readylift
Discussion in 'New Members' started by ziljain, Mar 17, 2019.
  1. Mar 17, 2019 at 4:56 PM
    ziljain
    ziljain [OP] New Member
    ziljain
    tacoma
    is a readylift system 3" sst lift kit good...cant afford a expensive lift right know.
  2. Mar 17, 2019 at 4:59 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    I don’t know anything about that lift, but welcome to TacomaWorld!
  3. Mar 17, 2019 at 5:01 PM
    ziljain
    ziljain
    tacoma
    Thanks
    Taco critter and irayfz6 like this.
  4. Mar 17, 2019 at 5:07 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Bilstein adjustable on the front. readylift blocks on the rear...best bang for the buck
    Taco critter, irayfz6 and ziljain[OP] like this.
  5. Mar 17, 2019 at 5:15 PM
    GotExhaust
    GotExhaust Well-Known Member Vendor
    Nick
    This would be your best lower cost way to go for a little amount of lift. Let us know if we can help you out. We offer just about everything and offer discounts to the members here!
  6. Mar 17, 2019 at 5:46 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  7. Mar 17, 2019 at 5:48 PM
    Bishop84
    Bishop84 Well-Known Member
    Lots of people run ready lift level kits. Nothing wrong with it if you want to start out. Just don't go bouncing off rocks on a hard trail.
    Be warned, you'll need a ECGS axle bushing if the truck is a 2016+
  8. Mar 17, 2019 at 5:54 PM
    ziljain
    ziljain
    tacoma
    thanks
  9. Mar 17, 2019 at 6:45 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  10. Mar 19, 2019 at 5:46 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  11. Mar 19, 2019 at 5:54 AM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    Have used Ready Lift products and always thought they were decent (for what it is) quality compared to some of the other brands I have seen. Ran their leveling kit in my old Chevy with no issues, I currently run their rear blocks right now in my current truck. My friend has their kit on his Tundra and has had no issues..
  12. Mar 19, 2019 at 6:06 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Welcome to TW!
    Spacer lift's get a bad rap, maybe undeservedly. The problem is, with a spacer lift, shocks run out of travel before the suspension does. The shock then becomes the "bump stop". Slam the front end down and you can bend the lower end of the front shock. For just street driving and mild off roading, they do OK. Start jumping sand dunes, etc, and you can cause issues. I ran a spacer lift for a while when I first got my truck. Went 52K miles and never had a problem. I'd HIGHLY recommend putting a spacer between frame and bump stop to eliminate some front end travel....But even that is suspect if you plan on slamming rocks or jumping dunes... They're a low buck way of getting a little bit of lift, but not without SOME risk. There's a prevailing rumor that top plate spacer lifts effect ride quality. Simply put....NONSENSE. Shock and spring rate do NOT change. Ride doesn't change. As with ANY lift, you would need to have front end alignment changed.
    Long story short, for just a few bucks more you can end up with a much better suspension. Why do all the work and stop just short of "good"?
    The 5100 Bilstiens are the most economical GOOD way to raise the front. Contact Marie at Headstrong Offroad for great deals and greater advice on that set up.
    pipeitup likes this.
