ReadyLift vs. FatBobs
Discussion in '4 Cylinder' started by dwtacoma, Dec 16, 2016.
  1. Dec 16, 2016 at 6:43 PM
    dwtacoma
    dwtacoma [OP] Member
    Davis
    NE Alabama
    2012 Tacoma Access Cab Base
    Been looking through old posts about these two lifts for my 2012 5 lug. Seems that most people say more bang for your buck to go with FB. I would like pros and cons of each if y'all got any (or any advice). Basically what I'm trying to get after is a higher, more comfortable, meaner looking rise. Want to put some bigger tires on it as well. Which lift would you guys recommend? I want to keep it as close to factory as possible. The only real posts about this are from 2011 and 2013. Any updates? Have you had any problems with long road trips or stiffness? I don't do much off-roading so thats not a factor. I do drive long distances however. PLEASE. Any advice would help. If y'all have any pics that would be great, thanks.
    DW
  2. Dec 17, 2016 at 9:44 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    It's a steel spacer, there isn't a difference. 30x9.5 will look decent and still be close to stock. 15x7 0 offset. There aren't any other options at the moment.
    dwtacoma[OP] likes this.
  3. Dec 18, 2016 at 12:38 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
  4. Dec 21, 2016 at 5:29 PM
    dwtacoma
    Davis
    NE Alabama
  5. Dec 21, 2016 at 5:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    Even on stock rims you can run 235x75 with no suspension work and no rubbing. And right on the edge in terms of power loss.
    You will get a 1" 'lift' because the tires are 2" in dia larger than OE. And they do fill out the wheel wheels better.
    I didn't want an aggressive tire. I don't need it functionally, it weighs more and often costs more. And I wanted a great road tire. So i shopped Michelin and Bridgestone. Nice ride, great wet road traction, work well in the sand where I haul my yaks.
    And my suspension is still stock.
  6. Dec 21, 2016 at 5:40 PM
    HackD
    William
    Readylift SST Lift/Level kit, with Bilstein 4600 (front) and 5100 (rear). Rims are 16x7", aftermarket, originally intended for use on the Jeep light SUV products (Liberty, Patriot) with similar offset/back-spacing figures to the OEM steel Toyota rims. I currently run 225/75R16 tires.
    dwtacoma[QUOTED][OP] likes this.
  7. Dec 21, 2016 at 5:52 PM
    Clearwater Bill
    Billy
    Largo Florida
  8. Dec 21, 2016 at 8:08 PM
    defythemall
    San diego
    Whichever is cheaper, I paid $55 for mine on eBay. I'd go for 30x9.5 at the smallest, any smaller and it might as well be stock
  9. Dec 26, 2016 at 5:39 PM
    bobbyhill
    bobbyhill Active Member
    mark
    Riverside CA
    08 2.7 5 speed
    Magnaflow muffler, push bar, 3 inch lift kit, 31 inch tires,icon rims15x8, black mess grill,32inch light bar
    I did the ready lift one on my 08 5lug haven't had any issue but it's not really a easy bolt up some small alterations had to be done, the bolt holes had to be widen for the brackets for the new u bolts in the rear and u do have to collapse your spring and rotate your shock and shorten (cut down) the studs to install there spacers in the front. It took me and a buddy about 6 hours to do it all
  10. Dec 29, 2016 at 7:25 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I have an older Fat Bob's lift with the aluminum puck spacer and short AAL. I run the Prerunner rear shocks as they have the correct length and valving. The front struts are KYB and are currently smoked. Have no issues with the kit. One suggestion is use better U-bolts. The supplied U-bolts that came with the kit were plain steel and didn't hold torque after 5k miles. I replaced them with a larger (thicker) U-bolt from the auto parts sold in the help isle no problem since.
    A small tip. The center bolt in the leaf pack is a bear to reinstall. I recommend using a good helping of anti-sieze.
  11. Jan 16, 2017 at 6:16 PM
    sogafarm
    sogafarm Well-Known Member
    GA
    2012 tacoma reg cab spruce mica
    31" Falkon wild peak AT's, fat bobs lift, mud accents
  12. Jan 17, 2017 at 8:24 PM
    sogafarm
    GA
    31's are great for me but they rub at full turn on the swaybar.
  13. Jan 20, 2017 at 10:47 PM
    2.7taco
    Texas
    No rub on 245/75R16 on my 5 lug. My wheels are level 8 I believe they are +18 offset.
