Ready for a locker...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mike330R, Apr 22, 2013.
  1. Apr 22, 2013 at 7:47 PM
    Mike330R
    Mike330R [OP] Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    It's time for a locker for the rear of my 2000 4x4.
    Trying to decide on a drop in unit between a Lockright, ARB, or Detroit.
    Anyone have good data why one would be better than the other?
    While my rig is 80% daily driver I am not concerned with/fully aware of street handeling with a non-selectable locker.
    Who has the best price, either shipped or local to San Diego?
    I've read it's pretty easy to install but I don't have a good gauge to measure backlash and would rather have someone else do it, what's the going rate an who do you suggest?
    Also trying to figure out what gear ratio I have. I believe it's the 8".
    According to THIS POST I have 3.91's?
    Is the B06A towards the lower right corner the correct numbers to tell ratio?
  2. Apr 22, 2013 at 8:09 PM
    TonyTacoBC
    TonyTacoBC Well-Known Member
    Tony
    Langley, BC
    '03 Reg cab 4cyl 4x4
    tires
    You're correct, you have 3.91s.
  3. Apr 23, 2013 at 6:37 PM
    Mike330R
    Far West Phoenix
    Guess no 1st gens run lockers? ;)
  4. Apr 23, 2013 at 6:48 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i run a locrite, iirc you dont need to measure backlash with the locrite, it just replaces the spider gears
  5. Apr 23, 2013 at 6:49 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    For something that you drive daily I wouldn't get a full time locker.
  6. Apr 23, 2013 at 7:38 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    ARB all the way, reduces wear on tires because you can switch it completely off, I can install for you, PM me for info in interested..
  7. Apr 23, 2013 at 7:45 PM
    cshade
    cshade Well-Known Member
    cameron
    denver co
    1996 tacoma
    See thread
    just get a Detroit. if im not mistaken you have the 8.4 axle wich is very easy to do a full locker (took me 6 hours to do and i had never even seen a diff). My truck is my only vehicle and once you drive with it for a few weeks its like its not even there. I also haven't seen any extra tire wear and i just got new tires so ive been keeping track. you cant go wrong with a detriot, there bulletproof and you dont have to worry about any air issues.
  8. Apr 23, 2013 at 7:56 PM
    Mike330R
    Far West Phoenix
    The only Detroit I have found that will fit is around $600. For another 300 I can have a selectable.
    Still trying to make up my mind though.
    BTW: this axle is the 8" version.
  9. Apr 23, 2013 at 7:59 PM
    Mike330R
    Far West Phoenix
    Contacted Aussie, said they don't make one for an 8".
  10. Apr 23, 2013 at 8:07 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I have the lock rite for 3 year no problem but if say do a spartan posi instead of lock right its alittle bit stronger. And for the front do a selectable or you could just do front and rear arb
  11. Apr 23, 2013 at 8:10 PM
    cshade
    cameron
    denver co
    1996 tacoma
    See thread
    Well i havent been in the locker shopping game for a while but im pretty sure that the only selectable locker for the 8" you have (also called the 8.4) is arb which is about double the price seeing how you have to have lines and a compressor. The e-lock rear is also called an 8" but the non e-lock rear has a completely different housing. so when you go to look for a locker you want to look for the 8.4 option. EX: http://www.4wheelparts.com/Drivetra...?t_c=12&t_s=237&t_pt=101501&t_pn=EAT187SL199A
  12. Apr 23, 2013 at 8:12 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Yukon Grizzly Zip Air Locker. Fully selectable just like the ARB, same quality. Just lower price! Tons of guys run them without any problems.
  13. Apr 24, 2013 at 1:04 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    I would definitely get a selectable locker for a daily driver. Being an ARB owner I am partial to their product. I've found mine to have instantaneous engagement, be very reliable and very durable. Also, ARB customer service is second to none. ARB has proven over and over again that they stand behind their products.
    My story: I exploded my ARB through sheer stupidity. I engaged it while one of my tires was spinning and blew up the cage. (long story) I called their Renton WA customer service line and explained how I broke the locker. I acknowledged that the I was to blame in the incident, but asked if there was anything they could do to help out a loyal customer. ARB sent me a new cage, piston seal, main bearing and all the associated hardware entirely for free. For me, that makes ARB products worth the premium price.
  14. Apr 24, 2013 at 1:08 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you have the cash, there is no way anyone can make an argument against an ARB.
    Its expensive, but will be stronger than anything else, and because its your DD, it will be better on the road.
  15. Apr 24, 2013 at 1:17 PM
    Mike330R
    Far West Phoenix
    Ordered the ARB with the free compressor today.
  16. Apr 24, 2013 at 1:26 PM
    TacoMX
    Jonathan
    Deltona, Florida
    good choice...I wish I had the dough right now to do that
    My personal top choice is to find a e locker 3rd member with all the electronics and swap it in. OEM e lockers were 4.10 gears and that is what is in my truck, so it would work well (wouldn't have to regear the front)
  17. Apr 24, 2013 at 1:42 PM
    Lumpskie
    New Hampshire
    ^ I THINK you have to swap the full axle to fit go e-locker. If I remember correctly, the third members (and as a result axle housing) are different shapes between the 8" e-locker and the standard 8.4" so they are not interchangeable.
  18. Apr 24, 2013 at 1:46 PM
    Mike330R
    Far West Phoenix
    Pretty sure the full axle swap is needed.
    I looked into that swap but decided on ARB.
  19. Apr 24, 2013 at 1:48 PM
    TacoMX
    Jonathan
    Deltona, Florida
    You guys are right, that's what I meant, just mis-typed
  20. Apr 24, 2013 at 3:35 PM
    Lumpskie
    New Hampshire
    Cool, I just wanted to make sure you didn't buy a third and find out later. Nice truck BTW.
