Realistic MPG Expectations?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Luxy60, Oct 15, 2018.
  1. Oct 15, 2018 at 7:43 AM
    41magmag41
    41magmag41 Well-Known Member
    jim
    New Hamshiire
    tacoma double cab TRD 4 x 4
    Im in New Hampshire with my driving mostly highway. Speed limit is 70 but I run closer to 78 or so. Summer I get between 19 to 20 mpg. Winter blend and colder weather I get 18 or there abouts. Trd off road, 4x4, double cab.
    Skidog1 likes this.
  2. Oct 15, 2018 at 7:57 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Do any of you guys actually write down the miles and gallons for each fillup to compare to the computer readout? I've been recording the miles/gallons for 34+ years on every vehicle and it clearly shows when winter gas kicks in or you have something starting to get out of tune. The stock computer seems to over estimate the real mpg every time. That being said, my 2013 reg cab with the 2.7 AT and 285/75/16 tires and 3" lift is averaging around 16.41 since I got it back in late March. I do mostly around town driving which stays under 50 mph and I tow a couple of boats 10 miles back and forth to my boat ramp. It sounds like the V6 trucks get better mpg than the 2.7 trucks.
  3. Oct 15, 2018 at 8:00 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The computer in my truck is surprisingly accurate, anytime I hand calculate it is pretty much spot on.
    m603holden, Vanderjdm and phsycle like this.
  4. Oct 15, 2018 at 8:11 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    You know people keep complaining about Winter Blend fuel but from last february to today i've maintained the same gas mileage. I think its a bunch of hocus pocus. I think it has far more to do with it being winter than the gas alone.
    They say Winter Blend fuel has 1.7% less energy density as summer. So why would your MPG be dropping by 20%+ in winter?
  5. Oct 15, 2018 at 8:14 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    I'm either looking at the wrong average MPGs or I drive a helluva lot worse than I thought.
    Maybe both.
  6. Oct 15, 2018 at 8:41 AM
    MinerTaco
    MinerTaco Active Member
    SoCal
    2018 TRD Off Road DBL
    Similar setup for me...Same mileage
  7. Oct 15, 2018 at 9:12 AM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    I still get great mpg even with heavy traffic mixed into highway.
    19-20+ mpg
    The key is that I don't really accelerate much and instead let the impulse of the iddle engine take me forward and I also leave a bigger gap than usual in front so if I do accelerate, I know it won't be wasted 3 seconds later by breaking.
    Dacon, MidCitiesMildMan and TD90S like this.
  8. Oct 15, 2018 at 9:21 AM
    Taco Mustard
    Taco Mustard Well-Known Member
    TRD SPORT
    I have a Sport DC. Have 3800mi and I get the as advertised 18 city 22hwy. I have a 90mi drive to work 2 days a week and I’m always about 22mpg at the end of the trip. I also drive 75-80 on the highway so I’m sure I could do better.
    Now I know people will tell me I’m absolutely full of shit but if I run a few tanks of mid grade or above I can squeeze out a bit better gas miliage and the truck seems more throttle responsive. I also do not have the latest TSB update. I also don’t think I really need it. Good luck with your truck. I love mine.
  9. Oct 15, 2018 at 9:24 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I use fuelly.com with every fill up. It tracks the actual mpgs. I've had my truck for exactly 1 year this week and you can see my actual hand calculated Avg is 19.7 mpg.
    I live in a cold climate so winter I was seeing about 17-18 mpg and in summer 20-22 mpg.
    Kilokato likes this.
  10. Oct 15, 2018 at 10:22 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    I have checked mine a couple times. It was very close. I don't remember the difference, but it was trivial.
    phsycle and shakerhood like this.
  11. Oct 15, 2018 at 10:37 AM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Are you tracking your fillups with Fuelly?
  12. Oct 15, 2018 at 10:46 AM
    Jrazzle
    Jrazzle Well-Known Member
    Denver, CO
    realistically, with no wind, flat road, and no additional weight with the automatic, 22 highway, 18 city. my average is 15, but i also have a manual with about 1500lbs worth of stuff on it.
  13. Oct 15, 2018 at 10:49 AM
    MidCitiesMildMan
    No. As I posted above, I checked a couple fillups and the onboard computer was close enough for me.
    I used cleanMPG for years to track fuel mileage of my cars, and was / am a little bitter when they deleted everything. I would have liked the chance to backup my data. So I probably won't use an online tracker again.
    shakerhood likes this.
  14. Oct 15, 2018 at 10:49 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    40 mile R/T daily commute I average 21 mpgs on summer gas, 19 mpg in the winter running at sea level and keeping it at less than 65mph.
    Truck has 35k on it.
  15. Oct 15, 2018 at 1:21 PM
    #35
    greengs
    AB, Canada
    Doesn't that exceed your payload by 20-30%?
  16. Oct 15, 2018 at 2:58 PM
    #36
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    If you haven't hit it, its coming. Last two tanks for me I dropped from ~20 to 18. Yesterday was the first day below 40.
  17. Oct 15, 2018 at 3:34 PM
    #37
    phsycle
    phsycle Well-Known Member
    CA
    That's surprising. I've now had both the auto and manual. Same commute/errand routes, the auto got 10% better MPG. For all highway, going 70mph, there was only about 1MPG difference (favoring the auto). Both trucks at stock.
  18. Oct 15, 2018 at 3:39 PM
    #38
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    The free Fuelly app on your Android phone works great. You can then link it to your TW account.
  19. Oct 15, 2018 at 3:55 PM
    #39
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    your commute sounds VERY similar to mine. 43 miles each way. About 50 mins to 1 hr/ 8 mins. Atlanta area.
    20-21mpg (2017 TRD Sport)
  20. Oct 15, 2018 at 4:07 PM
    #40
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    I guess if I had a cell phone that would work. :D
    From what I understand about the winter gas is that it contains an oxygenate which is like liquid oxygen. So you really are getting less gasoline per gallon if that oxygenate turns to a gas (oxygen) in the combustion chamber. So a simple example would be you normally go 200 miles on 10 gallons of gas and get 20 mpg. With the oxygenate, you pay for 10 gallons of gas but it's really less like getting 9.5 gallons of gas. So you go 190 miles now but based on putting 10 gallons in your truck it looks like you're getting 19 mpg. I'm not sure how accurate this is, but that's how I understood what was happening. Now add longer warmups and higher idle due to the cold and it will burn more gas without going anywhere so that obviously hurts your mpg.
