Ready lift? Good or Bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by grogs34, Dec 31, 2011.
  1. Dec 31, 2011 at 2:30 PM
    grogs34
    grogs34 [OP] Senior Member
    Jake
    1998 tacoma
    lifted 2 inches,32x11.5x15
    Looking at shocks or a ready lift kit is a ready lift very good as far as spacers go/
  2. Dec 31, 2011 at 2:33 PM
    grogs34
    Jake
    1998 tacoma
    why do you say spacers are bad?
  3. Dec 31, 2011 at 2:37 PM
    grogs34
    Jake
    1998 tacoma
    Ok thanks for the info...could i add bilstein shocks on the spacers later on if i wanted to?
  4. Dec 31, 2011 at 2:41 PM
    grogs34
    Jake
    1998 tacoma
    two inch spacers and two inch bilsteins
  5. Dec 31, 2011 at 2:41 PM
    grogs34
    Jake
    1998 tacoma
    all together 4'' at tops
  6. Dec 31, 2011 at 2:52 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    It's code for Ready, Set, Run Away (as fast as you can) !
  7. Dec 31, 2011 at 2:53 PM
    grogs34
    Jake
    1998 tacoma
    ok cool, but the leveling kit and the bilstein will fit together. because people have told me that they will not fit together for some reason, and i will do a little bit of off roading on the farm and at other places but nothing to extreme, its more for the looks.
  8. Dec 31, 2011 at 3:02 PM
    Tacomanater
    Tacomanater Well-Known Member
    Washington County, NY (VT Border)
    '02 SR5, 4WD, V6, 5Spd
    JBA headers & exhaust, new cats, K&N CAI, new shocks, 2.5" lift, Prodigy P2, Timbren, snobord552 light bar (v.2), KC off-roads and Hella fog lights, Teflon A/R ATX 16" Ledge, Nitto Terra Grappler, (265/75R16's), ultragauge, curt roof rack on thule set-up.
    Hey,
    I just installed a ready lift leveler in the front and 1" spacer in the back (last week) so I could get 265/75/R16's under the truck.
    Looks okay, not as good as some of the other trucks in here, but I will tell you they are all right, it does ride like shit!!!
    Yes it is inexpensive...
    maybe the only plus, I do not need to put in UCA's, shocks or a diff drop in with this set-up..........However, I will probably change this out for coilovers, uca's and a diff drop sometime later this year....there is a right way, regardless of your use and an inexpensive way.....the spacer/readylift has minor advantages (costs less), but mostly disadvantages....as I see it/feel it now.
    Hey its all a learning curve. You choose how much you want to spend and when you want to spend it. GL
  9. Dec 31, 2011 at 3:10 PM
    grogs34
    Jake
    1998 tacoma
    thanks for your input it seems that spacers are disliked from just about everyone...i feel like i may go ahead and spend the extra money and get a whole new suspension lift.
  10. Jan 1, 2012 at 12:24 PM
    Tacomanater
    nmcq280:
    yes, blocks in the back. Works for now, but not for long haul. We will have to wait until towing season to see how she handles the trailer and gear. Then, may need to change it up a bit.
  11. Jan 1, 2012 at 12:29 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    If you haven't already done so, OP, you should review the the Suspension Lift Info and Tacoma Lift FAQ/Guide Stickies in the Suspension forum. They contain a wealth of information regarding various lift options, including many of the pros/cons for which you're looking.
  12. Jan 1, 2012 at 4:20 PM
    Tacomanater
    nmcq280:
    We'll see how well the Timbren system works....but I am still thinking suspension revamp alter this year.
