Realistic gas mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sub-arctic Toy, Jan 8, 2025.
  1. Feb 8, 2025 at 4:31 PM
    #81
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Typically get about 21 mpg. Highway and city mix.
  2. Mar 23, 2025 at 2:06 PM
    #82
    RonMx18
    RonMx18 Active Member
    Ron
    2012 Tacoma access cab 4x4 V6 6 spd man.
    Eibach pro coil overs set at 3", General Spring 3+1 rear leaf pack, Eibach extended rear shocks, Freedom Offroad Upper & lower Control arms.
    (Nelly 4x4) I think all DuraTracs are LT's tire rack shows them at 60lbs each...i found the lightest P285/70R17 in Kenda Kleever A/T at 45 lbs each, then 21 lb FN wheel, the kicker is i paid 185.00 each for the Kenda's & thats from a brick & mortar store january of 2025 (they also come in a more aggressive MT). Point is, im sure tire weight, rolling resistance, aero dynamics (from lift kit) winter versus summer blend fuels, top speed, wind, uphill/downhill,,,,were looking at a "shit sandwich" of factors. I have a 1/4 of a tanks worth of fuel before i can calculate my 1st tank of fuel with the lift & tires on plus the winter blend so i don't think i will see 19.6 before lift on 265/16s then 16.6 after lift & 285/17. Really doubt you have a motor issue thats effecting yor mileage its just yor right foot mixed in with all the above
  3. Mar 23, 2025 at 2:16 PM
    #83
    RonMx18
    Ron
    i am very close to yor set up with the same motor & 6 spd.....will not be happy if i end up at 15 !!! you may want to check to see if a buddy snuck over at nite & replaced yor spare tire with 800lb boat anchor as a joke
  4. Mar 23, 2025 at 2:58 PM
    #84
    scocar
    scocar hypotenoper
    [​IMG] There is no realistic mileage.
    YMMV.
    As indicated by all the other previous mileage threads. But carry on, sage contributors, carry on. There's always room for another circle jerk on a model that was released in 2005.
