Reading Oil Dip Stick [I'm not stupid]
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackrules, Oct 6, 2017.
  1. Oct 7, 2017 at 5:43 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Never could find a 710 cap or a 35 oz pump for those cars. :rofl:
    tcjacado likes this.
  2. Oct 7, 2017 at 6:13 AM
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    I read full at 5qt even. Should I be putting that extra .5 in that everyone else seems to be full at? I have it around, I just never have.
  3. Oct 7, 2017 at 6:14 AM
    DrFunker
    DrFunker Well-Known Member
    Did this too. Works pretty good. :thumbsup:
  4. Oct 7, 2017 at 6:30 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    You sure you didn’t drain your transmission and overfill your oil?
    balljoint and robssol like this.
  5. Oct 7, 2017 at 7:01 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    i filed mine a little, worked good.
    DrFunker[QUOTED] likes this.
  6. Oct 7, 2017 at 7:04 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I LOVE your disclaimer! "Reading Oil Dip Stick [I'm Not Stupid]. I'm prolly gonna use that.
  7. Oct 7, 2017 at 7:17 AM
    Richard
    Richard Member
    Port Saint Lucie, Fl
    The best way to read the dipstick is to make sure your truck is on level ground. And check it after the truck has been sitting for a while. Overnight is good. That way any oil in the tube has drained. You get a good check then.
  8. Oct 7, 2017 at 7:29 AM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    I pull, wipe, reinsert, pull and check. I find the underside of the stick gives a more definite level.
  9. Oct 7, 2017 at 7:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    You let the truck sit level for a bit before pulling the DS?
  10. Oct 7, 2017 at 7:58 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    No. Always wanted one:thumbsup::burnrubber:
    :rofl:I remember that thread:rofl:
  11. Oct 7, 2017 at 8:04 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Agree with Richard's post. When changing oil, I put in a 5qt jug, new filter, drive around the block, remove dipstick, let it sit a couple of hours or overnight (shop towel on steering wheel as reminder dipstick is out). This lets oil drain from tube. Remember low to high marks on the V6 dipstick is 1.6 quarts. Add oil to get to high mark.
    highriserkaiser likes this.
  12. Oct 7, 2017 at 8:13 AM
    vram74
    05 Prerunner SR5
    I check mine at gas station after filling up. Try to park at the most level looking pump station.
    Isn’t checking while cold going to give an inaccurate reading? Oil expands with heat. Your dipstick will read higher when hot. If your DS reads low when cold and you add oil, then you’ll read over the full mark when hot.
  13. Oct 7, 2017 at 8:50 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I have never heard of this discipline... :hattip:
    Key-Rei[QUOTED] likes this.
  14. Oct 7, 2017 at 9:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    Toyota reads these threads, and they desire to reduce customer anxiety.
    In 2020 they will be creating a dipstick free engine, so you no longer have to worry. Dealer serviceable only. :D
    Same business model as the transmissions, same principle as going from actual gauges to warning lights.
    Except for nanny stuff like TPMS, where they add more gauges.
    #savethedipsticks #dipsticksmatter
    Bebop and Skyway like this.
  15. Oct 7, 2017 at 9:22 AM
    #35
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    take some sand paper to the dipstick to scuff it up. definitely helps.
    robssol likes this.
  16. Oct 7, 2017 at 10:57 AM
    #36
    aficianado
    back to bone stock.
    Never said “cold” right? I let it sit for a few minutes.
    Never understood how folks have trouble reading our dipsticks. I just let things settle down a bit. Pull DS, wipe, insert, pull DS, read. If one side is sloppy, I read the other side. It’s usually better and I can see a good enough line to determine oil level. If the other side is sloppy as well, I didn’t give it enough time to settle down.
  17. Oct 7, 2017 at 4:22 PM
    #37
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The Tacoma doesn't. I have never seen an engine that used the dipstick tube for an oil return.
    OP, Just fill using what is listed in the owners manual and don't worry.
    When checking pull the dipstick and let it sit bor a minute or two before reinserting the stick.
  18. Oct 7, 2017 at 4:48 PM
    #38
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    This is my suspicion.
    All too common.
  19. Oct 7, 2017 at 6:06 PM
    #39
    vram74
    05 Prerunner SR5
    The checking cold part was a response to edm3rd’s post. I forgot to insert the quote.
  20. Oct 7, 2017 at 6:09 PM
    #40
    robssol
    Rob
    S. Wisconsin
    I wish I thought of that:rolleyes:
