the problem was. This vid really shows what the problem is. I'm curios if the dealership will fix it. Please post the update on it.
  4. Jun 11, 2010 at 10:20 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    looks like that carrier bearing bracket needs some more support
  5. Jun 12, 2010 at 6:47 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Wow...that cross member movement sure looks scary. Maybe strengthening the bracket would keep it from moving relative to the vehicle but that isn't the cause of the shudder. It might actually make the shudder feel worse as more of the vibration will be transferred to the frame and cab unless the carrier bearing's cushioned mount (that big, soft rubber donut around the bearing) is also made cushier.
    I wonder why the whole assembly wants to vibrate like that though...is it the axle angles? Can't that be fixed by shimming something? Was this guy's truck 'stock', with no lift?
    But it didn't look to me like the spline was a problem...it was sliding back and forth rather freely.
  6. Jun 12, 2010 at 8:52 AM
    desertdude59
    My 91 is lifted and I don't get a shutter from my driveshaft like that. I've had to replace my carrier bearing before, but just because the rubber was all ate up. Could be a driveshaft balance problem too. I still don't like the design of the bracket though.
  7. Aug 21, 2010 at 10:33 PM
    TACO_BOB
    Bob
    Northern Kentucky
    08 rc 5 speed 4x4
    well thinking about tradeing her in on a chevy after months of bs with toyota...what do you guys thinks?
  8. Aug 22, 2010 at 5:32 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I think you'll find the chevy will also have some incurable problem... hopefully it won't be as annoying as this apparently is.
    Have you explored repair under this tsb: "T-SB-0132-08 Driveline Vibration Between 15 - 25 MPH"? The work is covered under the 6/60K drivetrain warranty if they find yours needs it. The fix is a new aft transmission mount that controls the 2nd order vibrations. Your carrier bearing's hopping around like that is probably it just reacting to those vibes (if this is the case).
    Have you explored removing the carrier bearing entirely by replacing the split drive shaft with a one-piece? I think the cost will be around $400 (just guessing, really) from Tom Woods. Someone in another thread found a shop that will use your shaft ends and save some bucks. But your truck will be laid up while he's building it and you have to ship parts both ways...have to run the numbers to see if it's the better deal.
