ReadyLift 69-5510 on an 09 5-Lug
Discussion in 'Suspension' started by BioMed80, Sep 24, 2008.
  1. Sep 24, 2008 at 2:20 PM
    BioMed80
    BioMed80 [OP] Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    Hello to all,
    I'm wondering if anyone has tried the 69-5510 on a 2009. I emailed ReadyLift, and they said they haven't tried it yet. I searched the forums and didn't find anything either. I would assume it should work, but I wanted to get some confirmation.
    Also, this seems to be the only lift kit for the 05-newer 5-lugs, is that right?
    Thanks in advance.
  2. Sep 24, 2008 at 3:21 PM
    thehtizzle@gmail.com
    thehtizzle@gmail.com Well-Known Member
    Houston, TX
    06 Tacoma 4cyl Access Cab
    3" Redy Lift, radio upgrade, sub + amp, window visors
    I just installed the Ready Lift kit on my 2006 Tacoma 5 lugger. I beleive that is the same lift that is recommended for the 2009. It was my first one to do and wasn't that bad. Took me and two friends about 5 hours to do the entire thing. There was a little grinding required on the add a leaf bolt that holds the leafs together. Overall, I am satisfied with the installation and looks of the lift. I would recommend to anyone.
  3. Sep 24, 2008 at 3:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im pretty sure it will work, because i dont think they changed anything on the suspension end on the 09's from the 05's.
  4. Sep 24, 2008 at 4:00 PM
    BioMed80
    09 Regular Cab
    Thanks for the quick replies, guys. One more question, I'm planning on putting on 31x10.5x15's with the lift. I've read back and forth (with no clear answer) about 15's clearing (and not clearing) the caliper. Any input? Thanks again.
  5. Sep 24, 2008 at 4:07 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    if im not mistaken no 15" wheels will clear the caliper on 05+ tacomas and only some 16" will
  6. Sep 24, 2008 at 4:11 PM
    BioMed80
    09 Regular Cab
    On 5-luggers? My stock wheels are 15".
  7. Sep 24, 2008 at 4:14 PM
    JimBeam
    JB
    2015 Tundra
    well then i may be wrong...maybe its only the 6 lug new ones that cant fit the 15" wheels
  8. Sep 24, 2008 at 4:17 PM
    BioMed80
    09 Regular Cab
    Yeah, I know the 6-lug and 5-lug are different, that's why I'm trying to get some answers before I order everything. Thanks though.
  9. Sep 25, 2008 at 5:59 PM
    BioMed80
    09 Regular Cab
    Bump :eek:
    Also, I've read that the rear shocks are at (or near) max with this lift. Are there options of others with the 5-luggs?
