ReadyLift vs. Coil Spacer
Discussion in 'Suspension' started by Airickf, Jan 2, 2009.
  1. Jan 2, 2009 at 2:06 PM
    Airickf
    Airickf [OP] Member
    San Diego, CA
    2006 Tacoma 4x4 TRD
    5100s set at 2.5" Add-A-Leaf in the rear. 265/75r16 BFG A/T KOs
    Are there any advantages of one over the other?
    I'm thinking that the coil spacer will increase preload and reduce the downward travel???
    Where the Readylift (spacer on top of the strut plate) will just reposition the strut lower???
    Also, will using the Readylift cause any shock bottoming?
  2. Jan 2, 2009 at 8:48 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
  3. Jan 2, 2009 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to tacoma World!
    A "top plate" spacer which sits on the strut plate (which lowers the shock and spring) will destroy your ball joints.
  4. Jan 2, 2009 at 8:52 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Are the 2 items he's talking about the same?
  5. Jan 2, 2009 at 8:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    no. One preloads the spring pack, and keeps the length the same. BUT, gives a more stiff ride. the other thengthens the spring/shock combo, over extending the ball joints when you go over a bump, causeing your ball joints to fail.
  6. Jan 2, 2009 at 9:02 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    So he's talking about inserts you slip into the coil?
