Ready for a laugh?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BB_cuda, Aug 23, 2023.
  1. Aug 23, 2023 at 9:05 PM
    BB_cuda
    BB_cuda [OP] Active Member
    2021 Tacoma, metallic gray, LED headlights. Talon's Garage cat shield
    Here is the autonation add I would like to ask you all about please.
    https://www.autonationfordarlington...a-Tacoma-e00e890b0a0e0a917dcee69789d0fbef.htm
    A good friend (who is Tacoma knowledgeable) casually advised me that he sees a small lift on this truck. You all agree?
    Way back toward end of all pictures (photo 20) shows closeup of tires 285/75/R17. I have hunted around and came to conclusion that it takes a whole lot of work to clear these tires.
    2021 TRD sport, 4WD. Appears to be stock 17" wheels compared to another one I drove this last weekend.
    I called dealer sales guy selling this truck and he had a mechanic look at it. I had asked if there was a lift on it. Answer was no from the dealer mechanic.
    Am I getting lied to please? I'm in the middle of a purchase and don't want a modified truck.
    Please tolerate this newb's questions as I'm about to spend $40 grand. Thanks so much.
  2. Aug 23, 2023 at 9:07 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Looks lifted to me too.
    Chew likes this.
  3. Aug 23, 2023 at 9:13 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    shakerhood likes this.
  4. Aug 23, 2023 at 9:19 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    those pics are screwing with me, in one the passenger side looks squatted then the back looks to have standard taco lean on the drivers side
    measuring wheel center to the bottom of the fender will tell if there is a lift (anyone know stock offhand?)
    given the leather seats I'd guess it has a lift but if it is an adjustable shock lift you would just need to set them differently
  5. Aug 23, 2023 at 9:23 PM
    BB_cuda
    The leather seats are aftermarket Katzkin (zoom in on tag on photo 13). The truck started life as a cloth seats and no sunroof version. Trying to find leather seats and 6 speed manual is real hard unless you live out west. I'm in Houston. I wanted to find one done this way as I don't want a sunroof. Its a freaking truck! Factory leather only comes with sunroof.
    auskip07 likes this.
  6. Aug 23, 2023 at 9:32 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That is definitely lifted. Me personally, pass. If you want leather just have the katzkin or whatever route you want done to the truck you buy. Don’t need to specifically buy a truck with that already done. That will limit your options down to practically none.
    cryptolime, MR E30 and EL DUDE like this.
  7. Aug 23, 2023 at 9:36 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The rear shocks are not stock. Stock have a smooth hard plastic cover over the piston shaft. These are ribbed like a Bilstein 5100 boot.
    rolled93slc, MR E30 and tcjacado like this.
  8. Aug 23, 2023 at 9:40 PM
    EL DUDE
    EL DUDE Well-Known Member
    $40k is just too much for a midsize truck. I’d buy a used 4x4 tundra with real leather seats instead of the aftermarket crap.
  9. Aug 23, 2023 at 9:46 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Hey, it says no worries, they inspected it. You're fine. Buy 2 if they have an extra.
    MR E30 likes this.
  10. Aug 23, 2023 at 10:07 PM
    BB_cuda
    Thanks for idea but I'm actually wanting a midsize truck. I am replacing a 2003 Dodge Ram and wanting to downsize. I don't plan to pull with it. We have a BMW X5 with diesel if anything needing to be pulled. 550 lb-ft of torque in that beast
  11. Aug 23, 2023 at 11:02 PM
    MasTacosMa
    MasTacosMa Well-Known Member
    East Bay
    2020 TRD OR DCLB
    Looks like 5100s and IMO that's an upgrade over stock.
  12. Aug 23, 2023 at 11:19 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    10k miles and looks like new 285 tires not stock size so acceleration may suffer slightly and speedo off.
    See some dash mods on switches.
    Look under front and see if stock shocks or 5100 on like 3rd notch up (lowest is stock height) and 3rd is 1.75-2" lift.
    4th or highest notch is like 2.5" and alignment will not ever be able to be correct as they require new aftermarket UCAs - so crawl under and find out.
    It is a sport so no rear e-locker if you plan on any tougher offroad use you would need a TRD Offroad model.
    Those side bars are only steps so will get mangled if offroad use.
    Good luck with whatever you decide.
    265/70 R17 TIRES vs 285/75 R17 TIRES
    Current New Difference
    Rev. / Mile: 638.26 595.99 -42.27
    Section Width: 10.43'' 11.22'' 0.79''
    Sidewall Height: 7.3'' 8.42'' 1.12''
    Tire Circum: 99.27'' 106.31'' 7.04''
    Tire Height: 31.6'' 33.84'' 2.24''
    If your speedometer reads 65 mph, you are going about 69.6 mph
  13. Aug 23, 2023 at 11:19 PM
    TheProject
    TheProject GorillaTaco
    Southern California
    2022 TRD OR DCLB - Midnight Black
    Def lifted for sure.
    You can't fit 285/75/17 BFG AT tires on a stock suspension on a Sport. Even if so, not without any significant modifications.
  14. Aug 23, 2023 at 11:22 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    I see overspray.
    Check for shitty body work and carfax
    shakerhood, BB_cuda[OP] and RSOTACO like this.
  15. Aug 24, 2023 at 2:07 AM
    RSOTACO
    RSOTACO Well-Known Member
    Joe
    York County PA
    2016 SR5 Barcelona 285 75 16
    Yes
    Hold off until this good friend is prepared to advise you formally. 40k is not a casual price.
  16. Aug 24, 2023 at 4:01 AM
    boutym44
    boutym44 Active Member
    2023 Tacoma TRD Sport
    The tire diameter itself is about three and a quarter inches above stock TRD Sport tires, so that right there is going to get you about 1.5 lift.
  17. Aug 24, 2023 at 4:07 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    keep in mind, not everyone wants or needs a full-size truck
    Big tall dave, 02Duck and auskip07 like this.
  18. Aug 24, 2023 at 4:07 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Just have them send you a picture of the suspension and that will eliminate any question…
  19. Aug 24, 2023 at 4:08 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It is certainly lifted.
    if you become seriously interested, I would personally be damn sure I pulled a Carfax on any used vehicle from any dealer
  20. Aug 24, 2023 at 4:25 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    There is a Carfax on the link, shows 1 minor accident on the front end.
    BB_cuda[OP] likes this.
