Ready Lift Strut Extension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by no_werries, Apr 7, 2009.
  1. Apr 7, 2009 at 1:42 PM
    no_werries
    no_werries [OP] Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Just finished putting on my new ready lift strut extensions, and diff drop. It was a pretty good deal, Managed to buy kit for $240 cash, installed my self, I still need to get alignment! But the kit included the two strut extensions, spracers and new bolts to drop the front differential, and skid plate spacers to alow room for lower diff! It is a very complete kit for the price, and an extra $100 I could have bought a rear block (with U bolts) to raise the back end up another inch, but I already have the back AAL's. The instructions that the company semt had great pictures, instructions were clear and easy to read! Took me about 3 hours all said and done!
    Oh yeh BIG SHOUT OUT TO CHRIS4X4, unfortunately the intructions the company gave me for dropping the strut didn't exactly make the task easy, I found that the lower control arm still doesnt have enough give even after you loosen the bolts for the ball joints! So Chris4x4's bit on moving the sway bar, and upper ball joints was great, I also found that detaching the sway bar where its is fastened to the truck frame helped a great deal in the removal proccess!
    Will have pics soon, heres is link to website's instructions on removing coil and spring, and installing extension! http://www.readylift.com/files/instructions/66-5055_Instructions.pdf
  2. Apr 7, 2009 at 3:22 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Sounds good. How much did the lift give you in real world numbers?
  3. Apr 7, 2009 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Glad to have been a little help. :)
  4. Apr 8, 2009 at 4:29 AM
    no_werries
    I'd have to say the lift was actually a bit more more then 2 1/2", probably closer to 2 3/4 - 3". However I did have an AAL lift in the back, which caused the truck to rake towards the front, meaning the front probably sat a bit lower compared to a stock vehicle.
  5. Apr 8, 2009 at 5:01 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Good to hear the install was pretty easy. I have a Hell Bent Steel 2.5 leveling kit sitting in my garage I need to find time to install. :cool:
  6. Apr 8, 2009 at 2:15 PM
    no_werries
    Just got back from getting aligntment, wow was the camber ever at a tilt, took the guy almost 2 hours to get the front aligned!
