Real world pulling power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jobberone, Nov 15, 2015.
  1. Nov 15, 2015 at 9:11 PM
    jobberone
    jobberone [OP] Member
    2015 4x4
    none
    New 2015 4x4 V6 auto. Want to pull Luhrs 29' open weighing 10000-12000. I don't have to go but 200 yds to the ramp but I still have to pull it out on a triple axle trailer with brakes. Ramp has good traction and isn't very steep at all.
    I was told it had a 14K lb pull load which seems high for a fairly small vehicle although the 4x4 will help and it doesn't have to travel on roads or hills just the ramp and a short distance.
    So what's the word?
    Thanks
    M
  2. Nov 15, 2015 at 9:24 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Is moving a boat 200 yds with risking damage to your new truck? Warranty doesn't cover that.
    In all reality, it would probably do it like a champ in 4lo taking it easy, but what if it didn't? Don't you know someone with a one ton you can supply a case of cold adult refreshment to?
  3. Nov 15, 2015 at 9:33 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Most childish way to explain love making potion. :rofl:
    ^Ditto o_O
  4. Nov 15, 2015 at 9:35 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Haha. I DID mean beer though - sorry to disappoint your imagination.
  5. Nov 15, 2015 at 9:58 PM
    jobberone
    2015 4x4
    none
    does pulling that weight void the warranty. They said 14,000 lb although I didn't really believe that was correct. I'd look it up in my trusty book they gave me but the truck is in HI and I'm in SC until Dec 7. Ready to pull the string on a boat but want to do my due diligence. Thanks for the replies BTW.
  6. Nov 15, 2015 at 10:03 PM
    PapaBear
    Austin
    SIN CITY
    I'm not imagining things. :cool:
    To my knowledge, it does not. But as @landphil stated, is it worth the risk?
  7. Nov 15, 2015 at 10:08 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Is it really worth chancing your warranty over 200 yards? Placing a load that size on a midsize pickup is definitely putting some stress on the components. Too me, it's too risky. Do as you please OP, but be wary of the consequences if it doesn't work out. I'm sure the dealer could tell the truck was placed under a great deal of stress if they really looked for "wear" signs.
  8. Nov 15, 2015 at 10:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    hows the tongue weight?
    if it doesnt put the truck on the bumpstops.... 4 lo will be a cake walk.
  9. Nov 15, 2015 at 10:11 PM
    jobberone
    2015 4x4
    none
    The boat will be shipped from the East Coast to Long Beach then loaded on a boat for transport to Hilo HI. I will have it towed to the marina by a friend.
    Pulling it 200 yds will damage the transmission and/or frame??
  10. Nov 15, 2015 at 10:12 PM
    ZachPrerunner
    Southeast TN
    No one knows, chance you'll be taking. Highly doubt the frame will be damaged, but power train could give.
  11. Nov 15, 2015 at 10:13 PM
    jobberone
    2015 4x4
    none
    3500 lbs or so I think. I'll have to recheck. These boats are normally on a lift or in the water. Slips are nearly impossible to get there so dry storage is necessary.
  12. Nov 15, 2015 at 10:18 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Who said? A salesman? 6500lbs is the highest possible rated towing capacity of a 2nd gen Tacoma, if equipped with the tow package and a weight distributing hitch. You put 1000 - 1200 lbs hitch weight on it (10% of gross) and try to lift off, bad things can happen very fast. And yes, any failure that can be proven to be caused by abuse or overloading (proven by failure analysis after the failure) will not be coved by warranty.
  13. Nov 15, 2015 at 10:18 PM
    nd4spdbh
    SoCal
    yeah no.... 3500lb tongue weight is WAY WAY over what you ever want to put on the back of the taco.
    mbroughton02, EDDO and Rock Lobster like this.
  14. Nov 15, 2015 at 10:20 PM
    ZachPrerunner
    Southeast TN
    You're pretty much putting another Taco in the bed :eek:
  15. Nov 15, 2015 at 10:28 PM
    jobberone
    2015 4x4
    none
    That's an option. BTW I think the towing capacity is more like 7000 lbs. It is not 14000 lbs which is more like a big diesel truck ie 350 or 3500. I don't think that is in 4 low though. I don't know what the multiplication factor is for 4 low. I'm still not worried about the flat towing for 100-200 yds but I am getting it up the ramp. That's just me and I am listening to you all, ok.
  16. Nov 15, 2015 at 10:30 PM
    jobberone
    2015 4x4
    none
    I'll have to check on the tongue weight. If the boat weighs 10000 lbs then I doubt the tongue weight is that high. That's just the number that came to mind. I'll find out. Some of that depends on the trailer and how it carries the boat.
  17. Nov 15, 2015 at 10:33 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    You can rent a heavy duty truck from home depot. Its like 20 bucks an hour.
    jobberone[OP] likes this.
  18. Nov 15, 2015 at 10:41 PM
    mtnceej
    mtnceej Well-Known Member
    Gary
    Crestline, CA
    2015 SW DCSB TRD OR 4X4
    ICON Stage II TC UCAs Demello Bumper TRD Cat Back Exhaust
    Drive train stress aside (Which would be amplified on the ramp), I would imagine ramp issues even in 4 lo with good traction and only a slight grade, keeping in mind that you're going uphill with 10-12k from a stop with the added weight of water on the trailer. JMHO.
  19. Nov 15, 2015 at 10:42 PM
    jobberone
    2015 4x4
    none
    That's something to consider. Often you can put the boat in and leave if for not quite $10 per day in the water for a week or so which would keep down the need to rent it multiple days. I have to get the tongue weight estimated but you can level with an air system. They're not expensive. I'm still concerned on damaging the tranny. Won't matter if it pulls out without undue strain.
    I'm concerned after reading the responses though. I can invite someone to fish who has a bigger truck, huh. :)
  20. Nov 15, 2015 at 10:45 PM
    jobberone
    2015 4x4
    none
    Yeah, pretty embarrassing to have to get pulled out of that problem. I'm sure the marina can advise but I'm trying to get as many opinions as I can.
    What weight will it pull out safely?
