Re-welding cross member
Discussion in 'Suspension' started by ZERO COOL TACO, Feb 3, 2009.
  1. Feb 3, 2009 at 1:22 AM
    ZERO COOL TACO
    ZERO COOL TACO [OP] Member
    western north carolina
    2008 Double Cab TRD Rugged Trail
    6 inch fabtech suspension lift
    I installed a 6inch fabtech lift on my 08 Taco. In order to install it I had to cut the factory cross member off. I miss the factory ride of my Taco and now want to remove it. Is it possible to weld the cross member back on and it be as reliable and safe. I don't know how much stress that thing absorbs. Any input would be great.
  2. Feb 3, 2009 at 4:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yes. It will have to be guseted, so If your not familiar with welding, have a shop do it.
  3. Feb 3, 2009 at 4:15 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    listen to chris he know his poo.
    did you have the coilovers too?
  4. Feb 3, 2009 at 5:41 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Wow - never heard of somebody wanting to remove their 6"...
  5. Feb 3, 2009 at 1:04 PM
    ZERO COOL TACO
    I'm not sure exactly what the problem is. I can appreciate the jeep like ride of a lifted vehicle but at 70mph or so it just seems to drift all of over the road subtly. And i"m not sure about coil overs. My lift is the fabtech 6inch suspen. Lift but its not the performance lift. The only shock replacement was in the rear. The front used the stock bilsteins just had a spacer.
  6. Feb 3, 2009 at 1:07 PM
    ZERO COOL TACO
    Also what does guseted mean? I'm not familiar with that term
  7. Feb 3, 2009 at 1:09 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    Maybe upgrade the front shocks? It's completely different, but when I went from the stock shocks to the Camburg COs, it was a world of difference.
  8. Feb 3, 2009 at 1:33 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    yeah it can be put back to stock. i had my 2000 dodge ram 4" trailmaster removed and rewelded all the crap they cut out.
  9. Feb 3, 2009 at 1:36 PM
    ZERO COOL TACO
    I may upgrade the shocks before i undo the 22 straight hours i vested in lifting my truck. Thanks alot
  10. Feb 3, 2009 at 1:37 PM
    ZERO COOL TACO
    How much did it cost you to get your stuff welded back on?
  11. Feb 3, 2009 at 1:39 PM
    paintdiddy
    shithead
    silver bullet
    to put the truck back to stock with all the parts i had kept.i had to buy 4 new shocks i gave away.$1000 so i sold the lift and 35" and rims for $1000. do you still have the crossmember???
  12. Feb 3, 2009 at 1:56 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    gussets are metal plates welded on to strengthen joints. They are usually triangular at joints but there are also gussets that are just plates welded over another piece(2nd pic) to help strengthen the span of frame.
    ex: the triangular piece of metal here
  13. Feb 3, 2009 at 3:02 PM
    ZERO COOL TACO
    Okay I got ya. That is certainly beyond my abilities so i guess I have to shell out some cash. And yes I still have the cross member and all of the stock parts. However the cuts weren't exactly a perfect line so I'm not sure if that will pose a problem.
  14. Feb 3, 2009 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The cuts wont be an issue. The welder will just weld some filler into the joint, then plate it. ;)
  15. Feb 3, 2009 at 4:20 PM
    ZERO COOL TACO
    I'm not sure what I'm going to do with it. I wanted to make sure that my truck could get back to stock before I let my lift go.
