Read Diff failure at 72k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CementPro, Feb 3, 2022.
  1. Feb 3, 2022 at 7:47 PM
    CementPro
    CementPro [OP] Well-Known Member
    2017 Cement Tacoma TRD Pro
    None.
    Anyone else have an unexpected rear diff problem requiring replacement shortly after the warranty expired? I have 72k on a 2017 TRD Pro and, despite reporting a clunk in the rear for 3 years, the dealer said Toyota won't cover it (they are replacing at a discount). No hard off-roading. Shavings in the fluid and some "looseness". I wanted to just re-gear but without knowing what is creating the unusual wear, I can't really do it (getting the internals is apparently impossible outside the dealer network), and since it's a daily driver, I can't have it parked for weeks waiting for ECGS to rebuild it (they have no rear diffs to build pre-builds). Anyone else had this experience?
  2. Feb 3, 2022 at 11:30 PM
    Montana_Actual
    Montana_Actual ;)
    Do you have documentation the "clunk" was reported? I'd fight hard on that one. When they investigated what did they do? I assume they changed the dif fluid each time and that's how they found metal shavings? It seems like whoever was working on it and keeping record ignored the severity of it and chalked it up to "normal wear and tear" instead of just fixing it to avoid a future issue - something they should have done being under warranty. I want to know more here. Subbed.
    But no, sorry, I have no experienced this personally. I think others on this forum have reported early dif failures though. Sorry this happened to you.
    oconnor likes this.
  3. Feb 4, 2022 at 4:55 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Some have had diffs replaced unnecessarily for gear whine which is hit or miss.
    Do you have a catastrophic failure? Shavings and looseness don't sound catastrophic. Sorry if I'm skeptical but issues like this seemed to be misdiagnosed with regularity in today's times.
    Not sure where you're looking but internals are definitely available outside of dealers. Maybe not the side gears, spider gears, cross pins, and such but definitely replacement carriers/lockers, bearings, rebuild kits, and ring and pinions.
    Chew likes this.
  4. Feb 4, 2022 at 5:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    This ^^^^^
    However, if it is your problem, I'd not have the dealer fix it.
    Had a friend with a similar issue in another marquee that the dealer could never get right. I sent him to a local shop that is a differential/axle specialist and he got fixed up right in less than 2 days, never had an issue again.
    So. If you live in a large enough community to have racers, street rods and off roaders, someone will know who the local guru is.
  5. Feb 4, 2022 at 5:54 AM
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    There’s plenty of wrecked Tacoma’s on eBay. I’d price some rear diffs there and see what the price comparison would be. Sorry for your luck.
  6. Feb 4, 2022 at 8:16 AM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    I heard some whine from mine and the dealership replaced it at 30k miles. supposedly was chunked. I had just finished a 3200 mile road trip.
    hopefully new one is good.
  7. Feb 4, 2022 at 3:36 PM
    JoeyDriver
    JoeyDriver Member
    2020 Tacoma SR MGM
    Any upgrades to suspension or tire size?
    Chew likes this.
  8. Feb 4, 2022 at 4:53 PM
    Montana_Actual
    Montana_Actual ;)
    Good point. Dealer would charge outrageous prices.
  9. Feb 9, 2022 at 3:01 PM
    CementPro
    None.
    It's the side gears, spider gears, and carriers...ECGS doesn't have those to re-build, and says they're hard to get (and pretty pricey).
  10. Feb 9, 2022 at 5:35 PM
    KB_TX
    KB_TX Well-Known Member
    2005 Tacoma TRD OffRoad
    How much is it running you with the discount? Buddy needed a new one on his STSV recently and got priced some $4k+, wondering how the taco + discount would compare
  11. Feb 9, 2022 at 6:07 PM
    CementPro
    None.
    Dealer ordered a new rear diff and installed it for $2k. Retail, the diff is $2700. I have the old one. Mechanic said there were actual shavings in the fluid and enough metal particles to form flux bands in the fluid when exposed to a magnet. That said, he didn't spend any real time looking at the old today.
    KB_TX[QUOTED] likes this.
  12. Feb 9, 2022 at 6:08 PM
    CementPro
    None.
    Wescott lift and Icon add a leaf a few months ago. I just run 275s.
  13. Feb 9, 2022 at 6:10 PM
    CementPro
    None.
    I considered used, but my local 4x4 guy said junk yards charge a lot and you don't know if the internals are good or not, so I'd be in the same place as I was before today's work. I really wanted to re-gear, but it's going to have to wait.
  14. Feb 9, 2022 at 6:31 PM
    1776Taco
    2019 2.7 4x4 SR
    The likeliness of you getting a bad differential from a truck that’s 5 years old or newer is pretty slim. There’s not a whole slew of people reporting common major diff issues from these trucks, can it happen? Sure. But it’s just not all to common. But do whatever makes you feel confident in the truck.
    Chew likes this.
  15. Feb 10, 2022 at 3:56 PM
    CementPro
    None.
    Rog, it's just that I wouldn't know until after I bought it and had someone tear it apart, then if I was unlucky enough to find a bad one (unlucky enough to have mine go bad already), there's no returns. The dealer's offer had an expiration, so if I ran into any trouble with any other option, I'm down to renting a car for however long it takes to get parts and space in their shop for someone else to do the work. I ended up picking the one option I knew would work, even if it puts me back where I was, gear wise, rather than where I want to be.
  16. Feb 10, 2022 at 4:07 PM
    Montana_Actual
    Montana_Actual ;)
    Last time I did a whole rear end I got it cheap and redid the internals too. Granted, that was in 2014 ish and it was for a Blazer. You should be good but get new axle seals because they are cheap and why not.
