Real world mpg
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sp02, May 9, 2019.
  1. May 9, 2019 at 11:10 PM
    tacoturdpro
    tacoturdpro Well-Known Member
    2017 White Tacoma TRD Pro 6MT
    around 17-18
    aafontanilla likes this.
  2. May 10, 2019 at 2:06 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Try using fuelly.com or a similar site/app to track your tanks. It’ll give you an accurate measurement, and you can compare your truck’s fuel economy to thousands of like vehicles. My CPU reads about 1 mpg higher than I actually get when I fill up.
  3. May 10, 2019 at 3:03 AM
    evansdmax
    evansdmax Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    I got 19.5 pretty much every tank combined driving with stick tires..... with the 255/85 mastercratfs its dropped to about 17..... manual trans with a camper top... I drive average
  4. May 10, 2019 at 3:13 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    After 3 years, 40 mile daily commute and 41k miles on the truck averaging 55-70 mph, I average 20 mpgs per tank.
    I'm also a +1 tire size with a loaded tool box and sliders.
  5. May 10, 2019 at 3:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    I don't think anyone is really 'offended', just a bit tired around the same top 10 topics.
    You've been here less than 6 months. Stay active and let us know if you have different thoughts in a couple of years.
    ColoradoTJ likes this.
  6. May 10, 2019 at 3:30 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    19.5-20 running 265/70/17s slightly bigger that stock.
  7. May 10, 2019 at 5:40 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Sounds about right from what you describe. When they test vehicles for mpg ratings, they don't drive at 75 mph speeds.
    https://www.fueleconomy.gov/feg/how_tested.shtml
  8. May 10, 2019 at 5:46 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I'm lifted on E rated 33's and I see 20 on the highway at 65 mph.
  9. May 10, 2019 at 5:48 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Stock tires, stock suspension, constantly use TSS @ 72/73, SoCal, 60% freeway, 30% 2 lane back roads @ 55, and 10% streets, NO airdam...
    20.3 avg.
  10. May 10, 2019 at 5:53 AM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    I was getting 14.5-15 with topper with thule load bars, 265/70/17 E rated KO2's, pro wheels, and OEM room rack. I took off the OEM roof rack, predator steps and Thule bars replaced with a prinsu rack on the cab and topper and now i'm getting 16.5-17.
    Not sure what was causing the drop but I've averaging about 2 mpg better after the changes. If i had to guess the wind resistance of the OEM roof rack and square thule bars.
    I'd say 80% of my driving is 35-55mph city driving and the rest about 75mph highway.
  11. May 10, 2019 at 6:14 AM
    KDubU
    KDubU Well-Known Member
    Agree with others that driving at 75mph with a Taco will suck gas although I am in the camp the truck should get better mpg but just doesn’t. Hell my cobra with a 408 gets 20mpg on highway cruising at 80mph.
  12. May 10, 2019 at 6:14 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Is your engine “broke in” yet (after 1500 miles, I got another 2 MPG average)... 2018 stock Limited, easy 24 MPG at 65, 22 MPG at 75 MPH, and goes down to 20 MPH with an 85 MPH average. With headwind, you drink more fuel quickly. I’ve only done one real long distance round trip, Albuquerque to Denver... high terrain (over 5000 feet in both cities) with lots of altitude changes (through a 7000 foot pass). Average highway speed was 75-78 MPH, recorded actual mileage of 22.3 on calm day to Denver and 18.7 on windy day (into wind) for return.
    Most annoying issue was transmission shifting in/out of overdrive gears in the hilly areas, but that’s what it is supposed to do. With headwind, the transmission would “hang” in 4th gear on the flat after climbing a hill... had to tap the gas (while in cruise control) to make the transmission up shift back into OD. Tacoma isn’t a long distance highway vehicle... however it does perform well in ABQ at local interstate speeds.
  13. May 10, 2019 at 6:19 AM
    Loudog504
    Luis
    Baton Rouge, LA
    Tacoma MPG is pretty horrid once you start adding anything. Even stock i never got over 19 on a good day. There are a lot of environment variables to consider as well that will swing it 1-2 mpg. Also, its the internet and people tend to embellish.
  14. May 10, 2019 at 6:30 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    The highest my new Tacoma has achieved in the 3 weeks since I picked it up is 18.0 MPG. Barely enough to meet the low-end of the advertised numbers. Most of the time it’s hovered between 14 and 17 MPG. I’ve been driving like Miss Daisy was in the back, too.
    It is getting 265/70-17 ATs next week. This ain’t looking good...
  15. May 10, 2019 at 6:32 AM
    #35
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    18-20, stock tires set at 35psi, lots of hills, but 95% freeway driving
  16. May 10, 2019 at 6:35 AM
    #36
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    I am always trying to adjust my driving habits to get the best possible mileage out of mine, I’m really happy with what I’m getting 19-24 ish in the V6. It’s turned into a game almost whenever I’m driving now.
    Dubiousveracity likes this.
  17. May 10, 2019 at 6:44 AM
    #37
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Average mid to upper 23's. V6, 4wd, all stock
    mgmdclb likes this.
  18. May 10, 2019 at 6:50 AM
    #38
    Atley45
    Atley45 Well-Known Member
    18-19 mpg combined for the v6 seems to be common for most.
    Check out fuelly.
    Might be able to extract 2-3 mpg in pure highway driving, but that is a "best case" scenario.
    If you're getting anything in the ballpark of 18-19 mpg, you're doing alright.
  19. May 10, 2019 at 6:54 AM
    #39
    HacksawMark
    Mark
    OREGON
    Mine averages from 0.1 to 0.3 higher.
    shakerhood likes this.
  20. May 10, 2019 at 7:02 AM
    #40
    HacksawMark
    Mark
    OREGON
    On full tanks of gas? Or are you just looking at the mpg readout on the dash?
