Real life auto lsd uses?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Dec 15, 2009.
  1. Dec 15, 2009 at 4:28 AM
    BSP4x4
    BSP4x4 [OP] Guest
    I don't do any off roading and was wondering when some of you have had to use your LSD button? I know what it is and how it works, but want to know actual, non off roading situations where you have used them. So far this and 4wd Low are the only features i have not used...
  2. Dec 15, 2009 at 5:53 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I use it to pull my Carolina Skiff up a slippery boat ramp.
  3. Dec 15, 2009 at 7:01 AM
    drjohnson36
    drjohnson36 Well-Known Member
    09 Pre-Runner SR5 DC
    Shitty gravel roads
  4. Dec 15, 2009 at 7:21 AM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
  5. Dec 30, 2009 at 5:34 PM
    briboki
    briboki Member
    Denver
    2010 DC SB TRD Off Road 4x4
    On ice tonight.
    Backing the truck into the garage. Half of the road is covered in ice. Back wheels are on ice and the front wheels are on dry pavement. Front wheels are turned all the way to the right. No room to straighten out, so I don't want to put it in 4hi with the front wheels on dry pavement. Try to back up with a small amount of throttle... back tires just spin and the back end slides sideways to the right a few feet. Apply the brakes, stop. Try again by just letting foot off the gas... hoping the truck will idle backwards on the ice. No luck. Little throttle makes it all spin again.
    Push the auto lsd button. Let off the brake, gave it a little gas... and it backed up just like it was on dry pavement.
  6. Dec 30, 2009 at 5:45 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Personally I think my mechanical LSD in my '07 does an excellent job.
  7. Dec 31, 2009 at 12:31 AM
    swendling12
    swendling12 Well-Known Member
    Sean
    Nebraska
    09 Reg Cab SR5 4 cyl 5spd 4x4
    personally I wasn't impressed with the auto lsd when I used it. the mechanical posi in my old GMC was much more effective. Find it easiest to drive my tacoma in the slick stuff if i just turn off traction control entirely, including the auto lsd off.
  8. Jan 29, 2011 at 11:44 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    I wish my truck had mechanical LSD. I tried to get up a slippery hill tonight and the alsd didn't do crap. I know mechanical LSD would have gotten me up it.
  9. Jan 30, 2011 at 12:19 AM
    Yota Newb
    Yota Newb Well-Known Member
    Bryan
    Indiana
    2010 5-Lug Regular Cab 2.7L 5 Speed
    Just a little 2 wheel drive here and I really like the auto LSD. I hit the button when the powder is fresh and it helps a ton. I plow snow for work, of course they have me use their big ass 4x4 Chevy but I have to get to work first and usually about the time we go out, the streets are at their worst condition. This year I have been out five times already and my little 5 lugger has done amazingly well. Deepest snow so far has probably been 6 inches. Pretty impressive for crappy Dunflop 215's!
  10. Jan 30, 2011 at 10:16 AM
    JKD
    JKD Well-Known Member
    I normally leave it in the default (TRAC) mode, but there have been a couple of times in snowy conditions that I wanted a little more engine power while accelerating from a stop. Hitting the A-LSD button works perfectly.
    It is way more effective overall than the LSD equipped vehicles I've had in the past. I've been in some RWD trucks that were plain scary to drive in slick weather, but with TRAC/A-LSD/VSC this truck is excellent in bad weather.
  11. Jan 30, 2011 at 10:32 AM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    I've found when I get stuck in 2wd, Auto LSD doesn't help. Maybe it would help if you enable it before getting stuck, but I just use 4wd.
  12. Jan 30, 2011 at 11:31 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    LSD button?
    There's no LSD buttons on mechanical LSD. It's constantly ON.
    Are you saying, there's a button to turn ON the Auto LSD? Hmm...I always thought that was constantly ON also.
    Or are you referring to the TRD Offroad locker?
  13. Jan 30, 2011 at 11:39 AM
    Ted Nugent
    Ted Nugent Well-Known Member
    Tim
    NEPA
    2010 Reg cab 4x4
    Nope 09 and up models have an electric lsd. Actually its an open diff that uses the brakes to send the power to the left or right drive tires.
  14. Jan 30, 2011 at 11:07 PM
    Janster
    Jandy
    Lancaster, PA
    I knew that....
    I didn't realize the AUTO LSD has a button to engage it.
    Atleast, that's what it appears....
  15. Jan 30, 2011 at 11:11 PM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    Yep. There is a button that turns the VSC off and the ALSD on. Hold it down and it turns it all off.
  16. Jan 31, 2011 at 12:08 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    I would think that traction control is the most of the time program that would be useful.. ICE hello. You don't want to be spinning both wheels on that. Traction control.
    I've only had a few trucks with limited slip or lockers. Most were open diffs and I've never been the one being pulled, always the one doing the pulling.
    Wouldn't complain about em or pay for em. Not for normal truck use. If you were a mountaineer that was trying to get stuck.. eh.
  17. Jan 31, 2011 at 6:41 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    For snow/ice condition
    In my experience, ALSD is far superior then a mech lsd. If you don't believe me, use it when you have 1 wheel on ice and 1 wheel om asphalt, you'll be amazed.
  18. Jan 31, 2011 at 6:55 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If they allowed people to run Auto-LSD constatly they would glaze their break pads and kill them self, then sue Toyota :D (order may be slightly different)
    Hence Mechanical LSD is FTMW !!! 100% of time with out worry about glazing break pads.
    My mechanical LSD does work in those conditions too, and does not require my intervention, and.... can provide constant slip control.
  19. Feb 1, 2011 at 7:08 AM
    supralight
    Dan
    Earth
    Sorry but "auto lsd" is always active with TRAC or ATRAC equipped trucks. It's just that when you "turn it on", you remove the throttle regulation, but yoi always have that locking effect on rear wheels. And I don't think anybody has any problem with glazing brake pads. Mine kicks off pretty often here in Snowland, no problem.
    Also, with one wheel on ice/one on asphalt, the traction is by far superior from a mech lsd, the launch is nearly like both wheels on asphalt even with full throttle applied.
  20. Feb 1, 2011 at 7:38 AM
    JKD
    I find that I have far better directional control on the TRAC/A-LSD equipped vehicles than I ever did with a mechanical LSD. It just works better.
