ReadyLift 2.75" Lift for Tacoma 5Lug
Discussion in '5 Lug' started by david04, Mar 16, 2008.
  1. Apr 10, 2008 at 9:25 PM
    tacomanub08
    tacomanub08 Well-Known Member
    San Diego, Cali
    08 Black Access Cab I4
    Removed 2ndary Air Filter, Front Tint
    Hey gm3, I don't know if you read about it on CT forums but there's a guy here in SD that has a lift for the 5-lugs... I talked to him and he said he was the only one currently that had them and has been shipping them around the US... he charges 450 total w installation.. think this is a good price or should I wait for the ReadyLift and get it installed somewhere else? Also, (noob ? incoming) will the ReadyLift lift both the front and back or just the front?
  2. Apr 10, 2008 at 9:28 PM
    david04
    david04 [OP] Member
    ITS $450 now? I've been meaning to call him, but I don't want to drive all the way south to do it. I'm assuming you mean Eric Conner...
    Did he tell you what exactly he's doing? What do you mean shipping around the US? He has his own product?
    The ReadyLift lifts the front 2.75" and the back 1.75"
  3. Apr 10, 2008 at 9:28 PM
    alextreme76
    alextreme76 Well-Known Member
    Tucson, AZ
    05 Reg Cab 4x4 5spd 265/70/16 Rugged Fails
    what did the cali dude do? no one will say anything on how he is lifting 5 luggers.
    i thinking readylift is reputable company and ill spend the $329 on it.
    this kit has an add a lift but its spring under axle, so what it does it add strength and arc to the spring, go out with a tape measure, the front tire to fender higher is like 2inch diff from front to rear... you can definately fit 32's-33's with little rubbing under articulation in the rear.
  4. Apr 10, 2008 at 9:35 PM
    tacomanub08
    San Diego, Cali
    Yes, Eric Conner.. just talked to him today, really nice guy. He didn't tell me exactly what he does (I probably wouldn't have understood anyways) but he said it lifted the truck 3". Umm, I'm assuming (don't quote me) it's his own product if he's shipping it around.. I suggest you give him a call. I'm sure he'd be able to answer your questions much better than I can, sorry.
  5. Apr 10, 2008 at 9:45 PM
    tacomanub08
    San Diego, Cali
    Check this out guys, this is the after pic of the lift Eric Conner did. Looks awesome.
  6. Apr 11, 2008 at 12:59 AM
    tacomanub08
    San Diego, Cali
    Thanks for the sound advice bud, I think that's what I'll end up doing :D.
  7. Apr 11, 2008 at 5:20 PM
    alextreme76
    Tucson, AZ
    silver truck is 31x10.50 w/ TC cranked to like 3 inchs lift in the front
    white truck is 31x10.50 stock suspension i think he said it rubbed (duh)
    BFG 31's measure to 30.7 true and 32's measure to 31.7 true.
  8. May 15, 2008 at 8:15 PM
    alextreme76
    Tucson, AZ
    we are ordering this kit this summer, you can definately fit 33's on here, it just depends on how much you want to rub and or trim....i thinking BFG T/A with their 33x10.50 which measures a true 32.7 inchs might ride real nice after a little work with a sawz all...the 33x9.50 might be a safer bet and wont rub in turns but will probably touch under full flex
  9. May 22, 2008 at 4:29 PM
    dirtroader
    dirtroader Member
    USA
    03 taco bone stock
    how many mpg did you lose with 31" tires and a mild lift (2-3")
    thanks
  10. Jul 2, 2008 at 10:41 PM
    toyota07
    toyota07 New Member
    5 lug toyota tacoma 4cyl
    y'all said mid may they are commin out with the lift..a dealer out of columbus georgia at action building truck styles said mine was commin in at the end of july for sure..because i kno the guy..he will def hook y'all up if u want it sooner
  11. Jul 3, 2008 at 12:12 AM
    PhoenixCadet
    PhoenixCadet Well-Known Member
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    +1 for this question
    I've been trying to find the answer everywhere.
    Any help?
  12. Jul 3, 2008 at 8:49 PM
    alextreme76
    Tucson, AZ
    if your looking for mpg's and offroading, they dont go hand in hand...just like fastcars and mpgs.
    turbo diesels are the only way to get great mpg's but now you got a dry bearing and a turbo offroad.
    everyone wants a reliable, fuel effienct, and fast/offroad car or truck but you can only have two.
    you'll probably loose 2-3mpg city from the added weight and friction of offroad tires
  13. Jul 11, 2008 at 11:44 AM
    PhoenixCadet
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    So then with this logic, I should just stick with the PreRunner V-6? Makes sense to me that if I'm going to lose some MPG on the I4 by putting bigger tires and a lift on it, just scrap that idea and get the V-6.
  14. Jul 11, 2008 at 10:56 PM
    PhoenixCadet
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    If that's what it'll take to get to Prerunner height, I'll have to look into that.
  15. Jul 11, 2008 at 11:11 PM
    #35
    PhoenixCadet
    San Diego, CA
    11 Reg Cab 2.7L 4x4
    I would love to get an I4 Prerunner, but (while I am learning to drive a manual) I'd really prefer to get an automatic.
  16. Jun 5, 2009 at 12:26 PM
    #36
    livesinthesea
    livesinthesea Member
    gm3bow, did you notice a difference in mpg from before and after you did the lift?
    I'm new to this, and looking to buy a 2.7l auto access cab, which I figure I'm going to want to lift just a little for loading up on camping trips and going on forest/fire/gravel roads but no serious off roading. Would you do the same type of lift/suspension again?
    thanks
    Luke
  17. Oct 29, 2010 at 12:01 PM
    #37
    aggiepack
    aggiepack Well-Known Member
    Nate
    [**SOLD**] '08 Super White reg. cab waiting for the '16
    Fat Bob's 5 lug 2."75" Lift Kit, Fat Bob's Performance 8000 Rear Shocks, 235/75/15 BFG A/T tires, UWS Low Profile Tool Box, AVID Off Road Sliders, Chrome Grille Assembly, Fog Lights, Black badges, Tinted Rear Window, TRD Bed Mat, TRD Off Road Floor Mats, Maglite Mount, CoverKing Seat Covers
    agreed!
  18. Nov 1, 2010 at 6:48 PM
    #38
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    i like it[​IMG]
  19. Nov 4, 2010 at 6:59 PM
    #39
    LBCdan
    LBCdan I got tiger blood.. WINNING
    Dan
    Long Beach , CA
    2012 MGM DCSB TRD SPORT
    Pioneer 4000NEX , grab handle GPS mount, Bakflip tonneau, OME 885, Bilstein 5100s, Wheelers 1.5" AAL
    I put the readylift lift on my 09 reg cab taco w/ 16x8" kmc enduro rims with 31" BFG Long Trails . I get some rubbing on the fender, but I dont know if i will screw something up if I trim.
  20. Nov 21, 2010 at 5:20 PM
    #40
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    looks good. i plan to do mine like that after i do all this christmas shopping.
    what size tires are you running
