Re-torque headbolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomanTurd, Jan 31, 2020.
  1. Jan 31, 2020 at 8:16 AM
    TacomanTurd
    TacomanTurd [OP] Well-Known Member
    David
    2004 Tacoma
    Stock for now
    Hello all
    this weekend the weather will be palmy fifty degrees so I’ll be tackling the leaky valve cover gaskets. While the valve covers are off I’ll try to re-torque the headbolts. Just wondering if it’s advisable to do so? And what’s the torque spec for the headbolts? Thank you
  2. Jan 31, 2020 at 8:28 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    No. There is no reason to do it and they are not meant to be retorqued. They are stretch to torque bolts and are not meant to be retorqued or reused should you ever do head gaskets they must be replaced.
    BlackGT99 likes this.
  3. Jan 31, 2020 at 8:30 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    leave them be
  4. Jan 31, 2020 at 8:33 AM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    No. They’re torque to yield
  5. Jan 31, 2020 at 8:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    No, no, no!
    Plus, if they were loose you'd have a lot bigger problems anyway.
  6. Jan 31, 2020 at 9:04 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Torque to yield means that they are torqued right up to the point of failure, basically. So do NOT try and "re-torque" them.
    As others, said, if they're loose, you got issues.
  7. Jan 31, 2020 at 9:16 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I agree with what other's have said. Don't screw with them. If it ain't broke, don't fix it. That could change the shape of the older head gasket then you're in deep trouble.
  8. Jan 31, 2020 at 10:49 AM
    TacomanTurd
    David
    2004 Tacoma
    Stock for now
    Thank you all. I’ll leave them alone
  9. Jan 31, 2020 at 11:08 AM
    rorrapalooza
    rorrapalooza Member
    19 TRD OR 6MT, 87 4Runner DLX 5MT
    I agree completely that they should probably not be retorqued, but to play devils advocate;
    Yield Strength can be thought of as the point where plastic deformation begins to take place in earnest (technically its 0.2% off set from the elastic limit) when a bolt is torqued to yield strength then held, overtime vacancies it the metal lattice move, which means plastic strain increases, and since the length and thus total strain is constant, elastic strain decreases. Since force is proportional to elastic strain, the torque will decrease, and it will actually be under yield strength after some period of months or years, especially if the bolt is hot, which it is.
    I wouldnt touch it unless theres some problem.
  10. Feb 1, 2020 at 2:40 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    rorrapalooza said exactly what I was going to say but I did forget the part about the “overtime vacancies in the metal lattice move”. I’m glad he reminded me of that ; )
  11. Feb 1, 2020 at 9:34 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You would have to pull out the cams anyway.
    Wyoming09 likes this.
  12. Feb 2, 2020 at 2:08 PM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    But you do want to replace the rear cam seals and the semicircular plugs along with those gaskets or you are wasting your time.
    may as well change plugs and wires and clean the throttle body too.
    Annndd.. swap the plenum gaskets for new also. Hope its a good day
