readylift on 5 lug issue
Discussion in 'Suspension' started by 07regtacoman, Feb 15, 2011.
  1. Feb 15, 2011 at 8:20 PM
    07regtacoman
    07regtacoman [OP] Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Anyone here have any ideas about 5 lug lift rubbing issues.Running 235/75/15's on stock wheels and passenger front tire is hiiting sway bar on full hard left turn.Not an issue when turning right.Alignment forthcoming since I just finished up.
  2. Feb 15, 2011 at 8:36 PM
    armyairforce89
    armyairforce89 Active Member
    Illinois
    2010 5-lug SR5
    Ready Lift SST Lift Kit, Fog Lights, Aluminum Diamond Plate Tool Box, AFE ProDry S Air Filter, UltraGuage, BF Goodrich Long Trail T/A 235x75x15's
    I have the readylift 5 lug kit with no problems at all. I did get the alignment done the same day though, maybe that will help you. I did have an unrelated problem of the drivers side front swaybar link coming loose from the factory causing rubbing. That was unrelated to the readylift and Toyota replaced the link without issue.
  3. Feb 16, 2011 at 7:05 PM
    07regtacoman
    Davis Ca
    07 Silver REG Cab
    Well I rechecked everything and took it in for an alignment.Good to go.Whatever they did fixed it.Truck drives and looks amazing.
