Real world pulling power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jobberone, Nov 15, 2015.
  1. Nov 16, 2015 at 10:31 AM
    #41
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Put some kind of trolly under the tongue of the trailer that can swivel, support the weight. pull away. Take pics, right.
    jobberone[OP] likes this.
  2. Nov 16, 2015 at 10:35 AM
    #42
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    The highest rated tongue weight of any rear pull hitch is a class 5, it's rated at 18,000 lbs towing with a tongue weight of 1800 lbs.
    For what is worth, I pulled a car hauler with 8000lbs of sheetrock on it across town with my Taco. Probably a 10,500lb load. NOT SUGGESTED!!! If you are only going to launch the boat I wouldn't worry one bit, but I don't think I'd retrieve with it.
  3. Nov 16, 2015 at 10:41 AM
    #43
    Turdsport
    Turdsport Well-Known Member
    Josh
    '14 TRD Sport Supercharged
    I didn't read every post here, but 14000 seems a bit much for our trucks. My f150 was only rated at 12000 with the tow pkg. now don't get me wrong, you could probably move it pretty well with the Tacoma, but can you stop it?
  4. Nov 16, 2015 at 10:58 AM
    #44
    Crashdown
    Crashdown Member
    Houston
    SR5 4x4
    Its this. I would say the tongue weight is in the 1000-1400 pound range. There is no way its 3500 pounds. It would have to use a fifth wheel for that kind of weight.
    Also, for something this heavy and large, it has a weight distribution hitch like travel trailers. That will help distribute the weight to the tow vehicle chassis and not the rear of the vehicle.
    As long as the truck doesn't bottom out when you put the weight on, I would think you should be okay for 200 yards. Take it easy and I doubt it would even break anything.
  5. Nov 16, 2015 at 11:17 AM
    #45
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    id be afraid the truck would get drug by the boat backing down the launch ramp and you you have a submarine taco!
    landphil likes this.
  6. Nov 16, 2015 at 11:22 AM
    #46
    jobberone
    jobberone [OP] Member
    2015 4x4
    none
    With electric trailer brakes how would that happen? And I've never seen a new transmission fail abruptly like that esp if you back off if it's not towing it up. The ramp is very small as the tides are only 3 ft. It isn't steep. So not only are you wrong in what you said here but your sarcasm isn't going to be appreciated by anyone. Yours was the only insulting comment out of all the responders.
    Next time keep your snarky comments to yourself, please.
  7. Nov 16, 2015 at 11:24 AM
    #47
    jobberone
    2015 4x4
    none
    Not worried about that but it may fail to pull it out, which I doubt, but if it did then I'd tie the ramp up until someone towed both the truck and boat out. Not an optimal option. Very embarrassing.
    I've decided to follow all the great advice and not risk it even though I think it'd work just fine. Not worth the risk IMO.
    Thanks for all the responses people.
  8. Nov 16, 2015 at 11:28 AM
    #48
    jobberone
    2015 4x4
    none
    Yeah I was off on the tongue weight although I'd have to have the right trailer. I could also use assist lifts on the rear. I agree. I think it'll do that over a short distance but I've decided for the time being not to even transport a boat out there now until I gather more information. I like being safe. Thanks for the response.
  9. Nov 16, 2015 at 11:29 AM
    #49
    Gearheadesw
    Davenport Fl
    Bummer, that means no pictures, we love pictures.
  10. Nov 16, 2015 at 11:29 AM
    #50
    jobberone
    2015 4x4
    none
    Thanks. Love the avatar.
  11. Nov 16, 2015 at 11:31 AM
    #51
    jobberone
    2015 4x4
    none
    Pull with the truck and stop with the trailer.
  12. Nov 16, 2015 at 11:58 AM
    #52
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Sounds like you made the right decision. Couldn't you just ask another guy who is launching to hook up to your trailer get the boat and move it?
  13. Nov 16, 2015 at 12:42 PM
    #53
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I am sure the Tacoma would do it but you are asking a lot out of that truck. I would be mostly concerned with the tongue weight. Not sure how you would get the boat tongue off the ground if something broke. Not sure you would need 4wd either you could be looking at the sky....:bikewheelie:
  14. Nov 16, 2015 at 1:14 PM
    #54
    vijay
    vijay Well-Known Member
    I only read few replies, so, forgive me if this sounds repetitive.
    a) DO not do this. 3500 LBS on hitch will get your front wheel off the ground.
    b) I cannot even recommend that you rent Pensky or Uhual because this is too much tongue weight.
    c) You can however rent a Pensky or Sunbelt with pin tail hook( you need commercial lic for this). Pin tails are designed to pull 20 ton trailers.
    d) call in wrecker and they will get this done for couple of hundred bucks.
  15. Nov 16, 2015 at 2:09 PM
    #55
    jobberone
    2015 4x4
    none
    Great idea. I'm going to talk to the marina and see what can be done.
  16. Nov 16, 2015 at 2:11 PM
    #56
    Large
    Large Red
    :rain:
    greeneggsnspam likes this.
  17. Nov 16, 2015 at 2:13 PM
    #57
    jobberone
    2015 4x4
    none
    The tongue weight I quoted is wrong. It's more like a 1000 which can be adjusted. I spoke with someone who does this but I'm not going to unless I see more than a few do it over a long period of time without consequences. I'd have never asked if it weren't going a 100 yds or so. Still I'm trying to make other plans including going to a smaller boat.
    Again thank for all the help people.
  18. Nov 16, 2015 at 2:29 PM
    #58
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    Apologize you took it that way. In addition, I have reconsidered my position and think you should go for it.
  19. Nov 16, 2015 at 2:40 PM
    #59
    devkurf
    devkurf Member at Large
    midwest
    @kuffer14 would do it and not think twice about it.
    bigfoote13 and Thomas Jefferson like this.
  20. Nov 16, 2015 at 2:41 PM
    #60
    Lomez
    Lomez
    AZ
    @kuffer14 would plasti-dip the boat first.
    And the trailer.
    TacoTaco15 and Thomas Jefferson like this.
