Realistic bilstein lift install time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtavixx, May 12, 2019.
  1. May 12, 2019 at 1:08 PM
    xxtavixx
    xxtavixx [OP] Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Ive read a lot of threads about the lifts, but almost no one documents how long it takes. Ive got an 8 month old baby girl so I have to arrange things around her. Im not new to working on vehicles, but Ive never done the ECGS bushing or an add a leaf. Both seem straight forward...
    I figure an hour per front shock/coil, an hour for ecgs and axle removal, and an hour total for rear shocks and aal. Including drink/break/coffee...5 hours?
    Front 6112 struts already assembled. Rear is 5100 with 3 lead add a leaf.
  2. May 12, 2019 at 1:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd say if this is the first time you're doing it on these trucks, give yourself 6-7 hours realistically. I've worked on probably 20 tacomas and that'd likely take me 4-5 hours to do.
  3. May 12, 2019 at 1:16 PM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    ^^^^^ exactly. Give your self more time then you think you need.
  4. May 12, 2019 at 1:22 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Dang. I was giving myself more time than I thought Id need. The working quarters that tight or something to slow it down?
  5. May 12, 2019 at 1:27 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The AAL is a PITA, and can take a little while getting the leaf pack apart and back together.
    For the ECGS the CV can be a hassle as well on a newer truck. I've done a third gen where it popped out and the whole process took 40 minutes. I've had another where the CV fought me every step of the way and it took an hour and a half.
    Then there's all the little misc shit that adds up time, like removing skid plates and mounts, sway bar, topping front diff off on oil, looking up torque specs etc.
    Here's a tip that I just tried the other day for the first time and it worked like a charm. Jack up the front drivers side as much as you can, so the vehicle is leaning sideways. Do the ECGS bushing that way. Reason being is when the CV pops out, no oil comes out. That saves time from having to top it off and the mess it can make. Gear oil is nasty.
    DriverSound, 02Duck and synaps3 like this.
  6. May 12, 2019 at 1:33 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Ye, gear oil is nasty. I intended to lift the driver side real high and probably lower the other side by deflating the tire, and tackle the driver side shock st the same time.
    Ive got torque values already mapped out, and really expected the CV to be the hardest part
    Gone are the days of 20 min shock swaps I guess.
  7. May 12, 2019 at 1:35 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    We didn't need to deflate the tire when we did it the other day. Just had a chunk of 6x6 in between the frame and the floor jack to lift it real high and had a 6 ton jack stand maxed out to hold it there. I'm doing every one like that from now on.
  8. May 12, 2019 at 1:35 PM
    SpeySquatch
    2016 TRD OR DCSB
    When you do the ECGS have a 2-4lb hammer because you will likely need to hit these grooves in the CV away from the truck to get the CV to pop out. If you loose fluid it’s not a big deal because the front only holds 1.1-1.4qts anyways. The part of getting the CV out can be a pain unless you have a metal rod and heavy hammer you can wack this thing straight out. Note: I’m using the punch wedge to point at the grooves, ideally the punch should be almost straight with a slight angle when you hit it out so you get the most force in the groove. If you are worried about marring the metal wrap the tip of your punch in electric tape
    DriverSound and stealthmode like this.
  9. May 12, 2019 at 1:39 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Know how many years it took me to learn the tape trick, and you put it out there for free?
    Honestly, solid advice in the post. Thanks!
  10. May 12, 2019 at 3:44 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    If you've never done the ECGS bushing give yourself at least a few hours plus a helping hand to hold the axle. You can make a bushing install tool using the removal tool, a few sockets and electric tape to protect the inside of the bushing. Ck youtube, there is a video on this. I would also tape off that protruding bolt so you don't nick or tear the CV boot. If you're careful you won't even need to change the rubber seal if your truck has low miles - save yourself $16.
    No gear oil leaked out of mine but I checked it anyways once it was back level and found it about a third qt low. So much for the dealer inspection. I plan to replace my gear oils after break in.
    Give yourself a few hours for the front install and about 4-6hrs for the rear AAL and a couple more for the 5160s.
    You will have to grind off the rear rivets of each leaf spring's rear alignment clamp and then use a pry bar to bend them off. The new leaf pack will have new alignment clamps.
    Another consideration seldom mentioned on here is to install a sway bar relocation kit to move the sway bar one inch away from the larger new coils, the new larger coils might rub the sway bar when driving over a speed bump or off roading.
    Unless you are rock crawling you should retain the front sway bar, it could save you in a bad situation. I drove mine with and without and it made a big difference. The kits run about $25-$35 and take about 20 min to install, I painted my brackets black.
    SR-71A likes this.
  11. May 12, 2019 at 3:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That only applies to some AAL, mainly the Icon which is why I hate them. The headstrong and Wheelers don't have that issue.
  12. May 12, 2019 at 3:52 PM
    MtnFisher
    ZeroDrift
    I installed Wheelers AAL last weekend and the factory alignment clamp was in the way. Mine is a 2019, I think there was a thread on this awhile back.
  13. May 12, 2019 at 3:53 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Interesting, I stand corrected. Maybe it's headstrongs then, or maybe it's a model year difference. All I know is I've installed many different brand AALs on all different years of trucks and I've only had to cut the clamps once, on an icon pack.
  14. May 12, 2019 at 3:58 PM
    MtnFisher
    ZeroDrift
  15. May 12, 2019 at 4:06 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It took me about 6 hours one day to do both F shocks and 4 hours a second day to do the rear shocks. There is a learning curve. That time includes setup and cleanup time. I did this by myself on my driveway.
    synaps3 and MtnFisher like this.
  16. May 12, 2019 at 4:07 PM
    MtnFisher
    ZeroDrift
    This video at about 1:38 shows the clamp removal. Note his AAL install took longer than he estimated.
    https://m.youtube.com/watch?v=9mdo-GnoVhY
    This is why I always take my time, as a former mechanic I don't have to worry about meeting expected flat rate times when working on my own $hit and can do a much better job than any shop trying to make a profit.
  17. May 12, 2019 at 4:11 PM
    MtnFisher
    ZeroDrift
    That's a 2 day job if you include the ECGS bushing install. And you don't want to rush the ECGS bushing install. I did have to grind my removal tool a bit to make it fit to remove the needle bearing. Again that was not anticipated. The removal tool is waay overpriced for what it is but needed.
  18. May 12, 2019 at 4:54 PM
    thekidkaiser
    thekidkaiser Well-Known Member
    Black TRD OR | DCLB
    Just finished mine and with plenty of frustration along the way I'd say about 10hrs. A very very long one day project.
  19. May 12, 2019 at 5:28 PM
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
    My Bro-in-law who works on F-16 Falcons and I took 8 hours to do just the lift. Didn’t do the bushing. There is a learning curve and things don’t always go as planed. Like when we were compressing the spring and it started to lift the truck off the lift while raising the lower control arm. Took time to figure that one out. I started spraying the bolts with PB Blaster a few days ahead of the install and that helped big time after 7 WI. winters.
    This isn’t a NASCAR pit stop. Take your time so it’s done right and no one gets hurt.
  20. May 12, 2019 at 6:20 PM
    hrivera007
    hrivera007 Well-Known Member
    2017 Off Road Auto
    Did mine yesterday. Taking my time and watching YouTube videos and reading how-to's from this forum. It took me around 10 hours. That was including assembling the new shocks. The front took me around 6 hrs and the add-a-leaf around 4hrs. Im still waiting for one of my rear shocks that's on back order so I haven't done the rear shocks but they look simple.
    I had issues lining the passenger side Icon AAL. Took a break, went for a smoke, came back and everything lined up perfectly. Go figured. The driver side was fast and painless.
    I have the SPC uca's and the ECGS bushing. Debating if that's a job I want to tackle or pay for it. In the end I saved myself around 600-700 hundreds doing the lift myself which in turn I purchased a bunch of tools to help me the project.
