ready lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Dec 23, 2010.
  1. Dec 23, 2010 at 11:21 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    just installed a ready lift, spacers up front and blocks in the back what tire size can i run with the stock 16' rims? want to avoid rubbing in all possible ways
  2. Dec 24, 2010 at 5:37 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    assuming the lift is 3", you can run 285/75/16' if you run 1" or thicker wheel spacers. And you will still have to trim fender well plastic and possibly chop the cab mount.
    If you don't want to run spacers or trim, then 265/75/16 is your max.
  3. Dec 24, 2010 at 7:26 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    trimming isnt a problem, ive heard wheel spacers being really hard on bearings on cv joints is that something i should worry about?
  4. Dec 24, 2010 at 9:35 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    285s and get spidertrax. Several members have them without problems.
  5. Dec 26, 2010 at 5:01 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    ok will do thanks guys :)
  6. Dec 27, 2010 at 5:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Along with the front spacer lift on ball joints.
