Read dum brake locking up periodically
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KevinsTaco16, Jan 7, 2024.
  1. Jan 7, 2024 at 1:40 PM
    KevinsTaco16
    KevinsTaco16 [OP] Member
    2016 Tacoma Sr5 Premium
    Leveling kit
    I have a 2016 Tacoma and the rear passenger side wheel keeps locking up randomly. It happened the other day (all within a week) and I just kind of hit the gas not fully realizing it was locked up because I was on a hill. Then it happened the other morning where it wouldn't move at all and finally I turned it off and got out and came back 5 minutes later and it was free. Today there was a snow storm and I had it in 4 wheel drive and had somewhat of a tough time getting out of the driveway then I found myself going sideways down the street and it was locked up. Immediately pulled over and took it out of 4WD and noticed the read passenger side not spinning. It would free up when I would put it in reverse and be free for about 20ft when I put it in drive and then it would lock up again.
    I read some other post about washing the truck and letting it sit. I washed it one night in colder temps (40's) and didn't move it overnight but it was fine the next morning. Any advice or help would be greatly appreciated
  2. Jan 7, 2024 at 1:42 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Is it locking up while you’re moving and attempting to slow, or after you’re parked and attempting to dive away for the first time?
    If the latter, it’s probably the drum and liner sticking.
  3. Jan 7, 2024 at 1:46 PM
    KevinsTaco16
    Leveling kit
    Both, 2 days now I went out and went to drive my truck and it felt like I was hooked up to a tree but today it was happening at speed (very low speed) but I would just lock up
  4. Jan 7, 2024 at 1:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If they're locking up randomly something is likely broken in there. Remove the drums and take a look
    RustyGreen and wombatz like this.
  5. Jan 7, 2024 at 1:55 PM
    KevinsTaco16
    Leveling kit
    I'd love to but we are getting dumped on with snow right now so figured I'd ask here first to see if anyone might have some insight on a similar issue
  6. Jan 7, 2024 at 1:55 PM
    KevinsTaco16
    Leveling kit
  7. Jan 7, 2024 at 1:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They're drum brakes. What else is there to do besides take the drums off and look? :notsure:
  8. Jan 7, 2024 at 2:01 PM
    andthen
    andthen Well-Known Member
    Fred
    22DCLB Lunar Rock
    Automatic or stick?
  9. Jan 7, 2024 at 2:01 PM
    KevinsTaco16
    Leveling kit
    not interested in putting my truck on a Jack or Jack stands or trusting wheel chocks on a driveway full of snow and ice man
  10. Jan 7, 2024 at 2:01 PM
    KevinsTaco16
    Leveling kit
    Automatic
  11. Jan 7, 2024 at 2:02 PM
    andthen
    Fred
    22DCLB Lunar Rock
    Do you use the emergency brake?
  12. Jan 7, 2024 at 2:05 PM
    KevinsTaco16
    Leveling kit
    yes very often
  13. Jan 7, 2024 at 2:06 PM
    andthen
    Fred
    22DCLB Lunar Rock
    Stop using it.
    MGMDesertTaco and Chew like this.
  14. Jan 7, 2024 at 2:07 PM
    KevinsTaco16
    Leveling kit
    doesn't help my currently situation but ok.
  15. Jan 7, 2024 at 2:08 PM
    andthen
    Fred
    22DCLB Lunar Rock
    From what I gather, the transmissions in these trucks are robust enough to take the weight of the truck without issue.
    I had to stop using mine and that was the end of my sticking issues.
  16. Jan 7, 2024 at 2:09 PM
    andthen
    Fred
    22DCLB Lunar Rock
    She'll eventually defrost and release, then don't put it on again.
  17. Jan 7, 2024 at 2:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're thinking of a sticking cable, which is common. That can happen if dirt and water gets in there, like through a cut in the sleeve
    Inside the drum, that stuff gets used every time you touch the brake pedal
    The wheels and drums have to be removed to check both areas
    andthen[QUOTED] likes this.
  18. Jan 7, 2024 at 2:15 PM
    andthen
    Fred
    22DCLB Lunar Rock
    yep
  19. Jan 7, 2024 at 2:15 PM
    KevinsTaco16
    Leveling kit
    it's not the sticking when I'm parked issue. It's locking up while under way
    b_r_o likes this.
  20. Jan 7, 2024 at 2:29 PM
    andthen
    Fred
    22DCLB Lunar Rock
    Then you have to take off the drums, clean them up and take a look. I dont see what you see or feel what you feel but if you get any crud in between the brake shoes and the drum, it will drag and stick. if there's any moisture in that crud, the freezing will cause the water to expand, making the dragging into a sticking issue. I'd drive it making sure not to use the emergency brake and the dragging should stop. If the wheel is completely locked up and it doesn't stop, then you need a brake job whether you like it or not, at that point, the truck has made the decision for you.
    Vlady and AmateurTaco1313 like this.
