Ready to buy Dakar Leaf Packs. What else?
Discussion in 'Suspension' started by woodyc, Jan 5, 2015.
  1. Jan 5, 2015 at 12:57 PM
    woodyc
    woodyc [OP] Well-Known Member
    Craig
    Oceanside, CA
    2014 Access Cab 4x4 TRD
    Sway Away 2.5 " Coilovers Sway Away rear shocks Dakar rear leafs (3rd leaf removed) Snug Top Sport Highliner Shell Thule Racks Toyota Bed Mat Weather Tech Floor Liners
    Getting ready to buy the Dakar Rear Leaf packs. I will purchase the longer u bolts and axle shims. Can I use the stock bushings? Or do I need to buy new bushings also?
    2014 Access Cab 4x4 TRD OR
  2. Jan 5, 2015 at 1:06 PM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    You will need rear Bushings they come with the front ones also you might need carrier bearing spacer kit ARB makes them both
  3. Jan 5, 2015 at 3:36 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Are you getting new rear shocks too?
  4. Jan 5, 2015 at 3:46 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Maybe think about getting u bolt flip kit? That's what I got with my Dakars.
  5. Jan 5, 2015 at 5:53 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  6. Jan 5, 2015 at 6:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Centre pin collars in case you need axle shims later
    You're welcome
  7. Jan 5, 2015 at 8:40 PM
    woodyc
    Craig
    Oceanside, CA
    Yes, I've ordered some Sway Away Coil overs for the front and shocks for the rear. With the Dakars I ordered the U bolts, and the shims. Toytec told me the factory bushings should work fine since they are almost brand new.
    I've not heard about the ARB FK29 Spacer. How does that work and where exactly does it go?
  8. Jan 5, 2015 at 8:44 PM
    bzzr2
    bzzr2 Well-Known Member
    when i got my dakars they came with the bushings already pressed. and ya, if buying new u bolts might as well do the flip instead of having that crap hanging down waiting to catch rocks and stumps. not sure what shocks you will be running but mine are 1 inch longer than the dakars extended and my stock brakelines are good, very very easy to make a $2 relocation piece also if you need it.
    Desert Drifter likes this.
  9. Jan 5, 2015 at 8:48 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    X2 U bolt flip kit!
  10. Jan 5, 2015 at 9:43 PM
    OZ-T
    Peter North
    British Columbia
    The FK29 is a CB drop spacer
  11. Jan 6, 2015 at 7:36 PM
    woodyc
    Craig
    Oceanside, CA
    Thank you all for your help !
  12. Jan 11, 2015 at 8:05 AM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    Subd
