Reading engine code
Discussion in '1st Gen. Tacomas (1995-2004)' started by ILove2Drive, Feb 7, 2009.
  1. Feb 7, 2009 at 9:21 AM
    ILove2Drive
    ILove2Drive [OP] Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    Hey guys. Last night when I was driving home my CEL came on. No difference in driving or anything so I'm not sure what's going on. I have a scan guage and my dad got out and checked it and cleared the code before I could look at it. He says the code is P041, I can't seem to find what that code means though, so if anyone can help me, it'd be much appreciated. Thanks in advance! :)
  2. Feb 7, 2009 at 9:57 AM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Here is a link to a code chart I think you are missing some numbers
    it might be a po441 code since he cleared wait and see if it comes back on.
    http://www.ncttora.com/fsm/2000/Repair Manual/Diagnostics/Engine/dtcc.pdf
    Online service manual link
    http://www.ncttora.com/fsm/2000/index.html
    P0441
    Evaporative Emission Control
    System Incorrect Purge Flow
    .Vacuum hose cracked, holed, blocked, damaged or discon-
    nected
    .Open or short in vapor pressure sensor circuit
    .Vapor pressure sensor
    .Open or short in VSV circuit for EVAP
    .VSV for EVAP
    .Open or short in VSV circuit for vapor pressure sensor
    .VSV for vapor pressure sensor
    .Charcoal canister cracked, holed or damaged
    .ECM
  3. Feb 7, 2009 at 10:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check your gas cap.
    If they're not 'tight' can setoff the CEL.
  4. Feb 7, 2009 at 12:21 PM
    ILove2Drive
    Casey
    WV
    Yeah man I was lookin the manual earlier too, this helps me think even more that it was probably 441, I asked him earlier if it was 441 and he says it wasn't. I took it up the road and it didnt come back on, but I'll give it some time. So I guess we'll see, but thank you! +1 :)
  5. Feb 7, 2009 at 12:24 PM
    ILove2Drive
    Casey
    WV
    Gas cap is good, but thanks for the headsup! :)
  6. Feb 9, 2009 at 11:43 AM
    ILove2Drive
    Casey
    WV
    The code came back today, it was P0141 so I'm assuming that's what it was. I looked it up and was just wondering how serious of an issue this was? Should I probably take it in?
  7. Feb 9, 2009 at 11:48 AM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    2016 4Runner 4x4 Limited Metallic Gray
    5K LED interior lighting
    Im not an expert.. but it sounds minor. HOWEVER, even if it is minor, and has ANY ties into the emissions testing whatsoever, if you live somewhere that has to do emissions testing, there is a good chance that you won't pass it.
  8. Feb 9, 2009 at 12:01 PM
    ILove2Drive
    Casey
    WV
    Alright thanks, is it anything that will affect the truck as far as performance or anything like that goes?
  9. Feb 9, 2009 at 12:06 PM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    Checking that code in the list it says:
    P0141
    (DI–241)
    Oxygen Sensor Heater Circuit
    Malfunction (Bank 1 Sensor 2)
     Same as DTC No. P0135
    As I mentioned before, there is a good chance that would cause you to fail emissions. I doubt it would affect too much as far as day to day driving. It might indicate other problems with your engine performance (ie. too rich/lean of a mixture). Though, there are a host of other sensors that would probably flag warnings if that were the case.
  10. Feb 9, 2009 at 12:12 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Check your charcoal canister. I had the same code and it turns out my charcoal can had a 3in long crack in the bottom.
  11. Feb 9, 2009 at 12:53 PM
    ILove2Drive
    Casey
    WV
    Alright thanks guys! :thumbsup:
  12. Feb 9, 2009 at 1:23 PM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    Also check the seal around your MAF sensor because i had the same code pop up and my problem was that too much air was getting in and the mixture was too lean.
  13. Feb 9, 2009 at 1:26 PM
    dually
    dually Low and slow
    Then he would have a code for being too lean also.
  14. Feb 12, 2009 at 8:15 PM
    ILove2Drive
    Casey
    WV
    Alright I have another quick question on this. Does anyone know exactly where this sensor is located? And is it something that I could replace myself or something that would probably need to go in to the dealer to be fixed?
  15. Feb 13, 2009 at 2:12 PM
    ILove2Drive
    Casey
    WV
    Anyone have any ideas?
  16. Dec 20, 2009 at 6:03 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    its your rear o2 sensor located after the catalytic converter. Its also the cheaper of the two sensors on your exhaust.
