Readylift 5lug Wheel/Tires help??
Discussion in '5 Lug' started by ACGrenade, Jul 24, 2011.
  1. Jul 24, 2011 at 12:35 PM
    ACGrenade
    ACGrenade [OP] Member
    Andy
    Florida
    06 Tacoma SR5 Base/Lifted
    Readylift 18 inch VTEC 285/60/R18 Nitto Terra Grapplers BLACKED OUT Windows 4.10 Re-gear INSTALLED.
    2006 Tacoma SR5 5lug Base Access Cab (owned).
    Readylift already installed.
    Just added 285/65/R18 Nitto Terra Grappler
    It rides a little rough, I have disk brakes on the front, and drums on the rear. I am planning to replace the pads VERY soon. Anyone recommend any further mods to get better braking?
    Also, I want to know what I can do to get another inch or two in height? Shock options maybe?
    Thanks for the help!
  2. Jul 24, 2011 at 1:40 PM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    better breaking u can get slotted roters or a big break kit lol
    rear u can add bigger blocks ....... front not much .
  3. Jul 24, 2011 at 1:50 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    As a 5 lug, your only option for more hight on top of your ready lift is a body lift.
  4. Jul 24, 2011 at 5:29 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    what they said^
    unfortunately there are many options for lifting our trucks. here is a thread about most of the option for 2nd gen 5 luggers. i dont think there are any LT trucks 2nd gen 5 lug in there but that is an option but seeing that your in florida its not a very reasonable option since you wouldnt use it unless you wanted to drop all the dough just for the look...
    EDIT: oh and welcome to TW!
  5. Jul 24, 2011 at 9:49 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    if you want more height and performance sell the lift and get a tc mid travel :D
  6. Jul 25, 2011 at 7:16 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    You can add spindles on top of your spacer for more lift instead of BL...
  7. Jul 25, 2011 at 8:55 PM
    113tac
    Stephen
    Northern Virginia
    hes a 2nd gen...as far as i know there arent any spindles available short of fully custom
  8. Jul 25, 2011 at 9:22 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
  9. Jul 26, 2011 at 7:13 AM
    ACGrenade
    Andy
    Florida
    Ok... I found some shocks called "Bilstein 5100 Adjustable Shocks" for Tacomas. But I already have Readylift so will they still work?
    Any suggestions?
  10. Jul 26, 2011 at 8:04 AM
    TexasTacoma37
    No they won't work for 5-lugs...only 6 lugs.
    As I noted above, a body lift is your only option.
  11. Jul 26, 2011 at 8:07 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Your in a bad boat, I have basicaly the same truck as you. Our options are not good and expensive.
  12. Jul 26, 2011 at 4:56 PM
    MowTaco
    Kansas
    Ah. well nevermind.
