Read/Write speeds
Discussion in 'Technology' started by scout624, Mar 21, 2018.
  1. Mar 21, 2018 at 9:25 PM
    scout624
    scout624 [OP] Well-Known Member
    2018 Ford EcoSport
    Alright you techies, I have a bit of a dilemma...
    I'm currently using a 1TB G-Tech USB 3.0 "G-Drive" that I got in spring of 2016 with my 2015 MacBook Pro. Normally, I get write speeds in the high 90's, low 100's, however in the past day or two, I noticed my write speeds have dropped to 50-60 MB/s (pic shown). A few days ago I bought a new cable for it, however after testing both the new and old cables, I have ruled out it being the cable. What do you guys think may be causing the sudden drop in write speeds? It should be noted that I DO have data on it, as well as I also have it set in Photoshop and Illustrator to be used as a scratch disk.
    Could that have possibly caused it? And with the new write speeds, would it be better to connect it to my computer via FireWire using a FireWire/Thunderbolt 2 adapter? Or just keep it plugged in via USB?
    Thank you all very much
    Hunter
  2. Mar 21, 2018 at 9:30 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    In addition to ruling out the cable like you did, try it on another computer and see how it performs there.
    Matic and scout624[OP] like this.
  3. Mar 21, 2018 at 9:35 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Have you tried defragging the drive?
  4. Mar 21, 2018 at 9:37 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Isnt firewire a thing of the past? I dont really have anything to judge it by except for a raid 0 setup.
  5. Mar 22, 2018 at 7:32 AM
    scout624
    2018 Ford EcoSport
    Yep, it's some legacy stuff. But as far as speeds go it's USB 2.0 -> Firewire 800 -> USB 3.0 right now the 52 MB/s is essentially 2.0 speeds, so FireWire MAY be faster with writing? Idk.
    Yep, still have the slow write speed
    Matic[QUOTED] likes this.
  6. Mar 30, 2018 at 8:15 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    USB 3.0 is a 6Gbps interface, bottleneck sounds like the drive. OP Is the drive a solid state or a typical spinning Hard drive? you can open disk utility to find out.
  7. Apr 1, 2018 at 8:19 PM
    scout624
    2018 Ford EcoSport
    Spinning hard drive. And yes I'm aware of the bottleneck, just odd having write speeds suddenly cut in almost in half one day
  8. Jun 1, 2018 at 6:29 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    People still do this?
