ready to pull the trigger
Discussion in 'Long Travel Suspension' started by BMOC, May 9, 2011.
  1. May 9, 2011 at 8:35 PM
    BMOC
    BMOC [OP] Well-Known Member
    Paden
    Phoenix, AZ
    i have my mind set on getting a long travel kit. i'll be getting some extra cash
    in a few weeks.. and since i've had the truck i've been trying to find out what
    kind of suspension setup i want for it and i think this is just what the doctor
    ordered. and to think i really wanted a DB lift... thank god for TW..
    however i'm still undecided on which kit to order..
    Total chaos or All Pro.. search bar has really helped alot on researching each one.
  2. May 10, 2011 at 7:53 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    depends
    what kind of off roading do you want?
    all pro keeps the stock front fenders, tc doesnt.
    all pro is not as wide as tc
    all pros travel numbers are lower
    if your doing narrow stuff stick to all pro
    if your doing mostly desert and width isnt really a problem go with tc
  3. May 10, 2011 at 8:05 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    how much extra money we talking about because you can't buy a LT kit, throw it on and call it a day. whatever you are planning on spending... double it.
    and like eric said, what types of terrain you planning to hit up? those kit are both LT kits, but two very different kinds of LT kits
  4. May 10, 2011 at 8:06 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    donate sperm.
    its going to waste anyways :p
  5. May 10, 2011 at 8:09 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  6. May 10, 2011 at 8:50 AM
    BMOC
    Paden
    Phoenix, AZ
    I live in the Phoenix area and all the trails I go to are wash type areas pretty sandy and fairly wide so the total chaos should fit through all the trails I drive.
    I'm pretty sure I'll be able to afford the kit either way. I'm just worried about the quality and durablity of each one.
    I was actually thinking of the rear and how I'd do that. I read something about a kit from a company called decide?? And I think I read that I can use the stock shock mounts and save bed space for my quad?? Not sure but iirc I read something about that
    Thanks for the advice guys
  7. May 10, 2011 at 9:00 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    dont worry about the durability of the TC kit... you will break every stock part on the truck before you break anything they build. i can't speak for all pro because i have never ran any of their products
    the rear kit your talking about is defined engineering
    http://www.definedengineering.com/
    when i say double your budget i'm talking about having to build the rear end, gussets all the weak points of the frame and stock parts still being used, fiberglass, tires, wheels, fixing things when they break (which they will, many times) install, fabrication... the list never ends. if you have a LT truck and you use it, you will forever be spending money on the truck as long as you own it
  8. May 10, 2011 at 9:14 AM
    BMOC
    Paden
    Phoenix, AZ
    That's the rear end I was looking at getting unless there's a better one for the type of application I'm looking for. Trying to save bed space for toys and such.
    I understand I'll be forkin out alot of dough but I'm good for it and have read alot of lt stuff on here to know that going hard will eventually break something. But I'm prepared :)
  9. May 10, 2011 at 9:45 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
  10. May 10, 2011 at 9:46 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    x2
    but it's so much fun out in the desert...
  11. May 10, 2011 at 9:52 AM
    BMOC
    Paden
    Phoenix, AZ
    I'll keep that kit in mind for sure!
  12. May 10, 2011 at 9:55 AM
    BMOC
    Paden
    Phoenix, AZ
    I'd really like to know how durable the all pro kit is.. If anybody has any input on that I'd appreciate it!!
  13. May 10, 2011 at 10:00 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    trust me, you dont have to worry about breaking a LT kit... other things will break long before you break the LT kit itself. all pro builds solid products
    honestly, i dont see much point in you going with the all pro kit because you are not 4WD. for alot cheaper you could go with a bolt on mid travel kit and have almost the same travel numbers or for the same price you could get the TC kit, get more travel and have the ability to run a secondary shock.
  14. May 10, 2011 at 10:01 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Depends on how fast you plan on going. The only downside to the AP kit is that there's no mounting points for secondary bypass shocks. Other than that it's a really stout kit!
  15. May 10, 2011 at 10:06 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yep... secondary shocks FTW!!!
  16. May 10, 2011 at 10:10 AM
    BMOC
    Paden
    Phoenix, AZ
    I am 4wd. I guess I forgot to mention.
    I'm not going to get into any organized race league or anything like that. I thinking about speeds around 40 - 60 mph in the wash and washboards I'm introduced to here in Arizona.
    Sounds like the all pro may be something I should look more into because it sounds like they are gonna last over the times
  17. May 10, 2011 at 10:10 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i was about to get myself a set of front bypasses... and then i bought a flat screen and another hand gun...lol
    maybe next month :D
  18. May 10, 2011 at 10:20 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    get em soon and let's go run Lucerne Valley...
    i got this 85 mile loop mapped out on my GPS...
    :D:D:D
  19. May 10, 2011 at 10:22 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    Mike, sounds awesome. lets go anyways, even with out my front bypasses.
    when's good for you?
  20. May 10, 2011 at 10:24 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    last how? like the kit isn't going to break or the company will be around for a long time?
