Realistic bilstein lift install time
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtavixx, May 12, 2019.
  1. May 25, 2019 at 2:18 PM
    #41
    bees015
    bees015 Well-Known Member
    Sacramento, CA
    2017 White Tacoma TRD Offroad
    OME 886/HD Leafs w/nitrochargers LVL8 MK6 16in Wheels w/265/75/16 BFG KO2 Rigid Ditch Lights w/CaliRaised Brackets Various MESOs B&M Trans Cooler WeatherTechs LED Hi/Low w/Fogs Pop N' Lock Tailgate UltraGauge MX HD Front Brakes OVTune 1.05 2000 T4R SOLD 2014 RAV4 SOLD 2008 FJ Cruiser RIP 2010 Scion tc
    If its your first time doing something like this, 50% more time than you expect at least. Breaking parts, missing tools, loosing hardware, etc. 100% have access to a second vehicle when yours is ripped apart should you have to order parts....been there, missed work etc..... Its worth waiting to do the job if you can get an extra set of hands to help out but totally doable alone.
  2. May 25, 2019 at 2:23 PM
    #42
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Add a leaf isn’t hard, just annoying. The ECGS bearing should be around 1:30 max if you take it slow and know what you’re doing. The front 6112s should be the quickest. As well as the rear shocks
  3. May 25, 2019 at 2:31 PM
    #43
    xxtavixx
    xxtavixx [OP] Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    AAL is really easy with four clamps. The passenger side took me about 45 minutes total with four clamps. Thats retorqueing and all grinding down the rear rivet.
    Start with four clamps on the Oem leaf, two on the leaf above the overload as far out as you can. Put two close to the center pin. Remove pin, flip it over and thread through with out putting the nut on. Remove 2 clamps by pin and drop the overload leaf. Clamp one near the center and grind off the rivet.
    To install aal, remove the clamp near the center and thread the two extra clamps wide enough you can hold the AAL uncompressed and oem leaf. With the center pin in the aal, stick it in and push the factory pin out the top and put the nut on the aftermarket pin. Do not tighten the nut to compress, but grab those two spare clamps and compress. Putting the pin nut on is only buying you a free hand to get the clamps going. I suggest they be about 4” from the pin on either side. Dont be gentle here, clamp them hard.
  4. May 25, 2019 at 2:39 PM
    #44
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    To each their own I did a full coilover installation on my truck with adjustment under 2 hrs. rear shock installation was right on the 30 minutes without lifting the truck or removing tires
  5. May 25, 2019 at 2:55 PM
    #45
    xxtavixx
    Jacksonville fl
    2018 6MT
    If you arent doing the aal or ecgs bushing, yea I can see that
  6. May 25, 2019 at 3:26 PM
    #46
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I did them with the leafs still on the truck. Getting them together wasn’t hard at all, realignment of the center bolt into the axel was kind of a bitch
  7. May 28, 2019 at 3:47 PM
    #47
    RoughTaco
    RoughTaco Active Member
    2016 SR5 Tacoma
    How big of a clamp is needed to do AAL and how did you do it without removing from truck?
  8. May 28, 2019 at 5:35 PM
    #48
    xxtavixx
    Jacksonville fl
    2018 6MT
    I suggest two 3” and two 4”. The 4” for closer to the pin.
  9. May 29, 2019 at 4:49 PM
    #49
    RoughTaco
    2016 SR5 Tacoma
    Just got done on the install finally un-hitched that invisible trailer I’ve been pulling for the past 2 weeks lol
