Realistic bilstein lift install time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtavixx, May 12, 2019.
  1. May 12, 2019 at 6:24 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    UCAs are easy. Hardest part is bending the metal back but with the proper tool it's a walk in the park. For the ECGS bushing I can understand being intimidated, though it's not too horrible.
    hrivera007[QUOTED] likes this.
  2. May 12, 2019 at 6:32 PM
    hrivera007
    hrivera007 Well-Known Member
    2017 Off Road Auto
    True, the part I need to read more if on the settings on the spc's. I might try both next week if I can get a tool for the ECGS bushing.
  3. May 12, 2019 at 6:35 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's easy too, in the instructions they have the recommended middle setting which is good for 95% of people. Good luck!
  4. May 12, 2019 at 6:41 PM
    hrivera007
    2017 Off Road Auto
    Sounds good. I will try it this weekend.
  5. May 12, 2019 at 6:42 PM
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    I recommend buying 2 new UCA bolts and cutting the old ones out. For ~$20 a piece it will save you time and hassle bending fenders out of the way.
    Taco-Grinder and synaps3 like this.
  6. May 23, 2019 at 4:58 PM
    xxtavixx
    xxtavixx [OP] Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Some follow up that I learned,
    For the front, disconnect the sway bar on both end links before you start. Buy yourself the room.
    Youll want four 3-4” clamps for the AAL. I had 2.
    Don't forget to make sure your grease can is full before you rely on your memory. Also latex gloves are nice.
    For the AAL, you really want the rear of the truck higher than you think youll need it. Id suggest having your tires dropping at least 4-6” off the ground. You can do it with 2” like I did but its harder.
    Time?
    Passenger side front - 45 minutes.
    Driver side front - had I not hit complications with the egcs bushing, 90 minutes. The half shaft is very annoying to remove.
    Rear- having four clamps I could have probably done each side in an hour.
    Including jacking up and all that...
    5-6 hours for your first time. Having done it now, Id maybe get into the 4-5 hour mark
    18BRMTRDSportTaco and Boghog1 like this.
  7. May 23, 2019 at 5:34 PM
    freeriderchad108
    freeriderchad108 Well-Known Member
    Boston
    2016 Tacoma TRD Sport Silver
    A few minor things...
    Please don't do the add a leaf. I did that when I installed 6112/5160s and I regretted it enough to pay $600 for a set of OME 95R leafs. My truck rides so much better now. The AAL are a bandaid that makes your truck look the part but makes it ride like crap.
    Took me 8 hours solo to do 6112/5160, leaf springs, Bushings for shackles (don't attempt until you research what you're in for...), ECGS bushing.
    Driveway, HF 3 ton daytona jack, 2-6 ton and 2-3 ton jack stands, impact sockets, cordless impact, ice cold beverages (non alcoholic while working...)
  8. May 23, 2019 at 5:37 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Which aal did you do?
  9. May 23, 2019 at 5:41 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    When I did all mine, I did the rear leafs one day and the front coils, shocks, bushing another day. Plus, it was late last summer and my garage was about 110F
  10. May 23, 2019 at 6:05 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Mine rides great with my 5160s and AALs so don't go spewing BS on this forum. If yours rode like crap then you chose the wrong AAL.
  11. May 23, 2019 at 6:07 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    This is in line with my thinking. And why I wanted a 3 leaf aal that doesnt engage until loaded.
    With that said, if his oem springs were inverted sagging - yea, maybe
  12. May 23, 2019 at 6:09 PM
    MtnFisher
    ZeroDrift
    Yep, mine are Wheeler's multi leaf AALs. My friend has the same combo on his 2nd Gen and highly recommended them.
    Not all AALs are the same yet folks give out bad advice based on limited experience.
  13. May 23, 2019 at 6:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not gonna lie, I nailed my original quote.
    Boghog1 likes this.
  14. May 24, 2019 at 2:43 AM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Yea, you sure did.
  15. May 24, 2019 at 3:24 AM
    #35
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Took me 5 hours
    6112s pre assembled to 5/6. No ECGS replacement or vibration. (5,000km since install) rear ICON 3leaf AAL. Overload removed.
    Truck is night and day ride better on and Offroad. Run overload out unless you tow a lot. Then I would run overload out and invest in some bags.
  16. May 24, 2019 at 3:38 AM
    #36
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Learning curve w anything first time. I’d say give yourself 8-10 hiurs
  17. May 24, 2019 at 3:39 AM
    #37
    xxtavixx
    Jacksonville fl
    2018 6MT
    No ecgs, yea I could see that. Thats the longest part. I dont tow a lot, but I am running overload leaf in because I use the bed a good bit and I want to keep factory rake
  18. May 24, 2019 at 4:40 AM
    #38
    Oxwhite
    Oxwhite Well-Known Member
    Brent
    2018 TRD off-road. White
    So much helpful information on this site.
  19. May 25, 2019 at 2:01 PM
    #39
    freeriderchad108
    Boston
    Ok. My 5160s and AAL rode like a brick. It was the icon 3 leaf. I took out the overload leaf and it still rode like a brick.
    I bought OME leafs and it rides great.
    Not bs.
  20. May 25, 2019 at 2:06 PM
    #40
    freeriderchad108
    Boston
