Re Wiring Dome Light in Leer Cap
Discussion in 'Technical Chat' started by Drogers, Jun 16, 2010.
  1. Jun 16, 2010 at 2:20 PM
    Drogers
    Drogers [OP] Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    The dome light in my cap only works if my vehicle is running.
    I'd like to re configure the wiring so I can flip the dome light whenever I need to.
    Can anyone offer assistance on how to re configure this system?
  2. Jun 16, 2010 at 4:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Where is the dome light getting power from? I had to run a new wire from the fuse block all the way to my shell. If they already ran a wire for yours, then you you need to trace it back to the fuse block and find a power source that is always on.
  3. Jun 16, 2010 at 8:42 PM
    Drogers
    Derek
    Sayville, NY
    It's getting power from the tail light fuse. They popped the left side corner panel off of my bed and connected it.
  4. Jun 17, 2010 at 6:08 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 Access Cab 4x4, 17 TRD Sport 6 MT
    Leer 100R
  5. Jun 18, 2010 at 6:08 AM
    Drogers
    Derek
    Sayville, NY
  6. Jun 18, 2010 at 6:37 AM
    Drogers
    Derek
    Sayville, NY
  7. Jun 18, 2010 at 3:57 PM
    TroutBum
    Michigan
    Leer 100R
    Drogers,
    I used a new wire terminal and ran a new wire all of the way from the battery. No splicing into existing wires - I've always been worried about possible electrical gremlins due to corrosion (I live in the rust belt!).
    Hope that helps.
  8. Jun 18, 2010 at 11:26 PM
    Drogers
    Derek
    Sayville, NY
    I hear ya. I'm having a bit of a tough time. Bought all of the supplies but am unfamiliar with this stuff. Did you run 2 lines? I noticed that the dome light has 2 lines running into it.
  9. Jun 19, 2010 at 5:16 PM
    spp
    spp OC, Kalifornia
    OC California
    One is the chassis ground. You can attach it to the ground in the tail light and just run one wire to the battery.
  10. Jun 26, 2010 at 7:20 AM
    TroutBum
    Michigan
    Leer 100R
    Did you get it working Drogers? I could take more pictures if it'll help.
  11. Jun 27, 2010 at 5:22 PM
    Drogers
    Derek
    Sayville, NY
    Hi Mike,
    Thanks for checking in. I haven't gotten it yet due to some uncertainty that I still have about the wiring set up, number of wires involved, where exactly you hook it up to your battery and where you end up splicing it into the dome light wires. I'm new to electircal work in vehicles and am nervous to start cutting or splicing into the existing wires. I bought all of the supplies that you suggested, just need a little more detail to feel confident in my novice skills.
    Thanks very much.
  12. Jun 28, 2010 at 7:25 PM
    TroutBum
    Michigan
    Leer 100R
    I'll take some more pictures for you this week. Sorry, ran out of daylight tonight (trying to get rid of a bunch of stuff in the yard from the previous owners of my house!).
  13. Jun 29, 2010 at 6:08 AM
    Drogers
    Derek
    Sayville, NY
    No prob Mike. I really appreciate your help on this. Any photos plus a more detailed description for a "rookie" would be very helpful. Hear from you soon.
    Derek
  14. Jun 29, 2010 at 6:17 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Take power straight from the + battery terminal to an inline fuse (10A). Run a wire following the stock wires on the driver's side all the way back to the rear corner or tail light (or where ever the existing wiring is). Cut the existing power going to the light and connect it to the wire from the battery.
    Done.
  15. Jun 29, 2010 at 9:22 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    How the heck did they wire in the light to begin with? I just had a new Leer canopy put on this past weekend and I can turn the LED dome light on without the truck running. I do have to move the wires though so it looks cleaner, but I have to figure out where to put them first.
    Best of luck...post pictures when you're done.
  16. Jun 29, 2010 at 10:13 AM
    flightcancled
    Sounds like they took the power from the tail lights.
  17. Jun 30, 2010 at 7:38 AM
    Drogers
    Derek
    Sayville, NY
    So you're saying run 1 wire only from the battery terminal? I am confused since there are two wires that run into the dome light? Can you clear this up for me? Thanks!
  18. Jun 30, 2010 at 8:33 AM
    flightcancled
    Yes. The second wire is the ground, if the light works then its fine where it is. Odds are its tapped into the ground in the tails. With autos the frame is a massive ground, so you don't have to run a negative wire back to the battery.
  19. Jul 1, 2010 at 5:36 AM
    Drogers
    Derek
    Sayville, NY
    I don't know what my problem is? I can't seem to get this to work out.
  20. Jul 1, 2010 at 7:49 AM
    flightcancled
    What is the ground wire tied into? What did you do exactly?
